Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] dataStore.initialize() fails (four .ecore)
[Teneo] dataStore.initialize() fails (four .ecore) [message #82123] Sat, 05 May 2007 14:38 Go to next message
Originally posted by: gonzalinlinREMOVE_THIS.tiscali.es
Hi Martin,
The dataStore.initialize() call fails. Moreover, when I try to generate the
hibernate.hbm.xml file of one of my ecores, I get an exception (you can see
below, when I tried to generate the hibernate file for factura.ecore).
I needed four ecores for my model. And they are related between them. Maybe
there's an error in the design of the relationships.
I attach my ecores.
Could you help me? Thanks in advance.
With regards,
Gonzalo
0 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM -
Loading class party.PartyPackage should be an epackage
723 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM -
Loading class productoexpediente.ProductoexpedientePackage should be an
epackage
724 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM -
Loading class productoexpediente.factura.FacturaPackage should be an
epackage
Loading class productoexpediente.presupuesto.PresupuestoPackage should be an
epackage
749 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - Properties of
PersistenceOptions:
750 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions -
teneo.mapping.ignore_eannotations: false
teneo.mapping.always_version: true
teneo.mapping.inheritance : SINGLE_TABLE
teneo.mapping.optimistic_locking: true
teneo.naming.id_feature_as_primary_key: true
teneo.naming.default_id_column: e_id
751 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions -
teneo.mapping.default_cache_strategy: NONE
teneo.naming.version_column: e_version
teneo.mapping.fetch_containment_eagerly: false
teneo.mapping.join_table_for_non_contained_associations: false
teneo.naming.java_class_entity_names: false
teneo.naming.max_sql_name_length: -1
teneo.naming.strategy: lowercase
752 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions -
teneo.naming.default_id_feature: e_id
teneo.mapping.disable_econtainer: false
teneo.mapping.proxy_strategy: none
teneo.mapping.default_temporal: TIMESTAMP
teneo.mapping.join_table_naming_strategy: ejb3
teneo.mapping.cascade_all_on_containment: true
teneo.mapping.set_entity_automatically: true
teneo.mapping.hibernate_mapping_file: false
teneo.runtime.update_schema: true
856 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder -
Reading ecore file:
/home/gon/PROYECTO/eclipse/SGD-Modelo-EMF/model/party.ecore
1363 [main] DEBUG
Creating pamodel for the following epackages
1364 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - party
1597 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Create
base pannotated model
1597 [main] DEBUG
Deprecated eannotations with http://annotations.elver.org or
http://ejb.elver.org are ignored.
1597 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Parse
annotations
1608 [main] DEBUG
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter -
Processing package party
1609 [main] DEBUG
Processing party
1609 [main] DEBUG
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Number
of parsed typename annotations 0
1609 [main] DEBUG
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter - Find
efeature for each created eobject
1609 [main] DEBUG
Processing Party
1609 [main] DEBUG
1609 [main] DEBUG
1609 [main] DEBUG
Processing eclass Party
1609 [main] DEBUG
Processing direccion
1609 [main] DEBUG
1610 [main] DEBUG
