Home » Eclipse Projects » Eclipse Platform » Common Navigator - over-ride double-click behaviour
Common Navigator - over-ride double-click behaviour [message #765081] Tue, 13 December 2011 06:31 Go to next message
in my Common Navigator class implementation I can use GetCommonViewer to get the CommonViewer class but I can't remove any of the double-click listeners as there's no getListeners method.
I can easily add a new double-click listener but I want to totally replace the double-click listeners that already exist as I don't always want the nodes of my tree to expand when I double-click.
How can I do this?
Any ideas?
Mark.
Re: Common Navigator - over-ride double-click behaviour [message #765769 is a reply to message #765081] Wed, 14 December 2011 11:43 Go to previous messageGo to next message
I need to do the same thing and have not implemented or tried what I'm about to suggest but this is the course of action I will be taking:
In your org.eclipse.ui.navigator.viewer extension viewerActionBinding remove org.eclipsze.ui.navigator.resources.* (actionExtension) and put in the individual actionProviders that you want from org.eclipse.ui.navigator.resources (i.e. GotoActionProvider, GoIntoActionProvider, etc.) but do not include OpenActionProvider instead create your own OpenActionProvider.
[Updated on: Wed, 14 December 2011 11:45] by Moderator
Re: Common Navigator - over-ride double-click behaviour [message #767024 is a reply to message #765769] Fri, 16 December 2011 16:57 Go to previous messageGo to next message
Awesome thanks for that- a really good approach- I'll give it a go asap
Ta
Mark
Re: Common Navigator - over-ride double-click behaviour [message #825143 is a reply to message #767024] Tue, 20 March 2012 10:23 Go to previous messageGo to next message
hmm, no that's not it at all. The OpenAction just controls the options in the context menus.
Re: Common Navigator - over-ride double-click behaviour [message #825152 is a reply to message #825143] Tue, 20 March 2012 10:37 Go to previous message
Got it, Common Navigator has:
protected void handleDoubleClick(DoubleClickEvent anEvent) {
just override in your CommonNavigator class.
Previous Topic:Problems with installing software into eclipse based program
Next Topic:Why ErrorDialog is not showing exception's stack trace from IStatus?
Current Time: Thu Jul 24 22:11:38 EDT 2025
Powered by FUDForum. Page generated in 0.04468 seconds
