Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problem with asyncExec() - freeze app
Problem with asyncExec() - freeze app [message #830862] Wed, 28 March 2012 02:27 Go to next message
I have some code inside asyncExec() call, but it freeze gui. Why ? Full code below.
import org.eclipse.jface.action.MenuManager;
import org.eclipse.jface.action.StatusLineManager;
import org.eclipse.jface.action.ToolBarManager;
import org.eclipse.jface.window.ApplicationWindow;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridLayout;
public class TestApp extends ApplicationWindow {
	 * Create the application window.
	public TestApp() {
		super(null);
		createActions();
		addToolBar(SWT.FLAT | SWT.WRAP);
		addMenuBar();
		addStatusLine();
	 * Create contents of the application window.
	 * @param parent
	protected Control createContents(Composite parent) {
		Composite container = new Composite(parent, SWT.NONE);
		container.setLayout(new GridLayout(1, false));
			Button btnNewButton_1 = new Button(container, SWT.NONE);
			btnNewButton_1.setText("Freezed");
		Button btnNewButton = new Button(container, SWT.NONE);
		btnNewButton.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent e) {
				Runnable task = new Runnable() {
					public void run() {
						try {
							Thread.sleep(3000);
						} catch (InterruptedException e) {
							e.printStackTrace();
						getStatusLineManager().setMessage("Some message");
				Display.getDefault().asyncExec(task);
		btnNewButton.setText("Some Task");
		return container;
	 * Create the actions.
	private void createActions() {
		// Create the actions
	 * Create the menu manager.
	 * @return the menu manager
	protected MenuManager createMenuManager() {
		MenuManager menuManager = new MenuManager("menu");
		return menuManager;
	 * Create the toolbar manager.
	 * @return the toolbar manager
	protected ToolBarManager createToolBarManager(int style) {
		ToolBarManager toolBarManager = new ToolBarManager(style);
		return toolBarManager;
	 * Create the status line manager.
	 * @return the status line manager
	protected StatusLineManager createStatusLineManager() {
		StatusLineManager statusLineManager = new StatusLineManager();
		return statusLineManager;
	 * Launch the application.
	 * @param args
	public static void main(String args[]) {
		try {
			TestApp window = new TestApp();
			window.setBlockOnOpen(true);
			window.open();
			Display.getCurrent().dispose();
		} catch (Exception e) {
	 * Configure the shell.
	 * @param newShell
	protected void configureShell(Shell newShell) {
		super.configureShell(newShell);
		newShell.setText("New Application");
	 * Return the initial size of the window.
	protected Point getInitialSize() {
		return new Point(450, 300);
Re: Problem with asyncExec() - freeze app [message #831208 is a reply to message #830862] Wed, 28 March 2012 12:00 Go to previous messageGo to next message
It looks like you don't completely understand the behavior of asyncExec. You use this method to run code on the GUI thread. While your Runnable's run method is processing the GUI thread can't do anything else. Your run method has a 3 second sleep. Since this will be executed by the GUI thread, your GUI will be locked up for the duration of the sleep.
You most likely have the process backwards, you need to kick off a Job/Thread that sleeps for 3 seconds and then invokes asyncExec with a Runnable that only updates the Status Line.
Re: Problem with asyncExec() - freeze app [message #831720 is a reply to message #831208] Thu, 29 March 2012 04:51 Go to previous messageGo to next message
Could you provide some code to do this right ?
Do You mean somethink like that:
final Runnable task = new Runnable() {
	public void run() {
new Thread() {
	public void run() {
		try {
			Thread.sleep(3000);
}.start();
[Updated on: Thu, 29 March 2012 05:30] by Moderator
Re: Problem with asyncExec() - freeze app [message #831924 is a reply to message #831720] Thu, 29 March 2012 10:25 Go to previous messageGo to next message
That seems to catch the general idea. The long running operation (Thread.sleep(3000) in your case) is performed on a thread separate from the display thread. The asyncExec call is then used to update the display on the display thread.
Re: Problem with asyncExec() - freeze app [message #832730 is a reply to message #831924] Fri, 30 March 2012 10:03 Go to previous message
Note that if the point of the sleep() is to just delay for some time
before doing something then Display.timerExec() is a much simpler way to
do this, no additional threads required. Example snippet:
http://git.eclipse.org/c/platform/eclipse.platform.swt.git/tree/examples/org.eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet60.java
Grant
Previous Topic:SWT error while trying to create JavaServer Faces project
Next Topic:How to restrict user from going to Next Page if all the fields are not populated in Eclipse SWT
Current Time: Wed Jul 23 12:53:43 EDT 2025
Powered by FUDForum. Page generated in 0.31171 seconds
