Home » Archived » M2M (model-to-model transformation) » [ATL XSD EMF]: How to convert a xsd schema file to XMI formatted file
[ATL XSD EMF]: How to convert a xsd schema file to XMI formatted file [message #82986] Fri, 30 May 2008 10:15 Go to next message
Originally posted by: David-392.Li.MorganStanley.com
Hi all,
We have requiremnets to do xml schema conversion between xsd and XMI
formatted. The following code shows how we try to convert a xsd schema to
a XMI formatted file (which conforms to the XSD.ecore model), but the
result file seems not right. I am wondering where the problem is? Maybe
the way I am doing this is wrong? Is there any good way to do such
conversion? What I know is that the XSD package does not use XMI
serialization.
The code:
private static void xsd2xmi() throws IOException
ResourceSet metaResourceSet = new ResourceSetImpl();
metaResourceSet.getResourceFactoryRegistry().getExtensionToF actoryMap().put(
"xmi", new XMIResourceFactoryImpl());
"xsd", new XSDResourceFactoryImpl());
URI uriXsd = URI.createFileURI("C:/scheduleXsd.xsd");
Resource r = metaResourceSet.getResource(uriXsd, true);
r.load(null);
XSDSchema schema = null;
if ( r instanceof XSDResourceImpl) {
XSDResourceImpl rXSD = (XSDResourceImpl) r ;
schema = rXSD.getSchema();
URI uriXMI = URI.createFileURI("C:/scheduleXmi.xmi");
Resource rXMI = metaResourceSet.createResource(uriXMI);
rXMI.getContents().add(schema);
rXMI.save(null);
The scheduleXsd.xsd is;
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:tns=" http://xml.ms.com/ns/modex-models/atlPrototype-interop/v1_4/ schedule/v2_0"
targetNamespace=" http://xml.ms.com/ns/modex-models/atlPrototype-interop/v1_4/ schedule/v2_0"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xsd:complexType name="schedule">
<xsd:sequence>
<xsd:element name="scheduleId" type="xsd:string" minOccurs="0"/>
<xsd:element name="price" type="xsd:double" minOccurs="0"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
The output scheduleXmi.xmi is
<?xml version="1.0" encoding="ASCII"?>
<xsd:XSDSchema xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsd="http://www.eclipse.org/xsd/2002/XSD" element="[xsd:schema:
null]" document="[#document: null]"
schemaLocation=" file:/C:/p4shadow/m2m/atlPrototype-interop-v1_4-schedule-v2. xsd "
attributeFormDefault="unqualified" elementFormDefault="qualified"
typeDefinitions="//schedule;XSDComplexTypeDefinition">
<contents xsi:type="xsd:XSDComplexTypeDefinition"
element="[xsd:complexType: null]" name="schedule"
aliasName="schedule"
uRI=" http://xml.ms.com/ns/modex-models/atlPrototype-interop/v1_4/ schedule/v2_0#schedule"
aliasURI=" http://xml.ms.com/ns/modex-models/atlPrototype-interop/v1_4/ schedule/v2_0#schedule"
qName="tns:schedule" contentTypeCategory="elementOnly"
contentType="//schedule;XSDComplexTypeDefinition/XSDParticle ">
<baseTypeDefinition xsi:type="xsd:XSDComplexTypeDefinition"
href=" jar:file:/C:/dev/tools/eclipseide/3.3prod/eclipse/plugins/or g.eclipse.xsd_2.3.1.v200709252135.jar!/cache/www.w3.org/2001 /XMLSchema.xsd#//anyType;XSDComplexTypeDefinition=27 "/>
<content xsi:type="xsd:XSDParticle" element="[xsd:sequence: null]"
term=" //schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p ">
<content xsi:type="xsd:XSDModelGroup" element="[xsd:sequence: null]"
compositor="sequence"
particles=" //schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p/XSDParticle
//schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p/XSDParticle=1 ">
<contents element="[xsd:element: null]" minOccurs="0"
term=" //schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p/XSDParticle/scheduleId;XSDElementDeclaration ">
<content xsi:type="xsd:XSDElementDeclaration"
element="[xsd:element: null]" name="scheduleId"
aliasName="scheduleId"
uRI=" http://xml.ms.com/ns/modex-models/atlPrototype-interop/v1_4/ schedule/v2_0#scheduleId"
aliasURI=" http://xml.ms.com/ns/modex-models/atlPrototype-interop/v1_4/ schedule/v2_0#scheduleId"
