Home » Eclipse Projects » Eclipse Platform » jspEditor plugin for eclipse from strecl crashes eclipse
jspEditor plugin for eclipse from strecl crashes eclipse [message #82551] Wed, 25 June 2003 16:18 Go to next message
Originally posted by: mongoloid001.netscape.net
I like that plugin, but it crashes eclipse all the time. And strecl is not
supporting them anymore, I wonder if anyone got it to work with eclipse. Or
there is a similar plugin out there. I am using Crimson editor right now,
but it sucks for jsp tags.
Thanks!
!ENTRY org.eclipse.ui 4 4 Jun 06, 2003 14:55:34.41
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Jun 06, 2003 14:55:34.41
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2332)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:101)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1815)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1549)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.ui 4 4 Jun 06, 2003 14:55:34.51
!MESSAGE
*** Stack trace of contained exception ***
!ENTRY org.eclipse.ui 4 0 Jun 06, 2003 14:55:34.51
!MESSAGE java.lang.NullPointerException
!STACK 0
at com.strecl.jsp.internal.ui.editors.e.a(Unknown Source)
at com.strecl.jsp.internal.ui.editors.JspEditor$3.selectionChan ged(Unknown
Source)
at com.strecl.jsp.internal.ui.editors.JspEditor$a.if(Unknown Source)
at com.strecl.jsp.internal.ui.editors.JspEditor$2.run(Unknown Source)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:98)
at
a:845)
at
at
..java:25)
Re: jspEditor plugin for eclipse from strecl crashes eclipse [message #82631 is a reply to message #82551] Wed, 25 June 2003 17:17 Go to previous messageGo to next message
why not take a few minutes an fix it?
> Thanks!
Re: jspEditor plugin for eclipse from strecl crashes eclipse [message #82642 is a reply to message #82551] Wed, 25 June 2003 17:20 Go to previous messageGo to next message
Give MyEclipse Enterprise Workbench a try. It has a very good JSP/HTML
editor with many new features being released on a monthly basis. Key JSP
features included in the EA2 release are:
- native jsp breakpoints and debugging (very similar to Java breakpoints)
- code completion for jsp, scriplet, custom tags, and html
- auto inclusion of jsp import statements
- JSP validate on save identifies errors before deployment
- rich syntax coloring schemes
- html preview capability (jsp coming in a few days)
- format preferences for soft/hard tabs, indentation levels, upper/lower
case of tags, ...
- wizards for JSP, HTML, servlet creation
www.myeclipseide.com
Note MyEclipse feature set is driven by user demand. If you don't find what
you want post it to one of their forums.
Wayne
MyEclipse Team
"Mongo" <mongoloid001@netscape.net> wrote in message
news:bdd02s$r5d$1@rogue.oti.com...
Or
> Thanks!
> !STACK 0
> at
> at
> a:845)
> at
> at
> .java:25)
> !MESSAGE
> !STACK 0
> at
> Source)
> at
> at
> a:845)
> at
> at
> .java:25)
Re: jspEditor plugin for eclipse from strecl crashes eclipse [message #84131 is a reply to message #82631] Fri, 27 June 2003 13:37 Go to previous messageGo to next message
Because it's supposed to be a tool. I wanna use 'tools' to fix 'other
things'. Don't wanna spend time on fixing 'tools'. 'Other things' are more
important than the 'tools'. If one tool doesn't work, I use another tool.
That was the purpose of my question.
"Christian Sell" <cse@dynabean.de> wrote in message
news:bdd3ho$um5$1@rogue.oti.com...
not
Or
now,
> > Thanks!
Re: jspEditor plugin for eclipse from strecl crashes eclipse [message #84144 is a reply to message #82642] Fri, 27 June 2003 13:38 Go to previous message
Thanks! I will give it a try.
"Wayne Parrott" <wayne@genuitec.com> wrote in message
news:bdd3ul$v41$1@rogue.oti.com...
> case of tags, ...
what
> Wayne
> MyEclipse Team
not
> Or
now,
> > Thanks!
> > !STACK 0
> > at
> > at
> > a:845)
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> > .java:25)
> > !MESSAGE
> > !STACK 0
> > at
> > Source)
> > at
> > at
> > a:845)
> > at
> > at
> > .java:25)
Previous Topic:Problem Exporting Jar file - classpath?
Next Topic:CVS crashes Eclipse 2.1 under Linux
Current Time: Tue Jul 22 01:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.93975 seconds
