Home » Archived » M2M (model-to-model transformation) » [ATL]: Value from Stereotype's Property
[ATL]: Value from Stereotype's Property [message #82559] |
Wed, 28 May 2008 09:17  |
Originally posted by: amehmood.sophia.inria.fr
Hi All,
I m trying to access the property value of a stereotype applied to a
class. for this i use the getValue function of the uml::Element :
java.lang.Object getValue(Stereotype stereotype, java.lang.String
propertyName)
Retrieves the value of the property with the specified name in the
specified stereotype for this element.
Parameters:
stereotype - The stereotype for which to retrieve the value.
propertyName - The name of the property whose value to retrieve.
The output I am getting is in the form of java Object. How can i convert
it to a string? How can i use it. I have tried to write the following
helper to get its value using the toString() function but in vain.
helper context UML2!"uml::Element" def : getTagValue(sName : String, pName
: String ) : String =
self.getValue(self.getAppliedStereotype(sName),pName).toStri ng();
Can anyone kindly solve this mystery... This will also help many others in
the future.
-aamir-
Re: [ATL]: Value from Stereotype's Property [message #82636 is a reply to message #82589] |
Thu, 29 May 2008 04:19   |
Hello Aamir,
Last week, I have done the same thing, the helper I use is :
helper context UML!Element def: getVal(stname : String, pname : String)
: String =
self.getValue(self.getAppliedStereotype(stname), pname);
And It works fine, I did not have to put any ".toString".
Hope it helps.
Guillaume
Aamir a écrit :
> Well I tried this coding also:
> pName : String ) : String =
> self.getValue(self.getAppliedStereotypes() -> select(e | e.name =
> sName).first(), pName).name;
> In this, the way to get the stereotype is changed. its implemented by
> Ivano for the ports, but for my case of Classes, its not working.!!!
> Aamir
Re: [ATL]: Value from Stereotype's Property [message #82818 is a reply to message #82713] |
Fri, 30 May 2008 04:22   |
Hi Rasha,
I use Papyrus too.
In my sample transformation I don't have the IN_profile parameter, it
seems not to be usefull, in my case it works with something like :
" create OUT : UML2 from IN : UML2; "
but I think it is not very important :)
I think your problems comme from the way you specify the name of your
stereotype. You must use the full name of it. So you must have something
like :
" s.getVal('YourTestProfileName::MyStereotype', 'myProperty') "
Hope this helps,
Guillaume.
> Hi Guillaume,
> I used this helper in a simple example as followed
> module SampleUMLProfile2Problem_2; -- Module Template
> create OUT : UML2 from IN : UML2, IN_profile : UML2;
> helper context UML2!Element def: getVal(stname : String, pname : String)
> : String =
> rule Copyclass{
> from
> s : UML2!Class (s.getVal('MyStereotype','myProperty')= 'value1')
> to t : UML2!Class( name <- s.name
> It gives me an error, whether I specify the compiler or not. The inputs
> are uml files produced by Papyrus. Do you use the same UML tool?
> at
> org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModelElement.real Invoke(ASMUMLModelElement.java:624)
> at
> org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModelElement.invo ke(ASMUMLModelElement.java:581)
> at
> org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
> at
> org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
> at
> org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
> at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke
> Any hint is greatly appreciated,
> Rasha
Re: [ATL]: Value from Stereotype's Property [message #83073 is a reply to message #82818] |
Fri, 30 May 2008 21:06  |
Thanks Guillaume & Rasha,
I solved the issue that was bothering me. Actually what i have noitced
important is that the getValue function to get the value of an attribute
on the stereotype returns an 'Object':
-- Get the value from the Property of the Stereotype.
sName).first(), pName);
so, if the attribute in the stereotype is of type string, u can directly
retrieve it with the above code, hence the java object placeholder is
string in this case. but, as i have seen in an example by Ivano, if the
stereotype's attribute has the enumeration type then he uses .name at
the end to get the value. This was what Rasha once used in one of her
codes, and from there my confusions started.
anyways, if anyone thinks i m wrong plz do inform me. It will be really
appreciating.
Have a Nice day,
-aamir jadoon-
INRIA, France.
Guillaume Doux wrote:
> Hi Rasha,
> I use Papyrus too.
> like :
> Hope this helps,
> Guillaume.
>> Hi Guillaume,
>> String) : String =
>> rule Copyclass{
>> from
>> inputs are uml files produced by Papyrus. Do you use the same UML tool?
>> at
>> at
>> at
>> at
>> at
>> Rasha
Current Time: Thu Jul 24 21:18:16 EDT 2025
Powered by FUDForum. Page generated in 0.04933 seconds