1610 [main] DEBUG
Processing localidad
1610 [main] DEBUG
1610 [main] DEBUG
1610 [main] DEBUG
Processing codPostal
1610 [main] DEBUG
1610 [main] DEBUG
1610 [main] DEBUG
Processing provincia
1610 [main] DEBUG
1610 [main] DEBUG
1611 [main] DEBUG
Processing telefono1
1611 [main] DEBUG
1611 [main] DEBUG
1611 [main] DEBUG
Processing extTel
1611 [main] DEBUG
1611 [main] DEBUG
1611 [main] DEBUG
Processing telefono2
1611 [main] DEBUG
1611 [main] DEBUG
1611 [main] DEBUG
Processing correoE
1612 [main] DEBUG
1612 [main] DEBUG
1612 [main] DEBUG
Processing fax
1612 [main] DEBUG
1612 [main] DEBUG
1612 [main] DEBUG
Processing web
1612 [main] DEBUG
1612 [main] DEBUG
1612 [main] DEBUG
Processing productos
1612 [main] DEBUG
1612 [main] DEBUG
1613 [main] DEBUG
Processing Empresa
1613 [main] DEBUG
1613 [main] DEBUG
1613 [main] DEBUG
Processing eclass Empresa
1613 [main] DEBUG
Processing cif
1613 [main] DEBUG
1613 [main] DEBUG
1613 [main] DEBUG
Processing denominacion
1613 [main] DEBUG
1613 [main] DEBUG
1614 [main] DEBUG
Processing nombreComercial
1614 [main] DEBUG
1614 [main] DEBUG
1614 [main] DEBUG
Processing cnae
1614 [main] DEBUG
1614 [main] DEBUG
1614 [main] DEBUG
Processing contacto
1614 [main] DEBUG
1614 [main] DEBUG
1614 [main] DEBUG
Processing Persona
1614 [main] DEBUG
1615 [main] DEBUG
1615 [main] DEBUG
Processing eclass Persona
1615 [main] DEBUG
Processing nif
1615 [main] DEBUG
1615 [main] DEBUG
1615 [main] DEBUG
Processing nombre
1615 [main] DEBUG
1615 [main] DEBUG
1615 [main] DEBUG
Processing apellido1
1615 [main] DEBUG
1616 [main] DEBUG
1616 [main] DEBUG
Processing apellido2
1616 [main] DEBUG
1617 [main] DEBUG
1622 [main] DEBUG
Processing fechaNac
1623 [main] DEBUG
1623 [main] DEBUG
1623 [main] DEBUG
Processing ContactoEmpresa
1623 [main] DEBUG
1623 [main] DEBUG
1623 [main] DEBUG
Processing eclass ContactoEmpresa
1623 [main] DEBUG
Processing cargo
1625 [main] DEBUG
1625 [main] DEBUG
1625 [main] DEBUG
Processing dptoEmpresa
1625 [main] DEBUG
1625 [main] DEBUG
1625 [main] DEBUG
Processing empresa
1625 [main] DEBUG
1625 [main] DEBUG
1625 [main] DEBUG
Processing Pdi
1625 [main] DEBUG
1626 [main] DEBUG
1626 [main] DEBUG
Processing eclass Pdi
1626 [main] DEBUG
Processing catAcademica
1626 [main] DEBUG
1626 [main] DEBUG
1626 [main] DEBUG
Processing areaConocimiento
1626 [main] DEBUG
1626 [main] DEBUG
1626 [main] DEBUG
Processing departamento
1626 [main] DEBUG
1626 [main] DEBUG
1627 [main] DEBUG
Processing centro
1627 [main] DEBUG
1627 [main] DEBUG
1627 [main] DEBUG
Processing codCtaCliente
1627 [main] DEBUG
1627 [main] DEBUG
1627 [main] DEBUG
Processing remuneracion
1627 [main] DEBUG
1629 [main] DEBUG
1629 [main] DEBUG
Processing horasSemanales
1629 [main] DEBUG
1629 [main] DEBUG
1629 [main] DEBUG
Processing Pas
1629 [main] DEBUG
1629 [main] DEBUG
1629 [main] DEBUG
Processing eclass Pas
1630 [main] DEBUG
Processing gratificacion
1630 [main] DEBUG
1630 [main] DEBUG
1630 [main] DEBUG
Processing cosCtaCliente
1630 [main] DEBUG
1630 [main] DEBUG
1630 [main] DEBUG
Processing centro
1630 [main] DEBUG
1630 [main] DEBUG
1630 [main] DEBUG
Processing Becario
1631 [main] DEBUG
1631 [main] DEBUG
1631 [main] DEBUG
Processing eclass Becario
1631 [main] DEBUG
1631 [main] DEBUG
1631 [main] DEBUG
1631 [main] DEBUG
Processing titulacion
1631 [main] DEBUG
1631 [main] DEBUG
1632 [main] DEBUG
1632 [main] DEBUG
1632 [main] DEBUG
1632 [main] DEBUG
1632 [main] DEBUG
1632 [main] DEBUG
1632 [main] DEBUG
Copying annotations on edatatypes over eattribute annotations!
