Re: Options in GMF Wizard [message #830363 is a reply to message #830301] |
Tue, 27 March 2012 10:33   |
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<meta http-equiv="Content-Style-Type" content="text/css">
<title></title>
<meta name="Generator" content="Cocoa HTML Writer">
<meta name="CocoaVersion" content="1038.36">
<style type="text/css">
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 15.0px; font: 12.0px Helvetica; color: #000000}
p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 15.0px; font: 12.0px Helvetica; color: #000000; min-height: 14.0px}
p.p3 {margin: 0.0px 0.0px 0.0px 12.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #021f8c}
p.p4 {margin: 0.0px 0.0px 0.0px 12.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #021f8c; min-height: 14.0px}
p.p5 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #000000; min-height: 14.0px}
p.p6 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 14.0px; font: 12.0px Helvetica; color: #000000}
p.p7 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 14.0px; font: 12.0px Helvetica; min-height: 14.0px}
p.p8 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 14.0px; font: 12.0px Helvetica}
</style>
</head>
<body>
<p class="p1">Hi Heinz,</p>
<p class="p2"><br></p>
<p class="p1">See comments below.</p>
<p class="p1">On 2012-03-27 15:05:44 +0200, Heinz Huber said:</p>
<p class="p3">Hi,</p>
<p class="p4"><br></p>
<p class="p3">i am trying to build a GMF on top of my xtext project.</p>
<p class="p3">I found the following instructions: http://www.kermeta.org/docs/fr.irisa.triskell.kermeta.samples.fsm.documentation/build/html.chunked/KerMeta-Create-FSM-Graphical-Editor-With-GMF/ch02.html</p>
<p class="p5"><br></p>
<p class="p6">You could and should start with the official tutorial <a href="http://wiki.eclipse.org/Graphical_Modeling_Framework/Tutorial/Part_1">http://wiki.eclipse.org/Graphical_Modeling_Framework/Tutorial/Part_1</a></p>
<p class="p6">If its the first time your try GMF its better to start with a very simple model, then you'll understand the basics, you could do the same with your xtext model.</p>
<p class="p3">Now i got some questions to the things i am inserting while the wizard.</p>
<p class="p3">1) The element which i mark in figure 2.10 is always the start rule of my xtext grammar?</p>
<p class="p7"><br></p>
<p class="p8">Here you should select the element that will contain all your graphical elements. In general its the root class of your metamodel, so that should correspond to your start rule.</p>
<p class="p3">2) What are the values of the checkboxes in figure 2.10 (Graphical Definition Model )? I mean the box, the line and the A. Please give me a short example too, because i couldn't get the system behind that thing. -> At the moment i marked elements which should be filled in in the editor with the A, elements which later be "boxes" in my editor with the box symbol. And the other ones which will have a connection to another element with the line element. But that doesn't work very well oO</p>
<p class="p8">This is where you say that a class should be represented as a box or as a connection (link between boxes). The A will be a label for your grahical element.</p>
<p class="p3">3)For what are the informations in figure 2.17? Is this the same like figure 2.10? Or has this information a different sense? Maybe you got an short example too for that. -> At the moment i filled in the information like i wrote at the end of question 2!</p>
<p class="p8">This is where you define the palette or creation tools. If you marked an element as box previously then the same here, its creation tool should be a box.</p>
<p class="p3">I tried working with this short instruction, but it doesn't work. After completing the generation progress i got my editor. But i could only insert the first element and not more. Also figure 2.19 looks very different to mine. I only got the start value of my xtext grammer and no other elements (which again leeds me to the idea, that i made mistakes on one of the questions above). Changing something in the "change .." button always produces a error which doesn't let me compile my project.</p>
<p class="p3">Hope, that someone of you got an idea to fix that. Maybe there is no way to fix that, because my bug is solved with correcting my code after getting the answer to my 3 questions.</p>
<p class="p3">Thanks in advance for your help! :)<span class="Apple-converted-space"> </span></p>
<p class="p6">BRs,</p>
<p class="p6">Guillaume</p>
</body>
</html>
Re: Options in GMF Wizard [message #830372 is a reply to message #830363] |
Tue, 27 March 2012 10:42   |
repost, previous had bad formatting.
Hi Heinz,
See comments below.
Definition Model )? I mean the >> box, the line and the A. Please give
the editor with the A, >> elements which later be "boxes" in my editor
well oO
grahical element.
got an short example too for that. -> At the moment i filled in >>
should be a box.
and no other elements (which again >> leeds me to the idea, that i
my project.
BRs,
Guillaume
FUDForum. Page generated in 0.04852 seconds
