Initialize papyrus diagram from an UML file [message #819764] |
Tue, 13 March 2012 05:52  |
when I right click on a .uml file, I haven't the context item "Initialize papyrus diagram".
How to initialize a papyrus diagram from an UML file?
Thank you.
I use Papyrus 0.8.2 on Eclipse 3.7.1.
[Updated on: Tue, 13 March 2012 06:12] by Moderator
Re: Initialize papyrus diagram from an UML file [message #843902 is a reply to message #843598] |
Fri, 13 April 2012 09:33   |
ah ok, thank you
but... I didn't consider UML2Tools because it is discontinued, isn't it?
I continued trying and I found a workaround:
If you are in the package explorer and select your UML file, and right-click it, go to new -> Papyrus Model. Select UML, and in my case I want to work with class diagrams.
After that, the new .di is open, and you can go to Model Explorer view, and there you have all the elements of the UML model. As I told you I want to work with class diagrams, so I created one, and then DnD classes to it.
I am still testing it ... but it seems that it works.
I am using the night build of a couple of days ago
Hope it helps, and I hope it works every day even better
Re: Initialize papyrus diagram from an UML file [message #1059313 is a reply to message #1059177] |
Fri, 17 May 2013 09:35  |
Thank for your reply. There exist six command in the filters shortcut menu, including three commands related to connector label and the other three related to content and compartment. the configuration to these options is nothing to do with the problem mentioned before. I wonder whether the need mentioned before by me could be realized by papyrus.
FUDForum. Page generated in 0.10042 seconds
