Home » Eclipse Projects » GEF » [Zest] Recursively nested Elements
[Zest] Recursively nested Elements [message #827531] Fri, 23 March 2012 09:03 Go to next message
Hi all,
first of all I was really astonished how easy graphs can be described
with Zest.
I have one Question. Is there a way to nest Graphelements recursively?
I was able to get elements drawn into a container by making my
ContentProvider implement INestedContentProvider. However I wasn't able
to nest elements deeper that one level because the Framework doesn't
consider the ContentProvider, when children of a container are created.
What am I doing wrong?
Thanks in advance
Veit
Re: [Zest] Recursively nested Elements [message #827621 is a reply to message #827531] Fri, 23 March 2012 11:25 Go to previous messageGo to next message
As of now, nested content providers does not support recursively nested graph elements.
When using the SWT API, you could add new nodes inside other nodes, as shown in the nested graph snippet: http://git.eclipse.org/c/gef/org.eclipse.zest.git/tree/org.eclipse.zest.examples/src/org/eclipse/zest/examples/swt/NestedGraphSnippet.java
Zoltan Ujhelyi
Re: [Zest] Recursively nested Elements [message #827639 is a reply to message #827621] Fri, 23 March 2012 11:50 Go to previous messageGo to next message
Hi Zoltan,
thanks for the quick response.
I will try another way to to express my structure then.
Cheers
Veit
p.s. Thanks for pointing me to the snippet anyhow. I wasn't aware of
CompositeLayouts too ;)
Am 23.03.2012 16:25, schrieb Zoltan Ujhelyi:
> graph elements.
> Zoltan Ujhelyi
Re: [Zest] Recursively nested Elements [message #827640 is a reply to message #827621] Fri, 23 March 2012 11:50 Go to previous messageGo to next message
Hi Zoltan,
Cheers
Veit
> graph elements.
> Zoltan Ujhelyi
Re: [Zest] Recursively nested Elements [message #827642 is a reply to message #827640] Fri, 23 March 2012 11:53 Go to previous message
Be careful with the snippet. I opened the Zest 2.0 version; if you are using 1.x, some adaptation might be required.
Zoltán Ujhelyi
Previous Topic:Need Help to apply Search Filter in GEF palette
Next Topic:Coorindate of the left Corner of the ClientArea
Current Time: Fri Jul 18 23:47:20 EDT 2025
Powered by FUDForum. Page generated in 0.06569 seconds
