Home » Modeling » EMF » [Teneo] Parent/Child/Child cascade merging error
[Teneo] Parent/Child/Child cascade merging error [message #428238] Mon, 16 March 2009 04:40 Go to next message
Hello!
I have the following model:
public interface Colocation extends EObject {
* @model containment="true"
* annotation="teneo.jpa appinfo='@OneToMany(fetch=LAZY)'"
EList<Application> getApplication();
public interface Application extends EObject {
* extendedMetaData="kind='element' name='serviceGroup'"
* annotation="teneo.jpa appinfo='@OneToMany(fetch=EAGER)'"
EList<ServiceGroup> getServiceGroup();
public interface ServiceGroup extends EObject {
* @model
String getName();
and the following test case causes exception:
Colocation colo = new Colocation();
coloDao.saveColocation(colo);
sessionFactory.getCurrentSession().save(colo);
Application app = new Application();
colo.getApplication().add(app);
ServiceGroup sg = new ServiceGroup();
app.getServiceGroup().add(sg);
Application merged = (Application)
sessionFactory.getCurrentSession().merge(app);
Exception:
org.hibernate.TransientObjectException: object references an unsaved
transient instance - save the transient instance before flushing:
Application
at
org.hibernate.engine.ForeignKeys.getEntityIdentifierIfNotUns aved(ForeignKeys.java:219)
at
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType.getID(EContainerUserType.java:399)
at
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType.replace(EContainerUserType.java:393)
at
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType.replace(EContainerUserType.java:152)
at org.hibernate.type.AbstractType.replace(AbstractType.java:15 3)
at org.hibernate.type.TypeFactory.replace(TypeFactory.java:515)
at
org.hibernate.event.def.DefaultMergeEventListener.copyValues (DefaultMergeEventListener.java:377)
at
org.hibernate.event.def.DefaultMergeEventListener.entityIsTr ansient(DefaultMergeEventListener.java:179)
at
org.springframework.orm.hibernate3.support.IdTransferringMer geEventListener.entityIsTransient(IdTransferringMergeEventLi stener.java:58)
at
org.hibernate.event.def.DefaultMergeEventListener.onMerge(De faultMergeEventListener.java:123)
at org.hibernate.impl.SessionImpl.fireMerge(SessionImpl.java:68 7)
at org.hibernate.impl.SessionImpl.merge(SessionImpl.java:669)
at org.hibernate.engine.CascadingAction$6.cascade(CascadingActi on.java:245)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:268)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :216)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:16 9)
at org.hibernate.engine.Cascade.cascadeCollectionElements(Casca de.java:296)
at org.hibernate.engine.Cascade.cascadeCollection(Cascade.java: 242)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :219)
at org.hibernate.engine.Cascade.cascade(Cascade.java:130)
at
org.hibernate.event.def.AbstractSaveEventListener.cascadeAft erSave(AbstractSaveEventListener.java:456)
at
org.hibernate.event.def.DefaultMergeEventListener.entityIsTr ansient(DefaultMergeEventListener.java:194)
at
at
at
org.hibernate.event.def.DefaultMergeEventListener.onMerge(De faultMergeEventListener.java:53)
at org.hibernate.impl.SessionImpl.fireMerge(SessionImpl.java:67 7)
at org.hibernate.impl.SessionImpl.merge(SessionImpl.java:661)
at org.hibernate.impl.SessionImpl.merge(SessionImpl.java:665)
at
my.company.ColoCascadingTest.testFullColoSave(ColoCascadingT est.java:207)
at
It seems that the merge operation doesn't cascade when there are more
than one unsaved nesting children. The update operation works ok, and
when there only one unsaved child also all is ok.
Thank you,
Alexey
Re: [Teneo] Parent/Child/Child cascade merging error [message #428240 is a reply to message #428238] Mon, 16 March 2009 04:58 Go to previous messageGo to next message
Hi Alexey,
You showed the model, is it only part of the total model? Does your model have explicit id efeatures (to hold the
database id)?
Btw, as a workaround you can disable persisting econtainer relations through the following option:
PersistenceOptions.DISABLE_ECONTAINER_MAPPING (set it to false)
Persisting econtainer relations explicitly is only required when you load the children independently from their parent
and need to have correct econtainers set at thay point and in addition want to work with emf resources.
gr. Martin
koloale wrote:
> Hello!
