Jubula 1.1 extensions in 1.2 [message #831170] |
Wed, 28 March 2012 11:05  |
I have made some Extensions for Jubula 1.1. Now have updated Jubula to the neweset version 1.2 and pasted the extension in the jubula plugins folder again.
But now, Jubula does not recognize my extension.
So my question is:
Has something changed in 1.2 that might cause this behavior? Has something changed in the source code which influences the extension handling?
Tommy
Re: Jubula 1.1 extensions in 1.2 [message #834816 is a reply to message #831176] |
Mon, 02 April 2012 08:40   |
thanks for the answers. I tried the workaround of h ttp://bugzilla.bredex.de/337. But now I get errors, when I try to start Jubula. The line I added was com.subshell.jubula.extension.client,1.2.0.201204021413,plugins/com.subshell.jubula.extension.client_1.2.0.201204021413.jar,4,false, which is an extension for a rcp application.
Here is the log:
!SESSION 2012-04-02 14:33:02.158 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_18
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 4 0 2012-04-02 14:33:06.317
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (135).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.jubula.client.ui.rcp.Plugin.start() of bundle org.eclipse.jubula.client.ui.rcp.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:626)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:608)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:562)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:486)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:459)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:174)
at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:105)
at org.eclipse.ui.internal.Workbench$61.run(Workbench.java:2400)
at org.eclipse.ui.internal.Workbench.startSourceProviders(Workbench.java:2397)
at org.eclipse.ui.internal.Workbench.access$18(Workbench.java:2382)
at org.eclipse.ui.internal.Workbench$30.runWithException(Workbench.java:1567)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.jubula.app.Launcher.start(Launcher.java:347)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: org.eclipse.jubula.tools.exception.GDConfigXmlException: null : null
---- Debugging information ----
cause-exception : java.lang.reflect.UndeclaredThrowableException
cause-message : null
class : org.eclipse.jubula.tools.xml.businessmodell.CompSystem
required-type : org.eclipse.jubula.tools.xml.businessprocess.ConfigVersion
path : /compSystem/configVersion/majorCustomVersion
line number : 16
at org.eclipse.jubula.toolkit.common.xml.businessprocess.ComponentBuilder.getCompSystem(ComponentBuilder.java:197)
at org.eclipse.jubula.client.core.ClientTest.<init>(ClientTest.java:204)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.jubula.client.core.ClientTestFactory.getClientTest(ClientTestFactory.java:44)
at org.eclipse.jubula.client.ui.rcp.controllers.TestExecutionContributor.<init>(TestExecutionContributor.java:98)
at org.eclipse.jubula.client.ui.rcp.controllers.TestExecutionContributor.getInstance(TestExecutionContributor.java:783)
at org.eclipse.jubula.client.ui.rcp.Plugin.registerPermanentServices(Plugin.java:1036)
at org.eclipse.jubula.client.ui.rcp.Plugin.start(Plugin.java:1022)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 70 more
Root exception:
line number : 16
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.323
!MESSAGE Plug-in org.eclipse.jubula.client.inspector.ui was unable to load class org.eclipse.jubula.client.inspector.ui.provider.sourceprovider.InspectableAutSourceProvider.
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/jubula/client/ui/rcp/sourceprovider/AbstractJBSourceProvider
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (135).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 55 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jubula.client.ui.rcp.Plugin.start() of bundle org.eclipse.jubula.client.ui.rcp.
... 64 more
line number : 16
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.325
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.AutStateSourceProvider.
!STACK 0
... 64 more
line number : 16
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.326
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.AvailableAutSourceProvider.
!STACK 0
... 64 more
line number : 16
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.328
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.AutAgentStateSourceProvider.
!STACK 0
... 64 more
line number : 16
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.329
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.ActiveProjectSourceProvider.
!STACK 0
... 64 more
line number : 16
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.331
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.TestExecutionSourceProvider.
!STACK 0
at
Re: Jubula 1.1 extensions in 1.2 [message #998975 is a reply to message #835643] |
Thu, 10 January 2013 23:23  |
i have this error when i added the extended plugin, do anyone knows the reason
!SESSION 2013-01-11 12:19:12.629 -----------------------------------------------
java.version=1.6.0_33
!ENTRY org.eclipse.osgi 4 0 2013-01-11 12:19:18.947
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (145).
!STACK 0
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at org.eclipse.jubula.app.Launcher.start(Launcher.java:242)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.jubula.toolkit.common.xml.businessprocess.ComponentBuilder.getCompSystem(ComponentBuilder.java:195)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.jubula.client.ui.rcp.Plugin.registerPermanentServices(Plugin.java:1039)
at org.eclipse.jubula.client.ui.rcp.Plugin.start(Plugin.java:1025)
... 70 more
Root exception:
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.955
!STACK 0
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (145).
... 55 more
... 64 more
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.957
!STACK 0
... 64 more
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.958
!STACK 0
... 64 more
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.959
!STACK 0
... 64 more
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.960
!STACK 0
... 64 more
... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.961
!STACK 0
... 64 more
FUDForum. Page generated in 0.31915 seconds