1632 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Add
default annotations
1643 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option
inheritance: single
1643 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option: Default
inheritance setting: SINGLE_TABLE
1643 [main] DEBUG
Automatically adding entity annotation: true
1643 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option: Eagerly
load all containment relations: false
1643 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option set
cascade all on containment: true
1643 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Option default
id feature name: e_id
1649 [main] DEBUG org.eclipse.emf.teneo.ecore.EClassNameStrategyUtils -
Creating org.eclipse.emf.teneo.ecore.DefaultEClassNameStrategy as eclass
name strategy
1649 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Qualify EClass
name option: org.eclipse.emf.teneo.ecore.DefaultEClassNameStrategy
1649 [main] DEBUG
g.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Maximum column
length: -1
1650 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - ID Feature as
primary key true
1650 [main] DEBUG
JoinTableForNonContainedAssociations false
1654 [main] DEBUG org.eclipse.emf.teneo.util.SQLCaseStrategyImpl - Creating
org.eclipse.emf.teneo.util.SQLCaseStrategyImpl$LowerCase as case strategy
1654 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - SQLCaseStrategy
1654 [main] DEBUG
JoinTableNamingStrategy ejb3
1654 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - >>>> Adding
default annotations for EPackage party
1654 [main] DEBUG
g.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Processing
EDataTypes
1654 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Processing
EClasses
1654 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Adding default
annotations for EClass: Party
1666 [main] DEBUG
annotations for EAttribute direccion
1668 [main] DEBUG
annotations for EAttribute localidad
1670 [main] DEBUG
annotations for EAttribute codPostal
1670 [main] DEBUG
annotations for EAttribute provincia
1670 [main] DEBUG
annotations for EAttribute telefono1
1670 [main] DEBUG
annotations for EAttribute extTel
1670 [main] DEBUG
annotations for EAttribute telefono2
1671 [main] DEBUG
annotations for EAttribute correoE
1671 [main] DEBUG
annotations for EAttribute fax
1671 [main] DEBUG
annotations for EAttribute web
1796 [main] DEBUG
rg.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - EReference +
productos/Party does not have a onetomany annotation, adding one
Exception in thread "main" java.lang.IllegalArgumentException : No annotated
model element present for: ProductoExpediente for type EClass has its
epackage been registered with Teneo?
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.checkAnnotatedPresent
(PAnnotatedModelImpl.java:324)
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.getPAnnotated(PAnnotatedModelImpl.java:270)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.ge tEntityName
(DefaultAnnotator.java:1397)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessOneToManyReference(DefaultAnnotator.java:830)
at
org.eclipse.emf.teneo.hibernate.hbannotation.util.HibernateD efaultAnnotator.processOneToManyReference
(HibernateDefaultAnnotator.java:180)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessEFeature(DefaultAnnotator.java:532)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessClass
(DefaultAnnotator.java:412)
at
org.eclipse.emf.teneo.hibernate.hbannotation.util.HibernateD efaultAnnotator.processClass(HibernateDefaultAnnotator.java: 144)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessPackage
(DefaultAnnotator.java:254)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.ma p(DefaultAnnotator.java:164)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java
:158)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:90)
at
org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM.createORM apperFile(GenerateHBM.java
:104)
at
org.eclipse.emf.teneo.hibernate.mapper.GenerateHBM.main(Gene rateHBM.java:84)
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #82175 is a reply to message #82123] Sun, 06 May 2007 09:25 Go to previous messageGo to next message
Hi Gonzalo,
Do you pass all epackage instances (of all the ecore models) to the datastore (in setEpackages())?
gr. Martin
Gonzalo wrote:
> Hi Martin,
> I attach my ecores.
