Re: Papyrus 0.8.2-SR2-RC4 MANIFEST.MF file error [message #871326 is a reply to message #826578] |
Fri, 11 May 2012 20:16   |
Camille Letavernier wrote on Thu, 22 March 2012 04:43Hello,
The source jar only contains the Java files.
All resources (Models, Manifest, ...) are contained in the Binary jar.
The "Import Plug-ins and Fragments" menu in Eclipse works fine for importing source files with all required resources (However, I think you need to install Papyrus from the downloaded update site first).
Thanks Camille.
When I did 'Import Plug-ins and Fragments' only with binary jar files,
I could run Papyrus as a runtime-application, but I didn't have any source.
But when I did 'Import Plug-ins and Fragments' with source jar files together with binary jar files,
I could get source files which have hundreds of build errors.
For example, many plug-ins contains unusual folder like 'custom-src', 'src-gen',
and uses those folders as build path, which doesn't match with binary jar files.
And a lot of Manifest.MF file show error like 'org.eclipse.papyrus.core not resolved' although there is no error in Dependency tab.
I tried both SR2_RC4 (2012/02/15) and N201204301213 (2012/04/30),
I couldn't build from the source.
What I want is to build Papyrus from the source to study how it works, not just install and use it. ^^
I spent over a month to solve this problem, but I couldn't get the answer.
Please help me out..
FUDForum. Page generated in 1.10266 seconds
