Home » Eclipse Projects » Equinox » Eclipse RCP with OSGi Service - Service not Starting(Service not starting (includes small example app))
Eclipse RCP with OSGi Service - Service not Starting [message #826590] Thu, 22 March 2012 05:01 Go to next message
hi,
i noticed that in my application my OSGi services are not starting up.
therefore i created a small application to test why. but i was not able to find out why.
you can Download the tiny OSGi Sample Application here
it constists of an Application, an OSGi Service (Interface and Impl) and a view Plugin, which tries to access the OSGi Service.
i hope someone of you can point me to my mistake
thanks in advance
[Updated on: Thu, 22 March 2012 05:01] by Moderator
Re: Eclipse RCP with OSGi Service [message #826626 is a reply to message #826590] Thu, 22 March 2012 05:54 Go to previous messageGo to next message
So you are trying to use DS?
You are missing the following information in your
lumo.osgi.service.notification.impls MANIFEST.MF:
* Service-Component: OSGI-INF/NotificationService.
* Bundle-ActivationPolicy: lazy
Please also make sure that you have DS in your launch config!
Tom
Am 22.03.12 10:01, schrieb Ludwig Moser:
> hi,
> to find out why.
> you can http://www.biooffice.at/tl_files/java/OSGi-Example.zip
> thanks in advance
Re: Eclipse RCP with OSGi Service [message #826647 is a reply to message #826626] Thu, 22 March 2012 06:31 Go to previous messageGo to next message
thanks (in my original code i do have the service-component included)
but why do i need Bundle-ActivationPolicy: lazy
makes no sense to me, as i want it activated immediately (which is done when its set to lazy...)
thanks a lot for this hint - it works now (both in my example and in the normal app!)
Re: Eclipse RCP with OSGi Service [message #826652 is a reply to message #826647] Thu, 22 March 2012 06:41 Go to previous messageGo to next message
err - i was too fast - its stil not working when exported.
EDIT: a build file was corrupted... so finally its fixed - thanks
[Updated on: Thu, 22 March 2012 07:10] by Moderator
Re: Eclipse RCP with OSGi Service [message #826675 is a reply to message #826652] Thu, 22 March 2012 07:18 Go to previous messageGo to next message
Are your build.properties correct?
Tom
Am 22.03.12 11:41, schrieb Ludwig Moser:
Re: Eclipse RCP with OSGi Service [message #826676 is a reply to message #826647] Thu, 22 March 2012 07:19 Go to previous messageGo to next message
Am 22.03.12 11:31, schrieb Ludwig Moser:
This equinox specific. Tom Watson has explained it once to me but I
can't remember.
Tom
Re: Eclipse RCP with OSGi Service [message #826682 is a reply to message #826647] Thu, 22 March 2012 07:24 Go to previous messageGo to next message
Ludwig Moser wrote on Thu, 22 March 2012 06:31
If you use DS a lot or are creating eclipse plugins as opposed to bundles, the lazy flag just tells equinox that it doesn't have to activate your bundle until the first time another bundle tries to load a class. ex: if you provide a service via DS and no one ever asks for it, your bundle won't be activated.
If you're in an OSGi application and you start all of your bundles yourself, it probably doesn't do anything for you.
PW
Re: Eclipse RCP with OSGi Service [message #826749 is a reply to message #826682] Thu, 22 March 2012 09:05 Go to previous messageGo to next message
I don't think this is fully correct - lazy activation is REQUIRED when
you use DS - but Tom Watson can prove me wrong on this naturally. IIRC
it has something to do with backwards compat, ....
Tom
Am 22.03.12 12:24, schrieb Paul Webster:
> PW
Re: Eclipse RCP with OSGi Service [message #826783 is a reply to message #826749] Thu, 22 March 2012 09:58 Go to previous messageGo to next message
i had one of my build properties fucked up (no clue why - linebreak and custom text in it?!?)
should never happen ;D
DS & Lazy Avctivation (was: Re: Eclipse RCP with OSGi Service) [message #827332 is a reply to message #826749] Fri, 23 March 2012 03:11 Go to previous message
Am 22.03.2012 14:05, schrieb Tom Schindl:
> you use DS
DS in Equinox works as any other thing in OSGi. It's only fully
functional once any involved bundle (the DS implementation, the DS
provider as well as the DS consumer) is ACTIVE. Until that point it's
not fully functional. For example, it may discover your components and
the components may be fully satisfiable but they are not activated
because the DS framework does not load the component class because the
bundle is not ACTIVE. (*[1]) Here is when Bundle-ActivationPolicy: lazy
comes into play. It allows the DS framework to auto-start the bundle in
order to load the component class.
[1]: Note, in OSGi classes from a RESOLVED bundle can be loaded. Thus, I
think its the DS implementation that puts the additional ACTIVE
constraint onto that model.
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
http://wagenknecht.org/
Previous Topic:Control based authorization in eclipse RCP
Next Topic:Download page legend
Current Time: Sat Jul 26 18:44:16 EDT 2025
Powered by FUDForum. Page generated in 0.05378 seconds
