Home » Archived » BIRT » SEVERE: Unable to open connection.(Problem with database connection)
SEVERE: Unable to open connection. [message #521084] Tue, 16 March 2010 08:47 Go to next message
I'm rather new to BIRT and was getting along just fine, but now I'm stuck with a database connection problem.
(Using Birt 2.5.1)
I created my report on my desktop with a JDBC Connection to my MYSQL database on another machine, by hardcoding the IP of the MYSQL server. This worked fine until of course when I try to deploy the report to production and the IP is different.
So, I set up a SSH tunnel to forward localhost:3306 to mysqlserver:3306.
Mysqlserver is the same machine the reprots will be deployed to, assuming then that the deployed report would happily connect to localhost on the production server.
The report (and I've recreated the simplest of reports to test with) works on my desktop, but when I deploy the report to the remote machine I keep getting:
16 Mar 2010 2:14:15 PM org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server..
        at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doConnect(JDBCDriverManager.java:262)
        at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getConnection(JDBCDriverManager.java:212)
        at org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUrl(Connection.java:234)
        at org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connection.java:160)
        at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaConnection.open(OdaConnection.java:238)
        at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:180)
        at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:193)
        at org.eclipse.birt.data.engine.executor.DataSource.open(DataSource.java:181)
The connection in the rptdesign file is as follows
    <data-sources>
        <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="7">
            <text-property name="displayName"></text-property>
            <list-property name="privateDriverProperties">
                <ex-property>
                    <name>contentBidiFormatStr</name>
                    <value>ILYNN</value>
                </ex-property>
                <ex-property>
                    <name>metadataBidiFormatStr</name>
                </ex-property>
            </list-property>
            <property name="odaDriverClass">com.mysql.jdbc.Driver</property>
            <property name="odaURL">jdbc:mysql://localhost/DB_PROBE</property>
            <property name="odaUser">probe</property>
            <encrypted-property name="odaPassword" encryptionID="base64">Y2xpZW50X3Bhc3M=</encrypted-property>
        </oda-data-source>
    </data-sources>
And I can happily connect to mysql from localhost with username probe and supplied password.
But for some reason BIRT does not want to connect via jdbc driver ??
Help please.
Thanx
Re: SEVERE: Unable to open connection. [message #521146 is a reply to message #521084] Tue, 16 March 2010 11:01 Go to previous messageGo to next message
I assume you have the same version of the jdbc driver in the production
systems
WEB-INF\platform\plugins\org.eclipse.birt.report.data.oda.jd bc_2.5.1.v20090821\drivers
directory?
Why do you have to setup the ssh tunnel? Why not just change the url
from
to
jdbc:mysql://mysqlserverip:3306/DB_PROBE
Jason
> (Using Birt 2.5.1)
> I keep getting:
> at
> org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:262)
> at
> org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:212)
> at
> org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:234)
> at
> org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec tion.java:160)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:238)
> at
> org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:180)
> at
> org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:193)
> at
> org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:181)
> <data-sources>
> <oda-data-source
> id="7">
> <ex-property>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> <property
> encryptionID="base64">Y2xpZW50X3Bhc3M=</encrypted-property >
> </oda-data-source>
> </data-sources>
> and supplied password. But for some reason BIRT does not want to connect
> via jdbc driver ??
> Help please.
> Thanx
Re: SEVERE: Unable to open connection. [message #521289 is a reply to message #521146] Wed, 17 March 2010 03:14 Go to previous messageGo to next message
Yup, same version of the jdbc driver everywhere.
The reason I set up the ssh tunnel was, cause the report will be deployed to several different machines with different hostnames.. .but localhost will hold true for all instances.
Re: SEVERE: Unable to open connection. [message #521333 is a reply to message #521084] Wed, 17 March 2010 06:19 Go to previous messageGo to next message
Argh.
Ok, my bad.
Turns out MYSQL service was not running on the loopback interface, which is why the localhost tunneling worked , but not an actual localhost connection.
Re: SEVERE: Unable to open connection. [message #824705 is a reply to message #521146] Mon, 19 March 2012 20:39 Go to previous messageGo to next message
Jason,
I'm wondering if you might have some insight. I have been working in the BIRT tool for some time and have established a connection to MySQL using the jdbc driver (v5.1). It has worked consistently up until about a week ago when all of a sudden it stopped working. I get the following error message:
'There is an error in get connection. Communication link failure. The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server'
Nothing, to my knowledge has changed. Do you know where I can look next to troubleshoot? At this point all of my report editing/creation has come to a stand still so I'm really stuck. Any help is appreciated.
Cheers.
Meghan
[Updated on: Mon, 19 March 2012 20:40] by Moderator
Re: SEVERE: Unable to open connection. [message #825257 is a reply to message #824705] Tue, 20 March 2012 13:04 Go to previous messageGo to next message
Meghan,
I get a similar error to this when MySQL is down. Can you connect to it
with the MySQL tools on the same machine?
Jason
On 3/19/2012 8:39 PM, Meghan Mising name wrote:
> Jason,
> message:
> Cheers.
> Meghan
Re: SEVERE: Unable to open connection. [message #825504 is a reply to message #825257] Tue, 20 March 2012 19:11 Go to previous message
Found my issue! Thank you, your reply helped.
Previous Topic:Writing to table from external application
Next Topic:Error when defining drillthrough in a chart
Current Time: Sat Jul 26 20:07:19 EDT 2025
Powered by FUDForum. Page generated in 0.03576 seconds
