Re: Script Functions: how are Java objects handled in JS? [message #832213 is a reply to message #831733] |
Thu, 29 March 2012 18:46  |
Alexey,
That is correct. Here is the list of data type names.
package org.eclipse.birt.core.data;
import java.math.BigDecimal;
import java.sql.Blob;
import java.util.Date;
* Defines constants for BIRT data types
public abstract class DataType
public static final int UNKNOWN_TYPE = -1;
public static final int ANY_TYPE = 0;
public static final int BOOLEAN_TYPE = 1;
public static final int INTEGER_TYPE = 2;
public static final int DOUBLE_TYPE = 3;
public static final int DECIMAL_TYPE = 4;
public static final int STRING_TYPE = 5;
public static final int DATE_TYPE = 6;
public static final int BLOB_TYPE = 7;
public static final int BINARY_TYPE = 8;
public static final int SQL_DATE_TYPE = 9;
public static final int SQL_TIME_TYPE = 10;
public static final int JAVA_OBJECT_TYPE = 11;
private static final String[] names =
"Any",
"Boolean",
"Integer",
"Float",
"Decimal",
"String",
"DateTime",
"Blob",
"Binary",
"Date",
"Time",
"Java Object"
BTW you may be interested in :
http://www.informit.com/articles/article.aspx?p=1748986
http://birtworld.blogspot.com/2008/09/birt-231-adding-functions-to-expression.html
//aggregate extension
http://birtworld.blogspot.com/2010/10/birt-duplicate-rows.html
http://birtworld.blogspot.com/2006/09/optimistic-sums.html
Jason
On 3/29/2012 5:13 AM, Alexey Romanov wrote:
> Are they the same as
> http://help.eclipse.org/helios/index.jsp?topic=%2Forg.eclipse.birt.doc.isv%2Fcore%2Fapi%2Forg%2Feclipse%2Fbirt%2Fcore%2Fdata%2FDataType.html?
FUDForum. Page generated in 0.07170 seconds
