Home » Archived » M2M (model-to-model transformation) » [QVTO] Iteration over collection
[QVTO] Iteration over collection [message #82474] |
Wed, 28 May 2008 06:59  |
I am evaluating QVTO. I want to transform a UML model with different
elements (Class,Subclass, Activity, Statemachine elements) into another
UML model.
The hierarchical structure of the source model should be remained.
Therefore I want to iterate over "ownedElement" Collection of UML::Model.
Unfortunately I don't know how to iterate correctly.
The command "forEach" seems to be unimplemented,yet.
So I tried with "iterate". But it has some syntax errors I can't resolve.
The error message is "")" misplaced construct(s)" which points to the
first if condition.
This is my code snippet :
modeltype UML uses "http://www.eclipse.org/uml2/2.1.0/UML";
transformation uml2uml(in model : UML, out model1 : UML);
main() {
var models := model.objects()[Model];
models.map umlmodel();
mapping UML::Model::umlmodel(): UML::Model {
ownedElement:=self.ownedElement->iterate (el; ini: Set(UML::Element){}|
if (el.oclIsTypeOf(UML::Class))
then
{select(oclIsTypeOf(UML::Class))->collect(oclAsType(UML::Class))- >map
Class2ClassTrans()->asSet();
}--end of then
endif;
if (el.oclIsTypeOf(UML::UML::Activity)).....
endif;
);--end of iterate
Thanks in advance for any suggestions !
Deepak
Re: [QVTO] Iteration over collection [message #82488 is a reply to message #82474] |
Wed, 28 May 2008 08:12   |
Hi Deepak,
You are right forEach is not implemented yet.
Also, it would not help you much as it executes a block of expressions b=
ut =
returns null.
There is a couple of issues I can see in your code snippet.
1)
iterate (el; ini: Set(UML::Element){}| --> self.ownedElement->iterate =
(el; ini: Set(UML::Element) =3D Set{} |
2) missing source object of the call to select
select(oclIsTypeOf(UML::Class))->collect(oclAsType(UML::Class))- >map =
3) 'ownedElement' property is not changeable, derived
4) as in iterate a block of expressions is not supported, you may exctra=
ct =
them into a helper operation
However, I suggest you to follow the style like bellow and guess it woul=
d =
satisfy your
usecase.
nestedPackage +=3D self.ownedElement[Package]->map toPackage();
ownedType :=3D self.ownedElement[Class]->map toClass()->asSet();
If you need any further help do not hesitate to post a question.
/Radek
On Wed, 28 May 2008 12:59:49 +0200, Deepak <dee_n@gmx.de> wrote:
> Hello,
> I am evaluating QVTO. I want to transform a UML model with different =
> elements (Class,Subclass, Activity, Statemachine elements) into anothe=
r =
> UML model.
> Therefore I want to iterate over "ownedElement" Collection of UML::Mod=
el.
> So I tried with "iterate". But it has some syntax errors I can't resol=
ve.
> The error message is "")" misplaced construct(s)" which points to the=
> first if condition.
> main() {
> var models :=3D model.objects()[Model];
> ownedElement:=3Dself.ownedElement->iterate (el; ini: Set(UML::Element)=
> then
> {select(oclIsTypeOf(UML::Class))->collect(oclAsType(UML::Class))- >map =
> }--end of then
> endif;
> endif;
> );--end of iterate
> Cheers,
> Deepak
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: [QVTO] Iteration over collection [message #82519 is a reply to message #82488] |
Wed, 28 May 2008 08:35   |
Just as suggestion for the starting example - QVTO provides virtual
behavior for the mappings.
So instead of 'if()' testing of element's type the following code can be
used:
packagedElement := self.ownedElement->collect(map ElementToNew())->asSet();
mapping Element::ElementToNew() : PackageableElement {
init {
result := object Class{name:='fake'};
mapping Class::ElementToNew() : PackageableElement {
init {
result := object Class{name:='real'};
mapping Activity::ElementToNew() : PackageableElement {
init {
result := object Activity{};
Radek Dvorak wrote:
> Hi Deepak,
> but returns null.
