| Contributing to GEF Context menu [message #82079] |
Wed, 04 June 2003 17:19  |
Originally posted by: schmerl+gef.cs.cmu.edu
I'm trying to work out how to use plugin extensions to add contributions to
the context menu that comes up in the GEF diagram. Is this possible? If so,
could someone direct me to the documentation to do it?
So far, I've tried the objectContribution extension, using edit parts as the
objectClass, and also the class of the editor that registers the context
menu, to no avail.
Any help much appreciated,
Bradley.
P.S. This is what I've tried so far:
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
id="myId"
objectClass="org.eclipse.gef.editparts.AbstractGraphicalEditPart ">
</objectContribution>
</extension>
<viewerContribution id="myId"
targetID="org.eclipse.gef.examples.logicdesigner.LogicEditor ">
</viewerContribution>
</extension>
| Re: Contributing to GEF Context menu [message #902906 is a reply to message #899755] |
Tue, 21 August 2012 01:22  |
In my editor, I created tree edit part. In that modelChildren method, i override as following
getModelChildren()
List result = new ArrayList();
result.add(component1);
result.add(component2);
return result;
my problem is, when i add shapes in editor in following order
component2 - 1
component1 - 1
component2 - 2
component1 - 2
but in my tree view it exist as follows
component1 - 1
component1 - 2
component2 - 1
component2 - 2
Kindly suggest any solution for this.
Thanks & Regards,
Karthikeyan.B
FUDForum. Page generated in 0.05976 seconds
