Home » Eclipse Projects » EclipseLink » Some Discriminator Values cause problem, while others do not(Error with some values in the @DiscriminatorColumn column, but not others)
Some Discriminator Values cause problem, while others do not [message #820175] Tue, 13 March 2012 16:29 Go to next message
I get the following message for only one value of the discriminator column in my inheritance structure. "Exception Description: Missing class for indicator field value [01ce19bf-46ca-11e1-9fb5-00059a3c7a00] of type [class java.lang.String]."
The problem only occurs when I include rows for the Summary class (the indicator value above). When I remove those rows from the table, the code works.
The discriminator column is a CHAR(36), but there are never any spaces. So, I don't think that's the problem.
I have a Mapped Superclass "Activity" that divides into two entities using TABLE_PER_CLASS strategy. Each of the tables "Performance" and "Plan" then further divide using "SINGLE_TABLE" strategy. The Plan table is subclassed as shown below.
Activity <-- Performance
Activity <-- Plan
Activity <-- Plan <-- Project
Activity <-- Plan <-- Project <-- Opportunity
Activity <-- Plan <-- Summary
Activity <-- Plan <-- WorkItem
Activity <-- Plan <-- WorkItem <-- Calendar
Activity <-- Plan <-- WorkItem <-- Task
Activity <-- Plan <-- WorkItem <-- Travel
The only thing that is possibly unique to the Summary class is it doesn't have any additional attributes/columns from Plan.
I've attached a file with the Plan table definition and the class definitions for Activity, Plan, Project, WorkItem and Summary. Setter/Getter methods and constructors have been removed to shorten the file.
Any help is appreciated greatly!!!!!!!!
Versions:
JPA: EclipseLink 2.2
DB: MySQL 5.5
System: Windows 7-64bit
Java: 1.6.0_25
IDE: NetBeans IDE 7.0.1
Re: Some Discriminator Values cause problem, while others do not [message #825207 is a reply to message #820175] Tue, 20 March 2012 11:52 Go to previous messageGo to next message
I'm not sure that you can change the inheritance type in subclasses, so that could be the root of your issue.
You also cannot use @Inheritance in a @MappedSuperclass, so that doesn't make sense.
Also the @DiscriminatorColumn, @Table and @Inheritance can only be given in the root entity.
If this is working at all, my guess is that the @Inheritance in the @MappedSuperclass is being ignored.
Check that the indicator is correct in Summary, looks like you may have typed it in wrong.
Re: Some Discriminator Values cause problem, while others do not [message #825517 is a reply to message #825207] Tue, 20 March 2012 19:39 Go to previous messageGo to next message
Thank you for the advice on @MappedSuperclass and @Inheritance. I had found references that said EclipseLink supports mixed inheritance, but I can't find the reference again.
I have checked and rechecked the value of the discriminator column; even copying the value from the log into the java code.
I also tried adding a column/attribute unique to the Summary class, but that hasn't changed the behavior at all.
So far, I am still getting the same exception ([EclipseLink-43])
As an alternative, can anyone tell me where to put a try-catch block, so I can handle this exception gracefully, rather than have it crash my application?
Re: [UPDATE] Some Discriminator Values cause problem, while others do not [message #826977 is a reply to message #825517] Thu, 22 March 2012 14:41 Go to previous messageGo to next message
I tried the following with the indicated results:
Change: Created new class, "ActivityGroup" to replace "Summary", including changing the Discriminator value.
Result: Same problem resulted for the rows that should have been allocated to the "ActivityGroup"
Change: Restored the "Summary" class. Changed the values for the underlying data rows to match the discriminator value for the "Plan" class. ("Plan" is the parent class of "Summary")
Result: This corrected the problem. For now, this is a viable workaround.
From the above, it would seem that the problem is in the "Summary" class definition. It's code is provided below.
package org.pims.data;
import java.sql.Date;
import javax.persistence.DiscriminatorValue;
import javax.persistence.Entity;
 * @author mlooman
 * @version 0.0
 * CHANGES:
 *  Date          Version      Description
 *  Mar 22, 2012   0.0         Initial Implementation
@Entity
@DiscriminatorValue("cc113aa4-742d-11e1-b5f9-00059a3c7a00")
public class Summary extends Plan {
  //<editor-fold defaultstate="collapsed" desc="Constructors"
  public Summary(){
    super();
    public Summary(String entityIdentifier){
    super(entityIdentifier);
  public Summary(String entityIdentifier, int planNumber, int activitySequenceInParentOrdinal, String planCurrentState, String planCurrentReason, Date planCreationTimestamp) {
    super(entityIdentifier, planNumber, activitySequenceInParentOrdinal, planCurrentState, planCurrentReason, planCreationTimestamp);
  //</editor-fold>
Re: [UPDATE] Some Discriminator Values cause problem, while others do not [message #827635 is a reply to message #826977] Fri, 23 March 2012 11:45 Go to previous message
Try adding a field to the Plan table and map it only in Summary to see if the problem goes away. If it does, file a bug with a simple test case so it can be looked into further and fixed.
Previous Topic:RESOLVED: retrieving some fields from an Entity
Next Topic:Persistence.getPersistenceUtil
Current Time: Sun Jul 27 11:29:37 EDT 2025
Powered by FUDForum. Page generated in 0.19875 seconds