> * @model
> String getName();
> Exception:
> Application
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thank you,
> Alexey
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Parent/Child/Child cascade merging error [message #428241 is a reply to message #428240] Mon, 16 March 2009 05:07 Go to previous messageGo to next message
Martin Taal wrote:
> Hi Alexey,
> model have explicit id efeatures (to hold the database id)?
Yes, I tried to simplify model and omitted maybe important details:
in all entities I have explicit id
* @model id="true"
Long getId();
> load the children independently from their parent and need to have
> emf resources.
Should it work without PersistenceOptions.DISABLE_ECONTAINER_MAPPING or
it is deliberate behavior?
Re: [Teneo] Parent/Child/Child cascade merging error [message #428242 is a reply to message #428241] Mon, 16 March 2009 05:13 Go to previous messageGo to next message
> * @model id="true"
> Long getId();
For Application and ServiceGroup I have sequence generated id:
* @model id="true"
* annotation="teneo.jpa appinfo='@Id
@GeneratedValue(strategy=SEQUENCE, generator=\"TypedEntityGen\")'"
* @generated
Long getId();
Re: [Teneo] Parent/Child/Child cascade merging error [message #428244 is a reply to message #428241] Mon, 16 March 2009 05:44 Go to previous messageGo to next message
Hi Alexey,
The exception is specifically related to the way Teneo stores econtainer relations. So disabling them should 'solve'
this error. The econtainer relation is stored in a special way because an object can have different types of containers.
So these are not stored in a standard hibernate way:
http://www.elver.org/hibernate/hibernate_relations.html#Stor ing+container+relation
Can you enter a bugzilla for this? I can check if I can enable cascade behavior over econtainer relations also.
Btw, I made a typo to disable econtainer mappings the value "true" should be set in the
PersistenceOptions.DISABLE_ECONTAINER_MAPPING option.
gr. Martin
koloale wrote:
> Martin Taal wrote:
>> Hi Alexey,
> * @model id="true"
> Long getId();
>> with emf resources.
The Netherlands
Re: [Teneo] Parent/Child/Child cascade merging error [message #830384 is a reply to message #428244] Tue, 27 March 2012 11:02 Go to previous messageGo to next message
Hi Martin, we are having the same problem with a graph of objects that we need to merge (some of them new objects, other existing dettached objects).
The transient object error seems to happend when the econtainer of a new object is another new object.
Is there any solution or workaround to this problem?
Disabling econtainer persistence is not an option in our case, since we need to query the objects in many of the levels of the graph, and need the econtainers to be setted.
Thanks in advance.
Pablo
Re: [Teneo] Parent/Child/Child cascade merging error [message #830413 is a reply to message #830384] Tue, 27 March 2012 11:32 Go to previous messageGo to next message
Hi Pablo,
First a workaround check :-), are the econtainer associations, explicitly modeled? If so then you can disable econtainer
persistence and use the explicitly modeled association.
gr. Martin
> The transient object error seems to happend when the econtainer of a new object is another new object. Is there any
> solution or workaround to this problem? Disabling econtainer persistence is not an option in our case, since we need to
> Thanks in advance.
> Pablo
The Netherlands
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Parent/Child/Child cascade merging error [message #830513 is a reply to message #830413] Tue, 27 March 2012 14:36 Go to previous messageGo to next message
Hi Martin, the econtainer associations aren´t modeled explicity, because we have many objects and the cost of mantaining the container associaciones would be quite heavy, so we intend to use the econtainer feature of EMF.
Thanks for the quick response,
Pablo
[Updated on: Tue, 27 March 2012 14:36] by Moderator
Re: [Teneo] Parent/Child/Child cascade merging error [message #830583 is a reply to message #830513] Tue, 27 March 2012 16:48 Go to previous messageGo to next message
I am afraid that it is quite difficult to get cascading to work over usertypes (used for storing the econtainer
relation). Would it work for you to do the cascade yourselve? You can easily transfer the econtainer associations and
merge/save the parent before the child.
gr. Martin
> Pablo
The Netherlands
Re: [Teneo] Parent/Child/Child cascade merging error [message #905028 is a reply to message #830583] Wed, 29 August 2012 11:13 Go to previous messageGo to next message
Hi Martin, we get into this error once again, with another part of our model. Last time, we do what you suggested, implement the cascade by ourselves, but this time, the graph of objects we are trying to merge with cascades is quite big to resolve the cascading by ourselves. Is there any solution, or tip we can follow to get to solve the cascading of merge over the econtainer usertype?
