[ATL] exporting plugin doesn't work [message #82832] |
Fri, 30 May 2008 04:34  |
Originally posted by: r.c.ladan.tue.nl
I tried to export the latest CVS version (2008-05-30) as a plugin (individual files), but it fails with this message:
Problems during export
C:\Documents and Settings\rladan\workspace\.metadata\.plugins\org.eclipse.pde .core\temp\org.eclipse.pde.container.feature\build.xml:119: The following error occurred while executing this line:
C:\Documents and Settings\rladan\workspace\.metadata\.plugins\org.eclipse.pde .core\temp\org.eclipse.pde.container.feature\build.xml:20: The following error occurred while executing this line:
C:\Documents and Settings\rladan\workspace\org.eclipse.m2m.atl.doc\build.xml: 67: Execute failed: java.io.IOException: Cannot run program "sh" (in directory "C:\Documents and Settings\rladan\workspace\org.eclipse.m2m.atl.doc"): CreateProcess error=2, The system cannot find the file specified
I included the following projects:
org.eclipse.m2m.atl
org.eclipse.m2m.atl-feature
org.eclipse.m2m.atl.doc-feature
org.eclipse.m2m.atl.drivers.mdr4atl-feature
org.eclipse.m2m.atl.examples-feature
org.eclipse.m2m.atl.sdk-feature
org.eclipse.m2m.atl.tests-feature
org.antlr.runtime
org.eclipse.m2m.atl.adt.builder
org.eclipse.m2m.atl.adt.debug
org.eclipse.m2m.atl.adt.editor
org.eclipse.m2m.atl.adt.perspective
org.eclipse.m2m.atl.adt.wizard
org.eclipse.m2m.atl.compilers.atl2006
org.eclipse.m2m.atl.drivers.emf4atl
org.eclipse.m2m.atl.drivers.uml24atl
org.eclipse.m2m.atl.engine
org.eclipse.m2m.atl.engine.emfvm
org.eclipse.m2m.atl.engine.vm
org.eclipse.m2m.atl.ocl.core
org.eclipse.m2m.atl.service.core
org.eclipse.m2m.atl.tests was excluded, because it contains build errors (missing EMF plugin?) :
Bundle 'org.eclipse.emf.compare.diff' cannot be resolved
Bundle 'org.eclipse.emf.compare.match' cannot be resolved
Rene
Re: [ATL] exporting plugin doesn't work [message #82867 is a reply to message #82832] |
Fri, 30 May 2008 04:46   |
The doc plugin uses an external script to export itself, in order to
build the Javadoc. That's why you encounter this error.
So to correctly export the plugins the best thing is to avoid the doc
plugin.
William
Rene Ladan a écrit :
> C:\Documents and
> C:\Documents and
> C:\Documents and
> C:\Documents and
> C:\Documents and
> C:\Documents and
> C:\Documents and
> C:\Documents and
> C:\Documents and
> C:\Documents and
> org.eclipse.m2m.atl
> org.antlr.runtime
> Regards,
> Rene
Re: [ATL] exporting plugin doesn't work [message #82956 is a reply to message #82867] |
Fri, 30 May 2008 10:09  |
William Piers wrote:
> Hello,
> plugin.
Thanks, it works now.
Rene
> Best regards,
> William
>> Hi,
>> C:\Documents and
>> C:\Documents and
>> C:\Documents and
>> C:\Documents and
>> C:\Documents and
>> C:\Documents and
>> C:\Documents and
>> C:\Documents and
>> C:\Documents and
>> C:\Documents and
>> org.eclipse.m2m.atl
>> org.antlr.runtime
>> Regards,
>> Rene
FUDForum. Page generated in 0.51375 seconds
