Home » Modeling » eTrice » no option for 'Empty eTrice Java Project'
no option for 'Empty eTrice Java Project' [message #829648] Mon, 26 March 2012 11:43 Go to next message
Hi everyone, (It seems that the message got corped somehow. Nevertheless, i am reposting it)
I have installed eTrice in Eclipse-3.7(Indigo) by extracting the download-able zip file in the dropins folder. I am facing the following problems with eTrice installation:
1. Unlike the representation in the Documentation, the File --> New --> Projects.. menu does 'not' show a separate category for 'eTrice'. Rather the entries are being displayed in the 'Others' category.
2. Even in 'Others' category, there is no option for 'Empty eTrice Java Project'.
3. While "Setting Up The Workspace" (following the instructions exactly), there are 4 warnings instead of just 1, as shown in the Documentation.
4. Moreover, the 'Run as' entry in the context menu of the "gen_org.eclipse.etrice.tutorials.launch" in the Package Explorer does not show any options for running the application(unlike the Documentation again).
I have already installed the following plugins in Eclipse : EMF, Xtext, Graphiti, Xpand, Xbase
I will be really grateful if you could help me to find out why am i getting this problem. I am completely new to eTrice.
Thanks in advance. Regards,
Jayant
[Updated on: Mon, 26 March 2012 12:02] by Moderator
Re: no option for 'Empty eTrice Java Project' [message #829675 is a reply to message #829648] Mon, 26 March 2012 12:18 Go to previous messageGo to next message
Hi Jayant,
you shouldn't extract the zip archive into the dropins folder.
Start Eclipse and use the p2 installer. The installer is able to determine required packages and install them too.
Go to Help > Install new Software...
and add the zip archive as local site (or use directly the eTrice update site).
Alternatively you can drag the Install button in the introduction of the eTrice home page
http://eclipse.org/etrice/
and drop it on your running Indigo installation (e.g. on the tool bar).
HTH,
Henrik
Am 26.03.2012 17:43, schrieb Jayant Gupta:
> Hi everyone,
> Documentation.
Re: no option for 'Empty eTrice Java Project' [message #829804 is a reply to message #829675] Mon, 26 March 2012 16:15 Go to previous message
Hi Henrik,
I am grateful to you for such a quick reply.
Your method worked pefectly fine after i corrected my proxy settings(i had enabled socks which was creating problems)
Thankyou very much for helping me.
Kindly regards,
Jayant
[Updated on: Mon, 26 March 2012 16:26] by Moderator
Previous Topic:importURI semantics
Next Topic:eTrice 0.2.0M2 published
Current Time: Sun Jul 20 21:25:10 EDT 2025
Powered by FUDForum. Page generated in 0.26717 seconds
