Home » Archived » Test and Performance Tools Platform (TPTP) » No reuse of component identifications (CBE)?
No reuse of component identifications (CBE)? [message #83084] Mon, 11 September 2006 07:13 Go to next message
i developed a static Log Parser plugin. I tried to cash and reuse
component identifications for the CBEs but it doesn't work. Debugging of
the problem shows the following. In the case i reuse a component
identification (ci) in a new CBE the references of other CBEs on this ci
changes to null sometimes.
Is this the intended behavior to prevent reusing of ci?
Greetings
Holger
Re: No reuse of component identifications (CBE)? [message #83180 is a reply to message #83084] Tue, 12 September 2006 09:44 Go to previous message
Originally posted by: cindyjin.ca.ibm.com
HiHolger:
This is because that General Log Adapter(GLA)is using EMF based CBE
implementation to produce CBEs. In EMF model an object cannot be
reference by one or more containers. So when you reuse a
ComponentIdentification object, all other CBEs which has reference to
this ComponentIdentification are set the reference to null. You can use
CBE factory to generate ComponentIdentification and fill the component
ID with your cached information.
Cindy
Holger Machens wrote:
> Greetings
> Holger
Previous Topic:Monitoring agents using extended SampleClientAC via (NewTec)AgentController
Next Topic:Perfmon sample request
Current Time: Tue Jul 22 07:42:13 EDT 2025
Powered by FUDForum. Page generated in 0.07055 seconds
