Home » Archived » BIRT » Aggregation problem(can't get aggregation to show up)
Aggregation problem [message #829612] Mon, 26 March 2012 10:53 Go to next message
So I am trying to aggregate one of my columns and for some reason or another it doesn't show up on the report footer.
1. I added "Aggregation" from the Quick Tools menu
2. I selected SUM as the report function
3. The expression is a column binding: parseInt(row["Amount"])
(the column is String numbers, that's why I have to use parseInt)
4. I have a filter that says ignore row values that contain "*****".
(The stars in used in place of null values in the report)
Seems quick and easy. I am using the BIRT Field Guide as my reference and I don't think I missed anything.
Any ideas on what to check?
Re: Aggregation problem [message #829729 is a reply to message #829612] Mon, 26 March 2012 13:52 Go to previous message
Never mind on this one. I unmounted my jump drive and mounted it again and now everything work. Proof that this is a Monday....
Previous Topic:Scatter Charts facilities - full freedom?
Next Topic:set Data Source from your java code
Current Time: Sun Jul 20 23:27:51 EDT 2025
Powered by FUDForum. Page generated in 0.03031 seconds