> With regards,
> Gonzalo
> epackage
> epackage
> epackage
> PersistenceOptions:
> 856 [main] DEBUG
> Reading ecore file:
> 1363 [main] DEBUG
> 1364 [main] DEBUG
> 1597 [main] DEBUG
> 1597 [main] DEBUG
> 1597 [main] DEBUG
> annotations
> 1608 [main] DEBUG
> 1609 [main] DEBUG
> Processing party
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> Processing Party
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> Processing extTel
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> Processing correoE
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> Processing fax
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> Processing web
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1613 [main] DEBUG
> Processing Empresa
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> Processing cif
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> Processing cnae
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> Processing contacto
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> Processing Persona
> 1614 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> Processing nif
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> Processing nombre
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1616 [main] DEBUG
> 1616 [main] DEBUG
> 1616 [main] DEBUG
> 1617 [main] DEBUG
> 1622 [main] DEBUG
> Processing fechaNac
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> Processing cargo
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> Processing empresa
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> Processing Pdi
> 1625 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1627 [main] DEBUG
> Processing centro
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> Processing Pas
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> Processing centro
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> Processing Becario
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> default annotations
> 1643 [main] DEBUG
> inheritance: single
> 1643 [main] DEBUG
> 1643 [main] DEBUG
> 1643 [main] DEBUG
> 1643 [main] DEBUG
> 1643 [main] DEBUG
> name strategy
> 1649 [main] DEBUG
> 1649 [main] DEBUG
> length: -1
> 1650 [main] DEBUG
> primary key true
> 1650 [main] DEBUG
> 1654 [main] DEBUG
> 1654 [main] DEBUG
> 1654 [main] DEBUG
> 1654 [main] DEBUG
> EDataTypes
> 1654 [main] DEBUG
> EClasses
> 1654 [main] DEBUG
> 1666 [main] DEBUG
> 1668 [main] DEBUG
> 1670 [main] DEBUG
> 1670 [main] DEBUG
> 1670 [main] DEBUG
> 1670 [main] DEBUG
> 1670 [main] DEBUG
> 1671 [main] DEBUG
> 1671 [main] DEBUG
> 1671 [main] DEBUG
> 1796 [main] DEBUG
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> :158)
> at
> at
> :104)
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #82324 is a reply to message #82175] Mon, 07 May 2007 14:51 Go to previous messageGo to next message
Hi Martin,
yes, I passed all ePackage instances to the dataStore.
I've tried it, with and without the qualified name of the ePackages.
I'm working in these two folders:
[project_root_folder]/src <- ePackages live here.
[project_root_folder]/Subsystems/WebPortal/Sources <- The java actions
calling dataStore.initialize() and ataStore.setePackages live in Java
packages under this folder.
Maybe dataStore.setEPackages can't find them?
With regards,
Gonzalo
"Martin Taal" <mtaal@elver.org> escribi
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #82363 is a reply to message #82324] Mon, 07 May 2007 15:47 Go to previous messageGo to next message
Hi Gonzalo,
I tested it and with me the tables are created in the db without errors. I used the four ecore files
you posted earlier.
How does your initialization code look like?
gr. Martin
Gonzalo wrote:
> Hi Martin,
> With regards,
> Gonzalo
> "Martin Taal" <mtaal@elver.org> escribió en el mensaje
> news:f1kl11$d5d$1@build.eclipse.org...
>> Hi Gonzalo,
>> gr. Martin
>> Gonzalo wrote:
>>> Hi Martin,
>>> the hibernate.hbm.xml file of one of my ecores, I get an exception (you
>>> can see below, when I tried to generate the hibernate file for
>>> factura.ecore).
>>> Maybe there's an error in the design of the relationships.
>>> I attach my ecores.
>>> With regards,
>>> Gonzalo
>>> epackage
>>> epackage
>>> an epackage
>>> of PersistenceOptions:
>>> 856 [main] DEBUG
>>> Reading ecore file:
>>> 1363 [main] DEBUG
>>> 1364 [main] DEBUG
>>> party
>>> 1597 [main] DEBUG
>>> Create base pannotated model
>>> 1597 [main] DEBUG
>>> 1597 [main] DEBUG
>>> Parse annotations
>>> 1608 [main] DEBUG
>>> 1609 [main] DEBUG
>>> Processing party
>>> 1609 [main] DEBUG
>>> Number of parsed typename annotations 0
>>> 1609 [main] DEBUG
>>> Find efeature for each created eobject
>>> 1609 [main] DEBUG
>>> Processing Party
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> Processing extTel
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> Processing correoE
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> Processing fax
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> Processing web
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1613 [main] DEBUG
>>> Processing Empresa
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> Processing cif
