Failed to load design in BIRT 2.6.2 runtime [message #832351] |
Thu, 29 March 2012 23:35  |
We have number of eclipse BIRT 2.3.1 reports running fine in Production since 2008. Same reports fail in run time after upgrade to v2.6.2.
In runtime we invoke the custom ReportAdapter which extends DataSourceEventAdapter via Event handler class.
Code Snippet:
reportContext.getAppContext().put(
"org.eclipse.birt.report.data.oda.xml.inputStream",
//"org.eclipse.datatools.enablement.oda.xml.inputStream",
//new ByteArrayInputStream((ReportDefender.encoder().decode(new String(getBytesFromFile(xml)))).getBytes()));
new ByteArrayInputStream(getBytesFromFile(xml)));
reportContext.getAppContext().put("org.eclipse.birt.report.data.oda.xml.closeInputStream", new Boolean(true));
Existing Environment:
BIRT Runtime - 2.6.2, Sample WebViewer, JDK 1.5
Report DataSource XML
And the DataSet is build dynamically via eventhandler class. We are getting the below errors;
On Browser:
Table (id = 53):
- Can not load the report query: 53. Errors occurred when generating the report document for the report element with ID 53.
Error.ReportQueryLoadingError2 ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Can not load the report query: 53. Errors occurred when generating the report document for the report element with ID 53.
at org.eclipse.birt.report.engine.data.dte.DataPresentationEngine.doExecuteQuery(DataPresentationEngine.java:164)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1890)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.executeQuery(ReportItemExecutor.java:412)
at org.eclipse.birt.report.engine.internal.document.v4.TableItemExecutor.doExecute(TableItemExecutor.java:72)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.execute(ReportItemExecutor.java:294)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.prepareChildExecutor(ContainerExecutor.java:226)
On Birt logs
Mar 29, 2012 2:20:34 PM org.eclipse.birt.report.engine.script.internal.ScriptExecutor
WARNING: Unhandled exception when executing script.
org.eclipse.birt.report.engine.api.EngineException: Unhandled exception when executing script.
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:162)
at org.eclipse.birt.report.engine.script.internal.ReportScriptExecutor.handleInitialize(ReportScriptExecutor.java:53)
at org.eclipse.birt.report.engine.api.impl.EngineTask.loadDesign(EngineTask.java:1766)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:216)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:85)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1315)
Caused by: java.lang.ClassCastException: com.idl.maistro.report.adapter.ReportAdapter incompatible with org.eclipse.birt.report.engine.api.script.eventhandler.IReportEventHandler
at org.eclipse.birt.report.engine.script.internal.ReportScriptExecutor.handleInitialize(ReportScriptExecutor.java:46)
Mar 29, 2012 2:20:36 PM org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
SEVERE: Unable to open connection.
org.eclipse.datatools.connectivity.oda.OdaException: Some connection properties are missing.
at org.eclipse.datatools.enablement.oda.xml.util.XMLSourceFromPath.<init>(XMLSourceFromPath.java:35)
at org.eclipse.datatools.enablement.oda.xml.util.XMLSourceFromPath.<init>(XMLSourceFromPath.java:42)
at org.eclipse.datatools.enablement.oda.xml.impl.Connection.open(Connection.java:87)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaConnection.open(OdaConnection.java:250)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:165)
at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:224)
Attached the XML, XSD, Report Design and CSS
Thanks in advance
Attachment: Report.zip
(Size: 14.02KB, Downloaded 295 times)
Re: Failed to load design in BIRT 2.6.2 runtime [message #832379 is a reply to message #832351] |
Fri, 30 March 2012 00:10   |
You may want to try:
Did you mean to set the "new handler on each event" advanced property on
your data source? You may want to set that to false. If you are
re-using the same stream you also may need to reset the stream in the
beforeOpen of the data set.
Jason
> Code Snippet:
> On Browser:
> Table (id = 53):
> On Birt logs
> Thanks in advance
FUDForum. Page generated in 0.07601 seconds
