Home » Archived » BIRT » var OR dynamic data set OR??(Variable Text in Chart and Table Report)
var OR dynamic data set OR?? [message #827131] Thu, 22 March 2012 19:35 Go to next message
I am very new to BIRT and not sure how best to tackle what I need to do.
I need to take values entered in client and pass them to the server and subsequently the BIRT report.
I'm using a POJO:
public List<ReportRecord> getReportValues(String reportStartTime,
String reportEndTime)
List<ReportRecord> record = new ArrayList<ReportRecord>();
for (int i = 0; i < record.size(); i++)
ReportRecord reportRecord = new ReportRecord();
reportRecord.setReportStartTime(reportStartTime);
reportRecord.setReportEndTime(reportEndTime);
record.add(reportRecord);
return record;
My open script:
importPackage(Packages.com.reports.server);
count = 0;
// Create instance of
// the class
reportParams = new Packages.com.reports.server.ReportServiceImpl();
//Load the List
userParams = reportParams.getReportValues("Java", "Java");
My fetch:
if (count < userParams.size() )
var rtnString = userParams.get(count).getReportStart();
dataSetRow["Start Time:"] = rtnString;
var rtnStrng = userParams.get(count).getReportEndTime
dataSetRow["End Time:"] = rtnString;
count++;
return true;
return false;
My values make it to the server (tomcat) fine. However, the default value "Java" show up for both variable. Just to mention this, I am using two different data sets for the same report.
What am I missing?
Re: var OR dynamic data set OR?? [message #827622 is a reply to message #827131] Fri, 23 March 2012 11:26 Go to previous messageGo to next message
After a little more reading, I'm using the beforeOpen script for my var:
count = 0;
// the class
//Load the List
userParams = reportParams.getReportValues("Java");
count++;
return true;
return false;
However, the var data is still not being passed to the report.
Any ideas?
Thanks!
Re: var OR dynamic data set OR?? [message #827626 is a reply to message #827622] Fri, 23 March 2012 11:32 Go to previous messageGo to next message
Just a bit more about instance of BIRT:
BIRT Engine ver 3.7.2 is installed in a servlet
Re: var OR dynamic data set OR?? [message #827746 is a reply to message #827131] Fri, 23 March 2012 14:47 Go to previous messageGo to next message
The fetch method is only called once per data set row. Generally you
set up an iterator in the open and use the iterator in the fetch. In
your case is userParams one row of data or multiple rows?
Jason
On 3/22/2012 7:35 PM, Kris Tannar wrote:
> I'm using a POJO:
> public List<ReportRecord> getReportValues(String reportStartTime, String
> reportEndTime)
> return record;
> My open script:
> count = 0;
> // the class
> //Load the List
> My fetch:
> dataSetRow["End Time:"] = rtnString; count++;
> return true;
> return false;
> What am I missing?
Re: var OR dynamic data set OR?? [message #827754 is a reply to message #827622] Fri, 23 March 2012 14:56 Go to previous messageGo to next message
Move this to the open:
Then in the fetch use:
var rowdata = userParams.get(count);
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/fetchevents.txt", true ) );
out.println( "row data " + rowdata);
out.println( "firstCol " + rowdata.getReportStart());
out.close();
var rtnString = rowdata.getReportStart();
var rtnStrng = rowdata.getReportEndTime
count++;
return true;
return false;
Then take a look at the text file that is generated.
Jason
> count = 0;
> // the class
> //Load the List
> count++;
> return true;
> return false;
> Any ideas?
> Thanks!
Re: var OR dynamic data set OR?? [message #827849 is a reply to message #827754] Fri, 23 March 2012 17:49 Go to previous messageGo to next message
Hi Jason,
Thanks for the response.
userParams will be multiple rows of data.
In the open script:
userParams = reportParams.getReportValues("Java", "Java", "Java");
Which matches the method signature.
the fetch script:
out.println( "firstCol " + rowdata.getReportStartTime());
out.println( "secordCol " + rowdata.getReportEndTime());
out.println( "thirdCol " + rowdata.getEndUser());
out.close();
var rtnString = rowdata.getEndUser();
dataSetRow["End User:"] = rtnString;
var rtnString = rowdata.getReportStartTime();
var rtnStrng = rowdata.getReportEndTime();
count++;
return true;
return false;
When I examine the out file all cols have "Java" as the value. The output on the report shows "Java" as well.
I am using two different data sets to populate the same report; could that be an issue?
Thanks for your time.
Re: var OR dynamic data set OR?? [message #829616 is a reply to message #827849] Mon, 26 March 2012 10:57 Go to previous messageGo to next message
Hi Jason,
Went through another iteration making the changes you suggested; please see the open and fetch scripts below:
open:
count = 0;
// Service class
//Load the List
fetch:
out = new PrintWriter( new FileWriter( "c:/temp/Newfetchevents.txt", true ) );
out.println( "firstCol " + rowdata.getEndUser());
out.println( "secondCol " + rowdata.getReportStartTime());
out.println( "ThirdCol " + rowdata.getReportEndTime());
out.close();
var rtnString = rowdata.getReportEndTime();
count++;
return true;
return false;
However, I receive a BIRT error:
"Can't find method com.reports.server.ReportServiceImpl.getReportValues(string)" from the open script.
This is understandable because the method signature in the script does not match the getReportValues(string, string string) signature.
Can't seem to build my scripts properly to retrieve data from the user, place it into the report design at run time.
What am I missing?
Any help would be super appreciated!!
Re: var OR dynamic data set OR?? [message #830743 is a reply to message #829616] Tue, 27 March 2012 22:26 Go to previous message
What do you get when you change:
to
Jason
On 3/26/2012 10:57 AM, Kris Tannar wrote:
> Hi Jason,
> open:
> count = 0;
> // Service class
> //Load the List
> fetch:
> true ) );
> out.close();
> count++;
> return true;
> return false;
> "Can't find method
> open script.
> place it into the report design at run time. What am I missing?
Previous Topic:Using jQuery UI in a report
Next Topic:out of memory error
Current Time: Sat Jul 26 10:42:45 EDT 2025
Powered by FUDForum. Page generated in 0.31066 seconds