I leave a new fresh example to clarify the error:
Our model looks like this:
A <>--> B <>--> C (all the relations are containments with multiplicity 0..1)
Our code do this:
public void saveA(A a){
session.save(a);
public void saveBandC(A a, B b, C c){
b.setC(c);
a.setB(b);
session.merge(a);
In the method saveBandC we get a TransientObjectException, over object B.
The problem seems to be in the merge of object C, when hibernate tries to resolve the value of the econtainer reference (B). At this moment, the method getID of the EContainerUserType is invoked, and it finds out that B is Transient.
The stacktrace of the error is this:
javax.ejb.EJBException: org.hibernate.TransientObjectException: object references an unsaved transient instance - save the transient instance before flushing: B
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.handleExceptionInOurTx(CMTTxInterceptor.java:183)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:251)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.required(CMTTxInterceptor.java:349)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invoke(CMTTxInterceptor.java:209)
at org.jboss.ejb3.tx2.aop.CMTTxInterceptorWrapper.invoke(CMTTxInterceptorWrapper.java:52)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:182)
at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
at org.jboss.ejb3.core.context.CurrentInvocationContextInterceptor.invoke(CurrentInvocationContextInterceptor.java:47)
at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
at org.jboss.ejb3.interceptor.EJB3TCCLInterceptor.invoke(EJB3TCCLInterceptor.java:86)
at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:333)
at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:390)
at sun.reflect.GeneratedMethodAccessor570.invoke(Unknown Source)
at org.jboss.ejb3.proxy.impl.handler.session.SessionLocalProxyInvocationHandler$LocalContainerInvocation.invokeTarget(SessionLocalProxyInvocationHandler.java:184)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
at org.jboss.ejb3.async.impl.interceptor.AsynchronousClientInterceptor.invoke(AsynchronousClientInterceptor.java:143)
at org.jboss.ejb3.proxy.impl.handler.session.SessionLocalProxyInvocationHandler$LocalInvokableContextHandler.invoke(SessionLocalProxyInvocationHandler.java:159)
at $Proxy230.invoke(Unknown Source)
at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:185)
at $Proxy381.mergeEObjetoIdentificable(Unknown Source)
at uy.com.gecos.erpm.infrastructure.datamanager.objetosnegocio.tests.querys.TestQuerysObjetosNegocio.crearQueryYSalvarEspecificacionDuenia(TestQuerysObjetosNegocio.java:337)
at uy.com.gecos.erpm.infrastructure.datamanager.objetosnegocio.tests.querys.TestQuerysObjetosNegocio.test_create_query_and_execute_by_id(TestQuerysObjetosNegocio.java:350)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.jboss.arquillian.junit.Arquillian$6$1.invoke(Arquillian.java:270)
at org.jboss.arquillian.container.test.impl.execution.LocalTestExecuter.execute(LocalTestExecuter.java:60)
at org.jboss.arquillian.core.impl.ObserverImpl.invoke(ObserverImpl.java:90)
at org.jboss.arquillian.core.impl.EventContextImpl.invokeObservers(EventContextImpl.java:99)
at org.jboss.arquillian.core.impl.EventContextImpl.proceed(EventContextImpl.java:81)
at org.jboss.arquillian.core.impl.ManagerImpl.fire(ManagerImpl.java:135)
at org.jboss.arquillian.core.impl.ManagerImpl.fire(ManagerImpl.java:115)
at org.jboss.arquillian.core.impl.EventImpl.fire(EventImpl.java:67)
at org.jboss.arquillian.container.test.impl.execution.ContainerTestExecuter.execute(ContainerTestExecuter.java:38)
at org.jboss.arquillian.test.impl.TestContextHandler.createTestContext(TestContextHandler.java:89)
at org.jboss.arquillian.core.impl.EventContextImpl.proceed(EventContextImpl.java:88)
at org.jboss.arquillian.test.impl.TestContextHandler.createClassContext(TestContextHandler.java:75)
at org.jboss.arquillian.test.impl.TestContextHandler.createSuiteContext(TestContextHandler.java:60)
at org.jboss.arquillian.test.impl.EventTestRunnerAdaptor.test(EventTestRunnerAdaptor.java:111)
at org.jboss.arquillian.junit.Arquillian$6.evaluate(Arquillian.java:263)
at org.jboss.arquillian.junit.Arquillian$4.evaluate(Arquillian.java:226)
