Home » Language IDEs » Java Development Tools (JDT) » how do I see compiler errors??
how do I see compiler errors?? [message #831967] Thu, 29 March 2012 11:28 Go to next message
I keep getting "Error: Could not find or load main class ..." error.
Finally wondering if the issue is some kind of compilation error that I'm not seeing. For the heck of it, I created a couple different errors that should have given me some kind of error msg upon compilation, but I don't see any! I tried creating an object that isn't defined, and I intentionally put a space in my println:
Syst em.out.println("Page title is: ");
This should create some kind of error somewhere, yes??
Where would I see it? I did have Build Automatically checked, tried unchecking, doing a clean, and it says that it will build after the clean, but I still see no error?? How do I get the errors to show?
Glenn
Re: how do I see compiler errors?? [message #831983 is a reply to message #831967] Thu, 29 March 2012 11:49 Go to previous messageGo to next message
What kind of project is the Java source in? If you are not working within a Java project the Java builder will not run on your source and no error markers will be created.
If you are working in a Java project, try opening the Problems View when your source is open in the Java editor and see if there is anything there.
Re: how do I see compiler errors?? [message #831988 is a reply to message #831983] Thu, 29 March 2012 11:58 Go to previous messageGo to next message
I'm pretty sure that I created a java project.. is there any way that I can verify?
Also, the Problems view is one of the bottom panes? (Along with Javadoc / declaration/ search and console?) If so, there is nothing listed: "0 items"
Sad
Re: how do I see compiler errors?? [message #832037 is a reply to message #831988] Thu, 29 March 2012 13:29 Go to previous messageGo to next message
OK, won't let me do links cause I'm under 25 msgs.. so I'll be editing them out..
I found the "Validate" option under the project, clicked it, and got the following in the Problem view:
Description Resource Path Location Type
cvc-complex-type.2.4.a: Invalid content was found starting with element 'pluginManagement'. One of ...:distributionManagement, "... maven.apache.org/POM/4.0.0":properties}' is expected. pom.xml /MySel20Proj line 16 XML Problem
Would you know if this means that I need a new build of maven?
Eclipse opened the pom file for me to highlight the error (and possibly correct it I guess .. red "X" next to "pluginManagement"), but I wouldn't know what to update.
Thanks for looking at this
Glenn
Re: how do I see compiler errors?? [message #832248 is a reply to message #831988] Thu, 29 March 2012 20:02 Go to previous messageGo to next message
> can verify?
Select project, right click ->Properties. The list of properties on the
left should include Java Build Path, Java Code Style, etc. Builders
section should have Java Builder.
> items"
Also make sure that your source code is in a source folder.
Properties->Java Build Path->Source tab.
You might want to check out the Java development user guide Basic
Tutorial. It explains what needs to be done for Java development.
Re: how do I see compiler errors?? [message #891935 is a reply to message #831967] Tue, 26 June 2012 11:57 Go to previous messageGo to next message
I had the same issue. The issue for me was my Java "Project Name" had spaces and a semicolon in the name. Renaming it worked.
Before: ICS; 2012-13
After: abcd
Worked when I renamed it to "abcd".
Re: how do I see compiler errors?? [message #891937 is a reply to message #831967] Tue, 26 June 2012 11:57 Go to previous message
After: abcd
Previous Topic:Eclipse proxy implementation, NTML
Next Topic:Eclipse program execution error
Current Time: Thu Jul 24 21:46:24 EDT 2025
Powered by FUDForum. Page generated in 0.29518 seconds
