Manual linking [message #829756] |
Mon, 26 March 2012 14:40  |
Hello again,
I am stuck again, I hope someone can set me on track... again...
I defined the grammar with simple ID fields, exported the ecore model, edited it to add real references for each id and imported it in my xtext grammar. I overrode the linker and I can set these references to point at the objects with the qualified name specified by the corresponding id.
In my naivety, I thought that this would be enough for the xtext runtime to give me full support as for links defined in the grammar with []. Either I was wrong and it's impossible or there are some other things that have to be put in place before that.
I tried to get inspiration from gepetto, but there's so much going on there that I can't tell what is important for this use case and what not, and more importantly I can't tell how the IDE support for links created manually is enabled.
Please point me in the right direction!
best regards,
Vlad
Re: Manual linking [message #829907 is a reply to message #829756] |
Mon, 26 March 2012 20:14   |
On 2012-26-03 20:41, Vlad Dumitrescu wrote:
> Hello again,
If there are no [ ] type references in the grammar, then naturally
nothing gets generated automatically for those, and you have to provide
all such functionality yourself.
What linking does (in addition to assigning a reference) is to find the
referenced elements (looking them up in an index), and keeping track of
these references to enable reacting to change and rebuilding.
There is a bunch of small things to deal with. I am happy to answer
question about Geppetto - but can't really give you a clear "hear is how
to do it" description. (+ some of the things I did early on are probably
done the way they are because I did not know better then).
- henrik
Re: Manual linking [message #830259 is a reply to message #829907] |
Tue, 27 March 2012 07:53  |
Thank you, Henrik. After a lot of thinking, I think I understand why just linking is not enough. I will have to give it even more thought, hopefully xtext works in my use case.
best regards,
Vlad
FUDForum. Page generated in 0.04426 seconds