qName="tns:scheduleId"
resolvedElementDeclaration=" //schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p/XSDParticle/scheduleId;XSDElementDeclaration "
substitutionGroup=" //schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p/XSDParticle/scheduleId;XSDElementDeclaration ">
<typeDefinition xsi:type="xsd:XSDSimpleTypeDefinition"
href=" jar:file:/C:/dev/tools/eclipseide/3.3prod/eclipse/plugins/or g.eclipse.xsd_2.3.1.v200709252135.jar!/cache/www.w3.org/2001 /XMLSchema.xsd#//string;XSDSimpleTypeDefinition=7 "/>
</content>
</contents>
term=" //schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p/XSDParticle=1/price;XSDElementDeclaration ">
element="[xsd:element: null]" name="price"
aliasName="price"
uRI=" http://xml.ms.com/ns/modex-models/atlPrototype-interop/v1_4/ schedule/v2_0#price"
aliasURI=" http://xml.ms.com/ns/modex-models/atlPrototype-interop/v1_4/ schedule/v2_0#price"
qName="tns:price"
resolvedElementDeclaration=" //schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p/XSDParticle=1/price;XSDElementDeclaration "
substitutionGroup=" //schedule;XSDComplexTypeDefinition/XSDParticle/XSDModelGrou p/XSDParticle=1/price;XSDElementDeclaration ">
href=" jar:file:/C:/dev/tools/eclipseide/3.3prod/eclipse/plugins/or g.eclipse.xsd_2.3.1.v200709252135.jar!/cache/www.w3.org/2001 /XMLSchema.xsd#//double;XSDSimpleTypeDefinition=10 "/>
</content>
</contents>
</content>
</content>
</contents>
<attributeDeclarations
href=" jar:file:/C:/dev/tools/eclipseide/3.3prod/eclipse/plugins/or g.eclipse.xsd_2.3.1.v200709252135.jar!/cache/www.w3.org/2001 /XMLSchema-instance.xsd#//nil;XSDAttributeDeclaration=1 "/>
href=" jar:file:/C:/dev/tools/eclipseide/3.3prod/eclipse/plugins/or g.eclipse.xsd_2.3.1.v200709252135.jar!/cache/www.w3.org/2001 /XMLSchema-instance.xsd#//noNamespaceSchemaLocation;XSDAttri buteDeclaration=3 "/>
href=" jar:file:/C:/dev/tools/eclipseide/3.3prod/eclipse/plugins/or g.eclipse.xsd_2.3.1.v200709252135.jar!/cache/www.w3.org/2001 /XMLSchema-instance.xsd#//schemaLocation;XSDAttributeDeclara tion=2 "/>
href=" jar:file:/C:/dev/tools/eclipseide/3.3prod/eclipse/plugins/or g.eclipse.xsd_2.3.1.v200709252135.jar!/cache/www.w3.org/2001 /XMLSchema-instance.xsd#//type;XSDAttributeDeclaration "/>
</xsd:XSDSchema>
Thanks for any help and suggestion.
Re: [ATL XSD EMF]: How to convert a xsd schema file to XMI formatted file [message #83016 is a reply to message #82986] Fri, 30 May 2008 10:42 Go to previous message
David,
This is related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=166638. There are no
plans to support this because it's a hard problem to solve (and resource
is lacking). Things like includes (including Chameleon ones) and
imports drive the process of deriving the abstract model from the
concrete syntax of the standard serialization. We'd need to carefully
visit all the features defined in the XSD model to mark things that
shouldn't be serialized as transient and derived.
David wrote:
> Hi all,
> to a XMI formatted file (which conforms to the XSD.ecore model), but
> the result file seems not right. I am wondering where the problem is?
> Maybe the way I am doing this is wrong? Is there any good way to do
> such conversion? What I know is that the XSD package does not use XMI
> serialization.
> The code:
> private static void xsd2xmi() throws IOException {
> r.load(null);
> rXMI.save(null);
> <xsd:sequence>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> The output scheduleXmi.xmi is ---
> null]" compositor="sequence"
> </content>
> </contents>
> aliasName="price"
> qName="tns:price"
> </content>
> </contents>
> </content>
> </content>
> </contents>
> </xsd:XSDSchema>
Previous Topic:ATL: reserved keyword name clash
Next Topic:[QVTO] Iteration over collection
Current Time: Fri Jul 18 17:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.06966 seconds