> 1)
> self.ownedElement->iterate (el; ini: Set(UML::Element) = Set{} |
> exctract them into a helper operation
> would satisfy your
> usecase.
> nestedPackage += self.ownedElement[Package]->map toPackage();
> ownedType := self.ownedElement[Class]->map toClass()->asSet();
> Regards,
> /Radek
>> Hello,
>> another UML model.
>> first if condition.
>> main() {
>> then
>> }--end of then
>> endif;
>> endif;
>> );--end of iterate
>> Cheers,
>> Deepak
Re: [QVTO] Iteration over collection [message #83001 is a reply to message #82519] |
Fri, 30 May 2008 10:17   |
Thanks Radek for your correction.
Sergey your solution is really elegant ! I am using it.
Thanks again !
Che
Sergey Boyko schrieb:
> Hello,
> used:
> init {
> init {
> init {
> Radek Dvorak wrote:
>> Hi Deepak,
>> but returns null.
>> 1)
>> would satisfy your
>> usecase.
>> Regards,
>> /Radek
>>> Hello,
>>> another UML model.
>>> UML::Model.
>>> resolve.
>>> the first if condition.
>>> main() {
>>> then
>>> }--end of then
>>> endif;
>>> endif;
>>> );--end of iterate
>>> Cheers,
>>> Deepak
Re: [QVTO] Iteration over collection [message #83031 is a reply to message #83001] |
Fri, 30 May 2008 11:04  |
Just a remark, you can use mapping 'disjucts' to achieve the same behavi=
or =
with
the advantage of having specific concrete return types.
This allows you to utilize the implicit population section and eliminate=
s
the need for explicit assignment of the result in the init section.
In addition, from the caller perspective, the individual mappings return=
appropriate types and no cast is needed.
Also, no fake result for the abstract super type mapping is really neede=
d
as the 'disjucting' mapping returns null if no appropriate 'disjuncted' =
one
can be selected for a given call.
Everything depends on you needs ;-), check the QVT spec for 'disjuncts',=
if interested.
/Radek
> Thanks again !
> Che
>> Hello,
>> Just as suggestion for the starting example - QVTO provides virtual =
>> So instead of 'if()' testing of element's type the following code can=
>> be used:
>> packagedElement :=3D self.ownedElement->collect(map =
>> init {
>> result :=3D object Class{name:=3D'fake'};
>> init {
>> result :=3D object Class{name:=3D'real'};
>> init {
>> result :=3D object Activity{};
>> Radek Dvorak wrote:
>>> Hi Deepak,
>>> Also, it would not help you much as it executes a block of expressio=
ns =
>>> but returns null.
>>> 1)
>>> iterate (el; ini: Set(UML::Element){}| --> =
>>> self.ownedElement->iterate (el; ini: Set(UML::Element) =3D Set{} |
>>> select(oclIsTypeOf(UML::Class))->collect(oclAsType(UML::Class))- >map=
>>> 4) as in iterate a block of expressions is not supported, you may =
>>> However, I suggest you to follow the style like bellow and guess it =
>>> would satisfy your
>>> usecase.
>>> ownedType :=3D self.ownedElement[Class]->map toClass()->asSet();=
>>> Regards,
>>> /Radek
>>>> Hello,
>>>> I am evaluating QVTO. I want to transform a UML model with differen=
t =
>>>> elements (Class,Subclass, Activity, Statemachine elements) into =
>>>> another UML model.
>>>> Therefore I want to iterate over "ownedElement" Collection of =
>>>> UML::Model.
>>>> So I tried with "iterate". But it has some syntax errors I can't =
>>>> resolve.
>>>> The error message is "")" misplaced construct(s)" which points to =
>>>> main() {
>>>> ownedElement:=3Dself.ownedElement->iterate (el; ini: =
>>>> then
>>>> {select(oclIsTypeOf(UML::Class))->collect(oclAsType(UML::Class))- >m=
ap =
>>>> }--end of then
>>>> endif;
>>>> endif;
>>>> );--end of iterate
>>>> Cheers,
>>>> Deepak
Current Time: Thu Jul 24 00:34:52 EDT 2025
Powered by FUDForum. Page generated in 0.04156 seconds
