Home » Archived » BIRT » Bar chart with multiple axis
Bar chart with multiple axis [message #829632] |
Mon, 26 March 2012 11:23  |
Hi everybody,
I want to create a birt bar chart having:
- a category x axis (example: product name)
- two data series (example: number of purchases and total € amount)
If I use a single y axis and choose "side by side" , the two series are displayed correctly, but not very readable because the two series have different value ranges (example: 0-100 for series1, 0-100.000 for series2).
So I need to use multiple y axis.
Here comes the problem: in the multiple axis mode, the bars belonging to the two data series are no more side by side, but overlapped.
What can I do to have them side by side again?
Re: Bar chart with multiple axis [message #835717 is a reply to message #834663] |
Tue, 03 April 2012 11:33  |
I do not think 2.3.2 had this feature, but you can check the xml view
and do a search for <SideBySide> in the chart xml.
Jason
On 4/2/2012 4:25 AM, ing omini wrote:
> Unfortunately in my version (2.3.2.r232) the only options available
> under axis tab are:
> - visible
> - type
> - color
> "aligned" and "side by side" options are not available in the GUI
> is there any workaround to achieve the same effect?
> Thanks again!
Current Time: Sun Jul 27 14:38:05 EDT 2025
Powered by FUDForum. Page generated in 0.27033 seconds
