Home » Eclipse Projects » Standard Widget Toolkit (SWT) » select collapsed item in TreeView
select collapsed item in TreeView [message #831715] Thu, 29 March 2012 04:42 Go to next message
Hi community,
I want to select and expand a special path from a collapsed item in a SWT TreeView. If the tree is expanded thus far that the items are visible the code below works. Otherwise not.
TreeViewer mbViewer = (TreeViewer) mbSelectionProvider;
mbViewer.expandToLevel(linkTarget, 1);
mbViewer.setSelection(new StructuredSelection(linkTarget), true);
mbViewer.getTree().showSelection();
Does anyone have the trick to get this work?
I have to state that linkTarget is from Type EObject and is a different class as the TreeItem. Since I tried to calculate the TreePath myself I did'nt get this work as I did not know how I could compare the TreeItem's to the linkTarget's type.
Thanks in advance
Re: select collapsed item in TreeView [message #831799 is a reply to message #831715] Thu, 29 March 2012 07:18 Go to previous messageGo to next message
You could try asking this in the Eclipse JFace forum.
Re: select collapsed item in TreeView [message #834823 is a reply to message #831715] Mon, 02 April 2012 08:50 Go to previous message
Well, I decided to calculate the TreePath instead. This does the job. Thanks anyway.
Previous Topic:How to add toolbar to a CTabItem
Next Topic:How to change row layout structure based on radio button in Eclipse SWT
Current Time: Sat Jul 26 10:30:09 EDT 2025
Powered by FUDForum. Page generated in 0.06293 seconds
