Home » Archived » BIRT » Is it possible to check if parameter allows null at rendering time?
Is it possible to check if parameter allows null at rendering time? [message #827530] Fri, 23 March 2012 09:06 Go to next message
I want to show a checkbox in a report if a certain parameter allows null values. From IGetParameterDefinitionTask I can get IParameterDefnBase or ParameterHandle, but neither seems to include the data I need. Is there a way to access it?
Re: Is it possible to check if parameter allows null at rendering time? [message #827539 is a reply to message #827530] Fri, 23 March 2012 09:23 Go to previous messageGo to next message
Oh right, I can just check if IParameterDefnBase is an IScalarParameterDefn and cast it. But why is IScalarParameterDefn.allowNull() deprecated?
Re: Is it possible to check if parameter allows null at rendering time? [message #827762 is a reply to message #827539] Fri, 23 March 2012 15:07 Go to previous messageGo to next message
I believe it was deprecated in favor of using:
* @return whether the parameter is required.<br>
* the rule for String type is:
* <li>isRequired=true, allowNull and allowBlank are false</li>
* <li>isRequired=false, allowNull and allowBlank are true</li>
* <br>
* for other type like integer:
boolean isRequired( );
Jason
Re: Is it possible to check if parameter allows null at rendering time? [message #827811 is a reply to message #827762] Fri, 23 March 2012 16:38 Go to previous message
I thought there were 3 different checkboxes for "allow null", "allow blank" and "is required" in parameter editor. Will need to recheck after the weekend.
Previous Topic:Data Sets and SQL Views
Next Topic:Hide empty yaxix series legend
Current Time: Wed Jul 23 21:36:10 EDT 2025
Powered by FUDForum. Page generated in 0.13140 seconds
