Same named element in 2 different xsd [message #82580] |
Tue, 08 May 2007 10:35  |
Hi Martin,
I have the same named element "ParentTree" in 2 different xsds eg
navigation.xsd and topology.xsd. Navigation.xsd reference topology.xsd. So
when I try a datastore.initialize, teneo finds the same eClass in
"ParentTree" in navigation and topology. Is there a way around this? Can I
redirect one of the ParentTree to point to a different table in the
database without explicitly changing the xsd?
Julia
Re: Same named element in 2 different xsd [message #82700 is a reply to message #82649] |
Wed, 09 May 2007 08:17  |
Hi Martin,
May be at some stage teneo can implement some extension point so that
one can set these options in Window -> Preferences... for teneo.
Parvez
Martin Taal wrote:
> Hi Julia,
> I would assume that they are conceptually different (as they are
> modelled each as their own type).
> So in this case they would need different tables.
> To solve the duplicate eclass name issue (when generating the jdo file)
> the best is to set the following property
> PersistenceOptions.QUALIFY_ENTITY_NAME
> to
> PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX);
> This property must be set to generate the jdo file. However passing
> properties can not be done for the right-click menu-generate-jdo option.
> You have to generate the jdo file programmatically. This is not
> difficult, just make a class with a static main method in your model
> project and call the following method:
> JpoxHelper.INSTANCE.generateMapping(your_epackages, options)
> this will return the jdo file.
> gr. Martin
> Julia wrote:
>> Hi Martin,
>> Actually, it's the same named element and structure in both xsds but
>> will hold different data. Would I not need 2 different tables in the
>> datastore? Would changing the table="ParentTree" to
>> table="ParentTree_nav" in package.jdo for one of the xsds work? It's
>> probably a hack :-). Would following the links you provided work in
>> this case?
>> Julia
Re: Same named element in 2 different xsd [message #606632 is a reply to message #82580] |
Tue, 08 May 2007 14:39  |
Hi Julia,
If the problem is that both eclasses are stored in the same table then you can use an
@Table(name="myname") annotation on the eclass to control were it is stored. You can set this
annotation in the xsd, the ecore or in a separate xml file.
See here for some extra info:
http://www.elver.org/jpox/ejb3_features.html
http://www.elver.org/jpox/ejb3_format.html
http://www.elver.org/jpox/ejb3_examples.html
gr. Martin
Julia wrote:
> Hi Martin,
> So when I try a datastore.initialize, teneo finds the same eClass in
> I redirect one of the ParentTree to point to a different table in the
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Same named element in 2 different xsd [message #606633 is a reply to message #82628] |
Tue, 08 May 2007 17:34  |
Hi Martin,
Actually, it's the same named element and structure in both xsds but will
hold different data. Would I not need 2 different tables in the datastore?
Would changing the table="ParentTree" to table="ParentTree_nav" in
package.jdo for one of the xsds work? It's probably a hack :-). Would
following the links you provided work in this case?
Julia
Re: Same named element in 2 different xsd [message #606634 is a reply to message #82639] |
Wed, 09 May 2007 01:03  |
Hi Julia,
I would assume that they are conceptually different (as they are modelled each as their own type).
To solve the duplicate eclass name issue (when generating the jdo file) the best is to set the
following property
to
This property must be set to generate the jdo file. However passing properties can not be done for
the right-click menu-generate-jdo option. You have to generate the jdo file programmatically. This
is not difficult, just make a class with a static main method in your model project and call the
following method:
gr. Martin
Julia wrote:
> Hi Martin,
> probably a hack :-). Would following the links you provided work in this
> case?
> Julia
The Netherlands
Re: Same named element in 2 different xsd [message #606639 is a reply to message #82649] |
Hi Martin,
Parvez
Martin Taal wrote:
> Hi Julia,
> to
> gr. Martin
> Julia wrote:
>> Hi Martin,
>> this case?
>> Julia
FUDForum. Page generated in 0.05735 seconds