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> Processing cnae
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> Processing contacto
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> Processing Persona
>>> 1614 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> Processing nif
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> Processing nombre
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1616 [main] DEBUG
>>> 1616 [main] DEBUG
>>> 1616 [main] DEBUG
>>> 1617 [main] DEBUG
>>> 1622 [main] DEBUG
>>> Processing fechaNac
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> Processing cargo
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> Processing empresa
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> Processing Pdi
>>> 1625 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1627 [main] DEBUG
>>> Processing centro
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> Processing Pas
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> Processing centro
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> Processing Becario
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> default annotations
>>> 1643 [main] DEBUG
>>> inheritance: single
>>> 1643 [main] DEBUG
>>> Default inheritance setting: SINGLE_TABLE
>>> 1643 [main] DEBUG
>>> 1643 [main] DEBUG
>>> Eagerly load all containment relations: false
>>> 1643 [main] DEBUG
>>> 1643 [main] DEBUG
>>> default id feature name: e_id
>>> name strategy
>>> 1649 [main] DEBUG
>>> EClass name option: org.eclipse.emf.teneo.ecore.DefaultEClassNameStrategy
>>> 1649 [main] DEBUG
>>> length: -1
>>> 1650 [main] DEBUG
>>> primary key true
>>> 1650 [main] DEBUG
>>> Creating org.eclipse.emf.teneo.util.SQLCaseStrategyImpl$LowerCase as case
>>> strategy
>>> 1654 [main] DEBUG
>>> SQLCaseStrategy org.eclipse.emf.teneo.util.SQLCaseStrategyImpl$LowerCase
>>> 1654 [main] DEBUG
>>> 1654 [main] DEBUG
>>> 1654 [main] DEBUG
>>> EDataTypes
>>> 1654 [main] DEBUG
>>> EClasses
>>> 1654 [main] DEBUG
>>> default annotations for EClass: Party
>>> 1666 [main] DEBUG
>>> default annotations for EAttribute direccion
>>> 1668 [main] DEBUG
>>> default annotations for EAttribute localidad
>>> 1670 [main] DEBUG
>>> default annotations for EAttribute codPostal
>>> 1670 [main] DEBUG
>>> default annotations for EAttribute provincia
>>> 1670 [main] DEBUG
>>> default annotations for EAttribute telefono1
>>> 1670 [main] DEBUG
>>> default annotations for EAttribute extTel
>>> 1670 [main] DEBUG
>>> default annotations for EAttribute telefono2
>>> 1671 [main] DEBUG
>>> default annotations for EAttribute correoE
>>> 1671 [main] DEBUG
>>> default annotations for EAttribute fax
>>> 1671 [main] DEBUG
>>> default annotations for EAttribute web
>>> 1796 [main] DEBUG
>>> annotated model element present for: ProductoExpediente for type EClass
>>> has its epackage been registered with Teneo?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> :158)
>>> at
>>> at
>>> :104)
>>> at
>> The Netherlands
The Netherlands
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #82398 is a reply to message #82363] Mon, 07 May 2007 17:07 Go to previous messageGo to next message
Hi Martin,
my initialization code is:
final Properties persistenceProps = new Properties();
persistenceProps.setProperty(PersistenceOptions.QUALIFY_ENTI TY_NAME,
PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX);
// Create the DataStore.
final String dataStoreName = "mayo";
final HbDataStore dataStore =
(HbDataStore)HbHelper.INSTANCE.createRegisterDataStore(dataS toreName);
dataStore.setPersistenceProperties(persistenceProps);
// Configure the EPackages used by this DataStore.
dataStore.setEPackages(new EPackage[] { PartyPackage.eINSTANCE,
ProductoexpedientePackage.eINSTANCE,
FacturaPackage.eINSTANCE, PresupuestoPackage.eINSTANCE});
// Initialize the DataStore. This sets up the Hibernate mapping and, in
// turn, creates the corresponding tables in the database.
dataStore.initialize();
final SessionFactory sessionFactory = dataStore.getSessionFactory();
// Open a new Session and start transaction.
final Session session = sessionFactory.openSession();
session.beginTransaction();
// Create an empresa.
Empresa empresa = PartyFactory.eINSTANCE.createEmpresa();
(code continues...)
I didn't this test today. Yes, you're right. This works! (Executing this
"main" class under my "src" folder). But...
Today, I tested this through my web application (Subsystems\WebPortal
folder) under Tomcat. So I think it must be that my web application doesn't
find the ePackages. This happens when I try to register a new Party (for
example) through a web form.
You have any idea? Thanks in advance!
With regards,
Gonzalo
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #82417 is a reply to message #82398] Mon, 07 May 2007 17:28 Go to previous messageGo to next message
Hi Gonzalo,
How does your initialization code look like in the web app, at which point do you initialize the
datastore?
gr. Martin
Gonzalo wrote:
> Hi Martin,
> public static void main(String[] args) {
> (code continues...)
> With regards,
> Gonzalo
> news:f1nvog$2ut$1@build.eclipse.org...
>> Hi Gonzalo,
>> used the four ecore files you posted earlier.
