EMFT examples and eclipse 3.2.2 [message #82791] |
Thu, 10 May 2007 15:14  |
Originally posted by: asma.charfi.com
Is the examples of EMFT validation and ocl interpreter example works with
Eclipse 3.2.2 ?
I installed EMFT (ocl,validation,query transaction) using the (software
updates_install new feature)in help menu after installing EMF 2.2.2
I also insatalled all the examples but when I validates models that did not
respect OCL constraints, the validation works normally!
is there any configuration which is not mention it in the exemples (i even
tried to run examples archives but i have the same problem)
thank you for helping me
Re: EMFT examples and eclipse 3.2.2 [message #83122 is a reply to message #82842] |
Fri, 11 May 2007 03:39  |
hi Merks,
I did not ask the same question that I asked in the ocl group: (here I speak
about EMFT tutorial ) and when I said that validation works normally I mean
that I did not recieve an error message that I have to recieve.
thank you for your advice (asking to OCL group)
"Ed Merks" <merks@ca.ibm.com> a
Re: EMFT examples and eclipse 3.2.2 [message #606652 is a reply to message #82791] |
Thu, 10 May 2007 06:41  |
Asma,
You already have a thread started in the OCL and EMF newsgroups about
this question. You're claiming below that things work normally. Is
that really your intent of the opposite of it? In any case, if there
are problems with OCL validation examples, it's best to ask about them
in the OCL newsgroup. Explain exactly what you tried and which specific
example isn't working.
> Eclipse 3.2.2 ?
Re: EMFT examples and eclipse 3.2.2 [message #606671 is a reply to message #82842] |
hi Merks,
FUDForum. Page generated in 0.04905 seconds