at org.jboss.arquillian.junit.Arquillian.multiExecute(Arquillian.java:314)
at org.jboss.arquillian.junit.Arquillian.access$100(Arquillian.java:46)
at org.jboss.arquillian.junit.Arquillian$5.evaluate(Arquillian.java:240)
at org.junit.runners.BlockJUnit4ClassRunner.runNotIgnored(BlockJUnit4ClassRunner.java:79)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:71)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:49)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at org.jboss.arquillian.junit.Arquillian$2.evaluate(Arquillian.java:185)
at org.jboss.arquillian.junit.Arquillian$3.evaluate(Arquillian.java:199)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.jboss.arquillian.junit.Arquillian.run(Arquillian.java:147)
at org.junit.runner.JUnitCore.run(JUnitCore.java:157)
at org.junit.runner.JUnitCore.run(JUnitCore.java:136)
at org.jboss.arquillian.junit.container.JUnitTestRunner.execute(JUnitTestRunner.java:65)
at org.jboss.arquillian.protocol.servlet.runner.ServletTestRunner.executeTest(ServletTestRunner.java:160)
at org.jboss.arquillian.protocol.servlet.runner.ServletTestRunner.execute(ServletTestRunner.java:126)
at org.jboss.arquillian.protocol.servlet.runner.ServletTestRunner.doGet(ServletTestRunner.java:90)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:734)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:847)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:324)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:242)
at org.jboss.weld.servlet.ConversationPropagationFilter.doFilter(ConversationPropagationFilter.java:67)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:274)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:275)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:161)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:181)
at org.jboss.modcluster.catalina.CatalinaContext$RequestListenerValve.event(CatalinaContext.java:285)
at org.jboss.modcluster.catalina.CatalinaContext$RequestListenerValve.invoke(CatalinaContext.java:261)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:88)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:100)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:159)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.jboss.web.tomcat.service.request.ActiveRequestResponseCacheValve.invoke(ActiveRequestResponseCacheValve.java:53)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:362)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:877)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:654)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:951)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.hibernate.TransientObjectException: object references an unsaved transient instance - save the transient instance before flushing: B
at org.hibernate.engine.ForeignKeys.getEntityIdentifierIfNotUnsaved(ForeignKeys.java:243)
at org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContainerUserType.getID(EContainerUserType.java:441)
at org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContainerUserType.replace(EContainerUserType.java:434)
at org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContainerUserType.replace(EContainerUserType.java:164)
at org.hibernate.type.AbstractType.replace(AbstractType.java:176)
at org.hibernate.type.TypeHelper.replace(TypeHelper.java:212)
at org.hibernate.event.def.DefaultMergeEventListener.copyValues(DefaultMergeEventListener.java:600)
at org.hibernate.event.def.DefaultMergeEventListener.mergeTransientEntity(DefaultMergeEventListener.java:337)
at org.hibernate.event.def.DefaultMergeEventListener.entityIsTransient(DefaultMergeEventListener.java:303)
at org.hibernate.event.def.DefaultMergeEventListener.onMerge(DefaultMergeEventListener.java:258)
at org.hibernate.impl.SessionImpl.fireMerge(SessionImpl.java:877)
at org.hibernate.impl.SessionImpl.merge(SessionImpl.java:859)
at org.hibernate.engine.CascadingAction$6.cascade(CascadingAction.java:279)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:392)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java:335)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:204)
at org.hibernate.engine.Cascade.cascade(Cascade.java:161)