>> gr. Martin
>> Gonzalo wrote:
>>> Hi Martin,
>>> With regards,
>>> Gonzalo
>>>> Hi Gonzalo,
>>>> gr. Martin
>>>> Gonzalo wrote:
>>>>> Hi Martin,
>>>>> factura.ecore).
>>>>> I attach my ecores.
>>>>> With regards,
>>>>> Gonzalo
>>>>> epackage
>>>>> epackage
>>>>> 724 [main] DEBUG
>>>>> g.eclipse.emf.teneo.hibernate.mapper.GenerateHBM - Loading class
>>>>> productoexpediente.presupuesto.PresupuestoPackage should be an epackage
>>>>> Properties of PersistenceOptions:
>>>>> 856 [main] DEBUG
>>>>> Reading ecore file:
>>>>> 1363 [main] DEBUG
>>>>> 1364 [main] DEBUG
>>>>> party
>>>>> 1597 [main] DEBUG
>>>>> 1597 [main] DEBUG
>>>>> 1597 [main] DEBUG
>>>>> Parse annotations
>>>>> 1608 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> Processing party
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> Processing Party
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> Processing extTel
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> Processing correoE
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> Processing fax
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> Processing web
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> Processing Empresa
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> Processing cif
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> Processing cnae
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> Processing contacto
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> Processing Persona
>>>>> 1614 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> Processing nif
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> Processing nombre
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1616 [main] DEBUG
>>>>> 1616 [main] DEBUG
>>>>> 1616 [main] DEBUG
>>>>> 1617 [main] DEBUG
>>>>> 1622 [main] DEBUG
>>>>> Processing fechaNac
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> Processing cargo
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> Processing empresa
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> Processing Pdi
>>>>> 1625 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> Processing centro
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> Processing Pas
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> Processing centro
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> Processing Becario
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> Add default annotations
>>>>> 1643 [main] DEBUG
>>>>> inheritance: single
>>>>> 1643 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> 1649 [main] DEBUG
>>>>> rg.eclipse.emf.teneo.ecore.EClassNameStrategyUtils - Creating
>>>>> org.eclipse.emf.teneo.ecore.DefaultEClassNameStrategy as eclass name
>>>>> strategy
>>>>> 1649 [main] DEBUG
>>>>> EClass name option:
>>>>> 1649 [main] DEBUG
>>>>> length: -1
>>>>> 1650 [main] DEBUG
>>>>> as primary key true
>>>>> 1650 [main] DEBUG
>>>>> case strategy
>>>>> 1654 [main] DEBUG
>>>>> SQLCaseStrategy
>>>>> 1654 [main] DEBUG
>>>>> 1654 [main] DEBUG
>>>>> 1654 [main] DEBUG
>>>>> EDataTypes
>>>>> 1654 [main] DEBUG
>>>>> EClasses
>>>>> 1654 [main] DEBUG
>>>>> 1666 [main] DEBUG
>>>>> 1668 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1671 [main] DEBUG
>>>>> 1671 [main] DEBUG
>>>>> 1671 [main] DEBUG
>>>>> 1796 [main] DEBUG
>>>>> + productos/Party does not have a onetomany annotation, adding one
>>>>> EClass has its epackage been registered with Teneo?
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> :158)
>>>>> at
>>>>> at
>>>>> :104)
>>>>> at
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #82439 is a reply to message #82417] Mon, 07 May 2007 17:46 Go to previous messageGo to next message
Hi Martin,
I initialize the code in the moment I press the button "Save changes". When
I press this button an Action is executed (like the one I attach to this
email). I initialize the DataStore at this moment.
With regards,
Gonzalo
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #82490 is a reply to message #82439] Tue, 08 May 2007 01:27 Go to previous messageGo to next message
Hi Gonzalo,
I don't know how your web development project is structured but the only thing I can think of right
now is that the version of the ProductoexpedientePackage.eINSTANCE in the web classpath differs from
your classpath in the main program you tested. Can you check?
gr. Martin
Gonzalo wrote:
> Hi Martin,
> With regards,
> Gonzalo
> news:f1o5lf$cjl$1@build.eclipse.org...
>> Hi Gonzalo,
>> datastore?
>> gr. Martin
>> Gonzalo wrote:
>>> Hi Martin,
>>> (code continues...)
>>> doesn't
>>> With regards,
>>> Gonzalo
>>>> Hi Gonzalo,
>>>> I
>>>> gr. Martin
>>>> Gonzalo wrote:
>>>>> Hi Martin,
>>>>> With regards,
>>>>> Gonzalo
>>>>>> Hi Gonzalo,
>>>>>> gr. Martin
>>>>>> Gonzalo wrote:
>>>>>>> Hi Martin,
>>>>>>> generate
>>>>>>> (you
>>>>>>> factura.ecore).
>>>>>>> I attach my ecores.
>>>>>>> With regards,
>>>>>>> Gonzalo
>>>>>>> 0 [main] DEBUG
>>>>>>> 723 [main] DEBUG
>>>>>>> an
>>>>>>> epackage
>>>>>>> 724 [main] DEBUG
>>>>>>> epackage
>>>>>>> 724 [main] DEBUG
>>>>>>> epackage
>>>>>>> 856 [main] DEBUG
>>>>>>> g.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBui lder -
>>>>>>> Reading ecore file:
>>>>>>> 1363 [main] DEBUG
>>>>>>> 1364 [main] DEBUG
>>>>>>> party
>>>>>>> 1597 [main] DEBUG
>>>>>>> 1597 [main] DEBUG
>>>>>>> 1597 [main] DEBUG
>>>>>>> Parse annotations
>>>>>>> 1608 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> Processing party
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> Processing Party
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> Processing extTel
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> Processing correoE
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> Processing fax
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> Processing web
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> Processing Empresa
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> Processing cif
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> Processing cnae
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> Processing contacto
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> Processing Persona
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> Processing nif
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> Processing nombre
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1616 [main] DEBUG
>>>>>>> 1616 [main] DEBUG
>>>>>>> 1616 [main] DEBUG
>>>>>>> 1617 [main] DEBUG
>>>>>>> 1622 [main] DEBUG
>>>>>>> Processing fechaNac
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> Processing cargo
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> Processing empresa
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> Processing Pdi
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> Processing centro
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> Processing Pas
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> Processing centro
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> Processing Becario
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1643 [main] DEBUG
>>>>>>> inheritance: single
>>>>>>> 1643 [main] DEBUG
>>>>>>> 1643 [main] DEBUG
>>>>>>> 1643 [main] DEBUG
>>>>>>> 1643 [main] DEBUG
>>>>>>> set
>>>>>>> 1643 [main] DEBUG
>>>>>>> 1649 [main] DEBUG
>>>>>>> strategy
>>>>>>> 1649 [main] DEBUG
>>>>>>> EClass name option:
>>>>>>> 1649 [main] DEBUG
>>>>>>> column
>>>>>>> length: -1
>>>>>>> 1650 [main] DEBUG
>>>>>>> Feature
>>>>>>> as primary key true
>>>>>>> 1650 [main] DEBUG
>>>>>>> case strategy
>>>>>>> 1654 [main] DEBUG
>>>>>>> SQLCaseStrategy
>>>>>>> 1654 [main] DEBUG
>>>>>>> 1654 [main] DEBUG
>>>>>>> Adding
>>>>>>> 1654 [main] DEBUG
>>>>>>> EDataTypes
>>>>>>> 1654 [main] DEBUG
>>>>>>> Processing
>>>>>>> EClasses
>>>>>>> 1654 [main] DEBUG
>>>>>>> 1666 [main] DEBUG
>>>>>>> 1668 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1671 [main] DEBUG
>>>>>>> 1671 [main] DEBUG
>>>>>>> 1671 [main] DEBUG
>>>>>>> 1796 [main] DEBUG
>>>>>>> EReference
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> :158)
>>>>>>> at
>>>>>>> at
>>>>>>> :104)
>>>>>>> at
>>>>>> The Netherlands
>>>> The Netherlands
>> The Netherlands
> package es.udc.fbellas.j2ee.miniportal.http.controller.actions;
> import java.io.IOException;
> import java.util.Properties;
> import javax.servlet.http.HttpServletRequest;
> import javax.servlet.http.HttpServletResponse;
> import javax.servlet.ServletException;
> import org.apache.struts.action.ActionMessage;
> import org.apache.struts.action.ActionMessages;
> import org.apache.struts.action.ActionMapping;
> import org.apache.struts.action.ActionForm;
> import org.apache.struts.action.ActionForward;
> import org.eclipse.emf.ecore.EPackage;
> import org.eclipse.emf.teneo.PersistenceOptions;
> import org.eclipse.emf.teneo.hibernate.HbDataStore;
> import org.eclipse.emf.teneo.hibernate.HbHelper;
> import org.hibernate.Session;
> import org.hibernate.SessionFactory;
> import party.Empresa;
> import party.PartyFactory;
> import party.PartyPackage;
> import productoexpediente.ProductoexpedientePackage;
> import productoexpediente.factura.FacturaPackage;
> import productoexpediente.presupuesto.PresupuestoPackage;