at org.hibernate.event.def.AbstractSaveEventListener.cascadeBeforeSave(AbstractSaveEventListener.java:450)
at org.hibernate.event.def.DefaultMergeEventListener.mergeTransientEntity(DefaultMergeEventListener.java:336)
at org.hibernate.engine.Cascade.cascadeCollectionElements(Cascade.java:425)
at org.hibernate.engine.Cascade.cascadeCollection(Cascade.java:362)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java:338)
at org.hibernate.event.def.DefaultMergeEventListener.cascadeOnMerge(DefaultMergeEventListener.java:630)
at org.hibernate.event.def.DefaultMergeEventListener.entityIsDetached(DefaultMergeEventListener.java:490)
at org.hibernate.event.def.DefaultMergeEventListener.onMerge(DefaultMergeEventListener.java:255)
at org.hibernate.event.def.DefaultMergeEventListener.onMerge(DefaultMergeEventListener.java:84)
at org.hibernate.impl.SessionImpl.fireMerge(SessionImpl.java:867)
at org.hibernate.impl.SessionImpl.merge(SessionImpl.java:851)
at org.hibernate.impl.SessionImpl.merge(SessionImpl.java:855)
at uy.com.gecos.erpm.infrastructure.datamanager.diccionariodatos.metamodelo.persistence.DiccionarioDatosPersistenceManagerBean.mergeEObjetoIdentificable(DiccionarioDatosPersistenceManagerBean.java:147)
at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
at org.jboss.ejb3.interceptors.container.ContainerMethodInvocationWrapper.invokeNext(ContainerMethodInvocationWrapper.java:72)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor$InvocationContext.proceed(InvocationContextInterceptor.java:127)
at org.jboss.weld.integration.ejb.interceptor.Jsr299BindingsInterceptor.doMethodInterception(Jsr299BindingsInterceptor.java:151)
at org.jboss.weld.integration.ejb.interceptor.Jsr299BindingsInterceptor.doAroundInvoke(Jsr299BindingsInterceptor.java:122)
at sun.reflect.GeneratedMethodAccessor572.invoke(Unknown Source)
at org.jboss.ejb3.interceptors.aop.EJB3InterceptorInterceptor.invoke(EJB3InterceptorInterceptor.java:80)
at org.jboss.ejb3.interceptors.aop.EJB3InterceptorInterceptor.invoke(EJB3InterceptorInterceptor.java:71)
at org.jboss.ejb3.interceptors.container.ContainerMethodInvocationWrapper.invokeNext(ContainerMethodInvocationWrapper.java:62)
at org.jboss.weld.ejb.SessionBeanInterceptor.aroundInvoke(SessionBeanInterceptor.java:46)
at org.jboss.weld.integration.deployer.metadata.WeldLifecycleInterceptor.doAroundInvoke(WeldLifecycleInterceptor.java:55)
at sun.reflect.GeneratedMethodAccessor573.invoke(Unknown Source)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:76)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:62)
at sun.reflect.GeneratedMethodAccessor571.invoke(Unknown Source)
at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:74)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_19547591.invoke(InvocationContextInterceptor_z_fillMethod_19547591.java)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:90)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_19547591.invoke(InvocationContextInterceptor_z_setup_19547591.java)
at org.jboss.ejb3.async.impl.interceptor.AsynchronousServerInterceptor.invoke(AsynchronousServerInterceptor.java:128)
at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
at org.jboss.ejb3.core.context.SessionInvocationContextAdapter.proceed(SessionInvocationContextAdapter.java:95)
at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:247)
... 134 more
Thanks in advance.
Pablo
Re: [Teneo] Parent/Child/Child cascade merging error [message #905205 is a reply to message #905028] Wed, 29 August 2012 19:07 Go to previous message
Hi Pablo,
Have you tried to travers the container relations and merge/save manually in that order? So something like this:
public void save(EObject eObject) {
if (eObject == null) {
return;
save(eObject.eContainer());
// do the real persist of the object
getEntityManager().persist(eObject);
gr. Martin
> Our code do this:
> session.save(a);
> b.setC(c);
> a.setB(b);
> session.merge(a);
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 134 more
> Thanks in advance.
> Pablo
The Netherlands
Previous Topic:Adding classes to generated Package
Next Topic:Distinct ItemProvider for different view
Current Time: Sat Jul 26 17:00:00 EDT 2025
Powered by FUDForum. Page generated in 0.06628 seconds