> import es.udc.fbellas.j2ee.util.exceptions.InternalErrorException;
> import es.udc.fbellas.j2ee.util.exceptions.DuplicateInstanceExcepti on;
> import es.udc.fbellas.j2ee.util.struts.action.DefaultAction;
> import es.udc.fbellas.j2ee.miniportal.model.userprofile.vo.UserProf ileDetailsVO;
> import es.udc.fbellas.j2ee.miniportal.http.view.actionforms.Empresa Form;
> import es.udc.fbellas.j2ee.miniportal.http.view.actionforms.UserPro fileForm;
> import es.udc.fbellas.j2ee.miniportal.http.controller.session.Sessi onManager;
> public class CreateEmpresaAction extends DefaultAction {
> public ActionForward doExecute(ActionMapping mapping,
> ActionForm form, HttpServletRequest request,
> HttpServletResponse response)
> throws IOException, ServletException, InternalErrorException {
> /* Get data. */
> EmpresaForm empresaForm = (EmpresaForm) form;
> String cif = empresaForm.getCif();
> String cnae = empresaForm.getCnae();
> String denominacion = empresaForm.getDenominacion();
> String nombreComercial = empresaForm.getNombreComercial();
> ActionMessages errors = new ActionMessages();
> persistenceProps.setProperty(PersistenceOptions.QUALIFY_ENTI TY_NAME, PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX);
> final HbDataStore dataStore = (HbDataStore)HbHelper.INSTANCE.createRegisterDataStore(dataS toreName);
> dataStore.setEPackages(new EPackage[] { PartyPackage.eINSTANCE, ProductoexpedientePackage.eINSTANCE,
> try {
> empresa.setCif(cif);
> empresa.setCnae(cnae);
> empresa.setDenominacion(denominacion);
> empresa.setNombreComercial(nombreComercial);
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #82674 is a reply to message #82490] Wed, 09 May 2007 07:03 Go to previous message
Originally posted by: gonzalinlinWITHOUT_THIS.tiscali.es
Hi Martin,
I think there's something wrong in the connection between my webapp and
Teneo-Hibernate-MySQL.
I'm trying to find a solution.
Thank you very much!
With regards,
Gonzalo
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #605308 is a reply to message #82123] Sun, 06 May 2007 09:25 Go to previous message
Hi Gonzalo,
gr. Martin
Gonzalo wrote:
> Hi Martin,
> I attach my ecores.
> With regards,
> Gonzalo
> epackage
> epackage
> epackage
> PersistenceOptions:
> 856 [main] DEBUG
> Reading ecore file:
> 1363 [main] DEBUG
> 1364 [main] DEBUG
> 1597 [main] DEBUG
> 1597 [main] DEBUG
> 1597 [main] DEBUG
> annotations
> 1608 [main] DEBUG
> 1609 [main] DEBUG
> Processing party
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> Processing Party
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1609 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1610 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> Processing extTel
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> 1611 [main] DEBUG
> Processing correoE
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> Processing fax
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> Processing web
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1612 [main] DEBUG
> 1613 [main] DEBUG
> Processing Empresa
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> Processing cif
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1613 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> Processing cnae
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> Processing contacto
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> 1614 [main] DEBUG
> Processing Persona
> 1614 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> Processing nif
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> Processing nombre
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1615 [main] DEBUG
> 1616 [main] DEBUG
> 1616 [main] DEBUG
> 1616 [main] DEBUG
> 1617 [main] DEBUG
> 1622 [main] DEBUG
> Processing fechaNac
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> 1623 [main] DEBUG
> Processing cargo
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> Processing empresa
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> 1625 [main] DEBUG
> Processing Pdi
> 1625 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1626 [main] DEBUG
> 1627 [main] DEBUG
> Processing centro
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1627 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> Processing Pas
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1629 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> Processing centro
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> 1630 [main] DEBUG
> Processing Becario
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1631 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> 1632 [main] DEBUG
> default annotations
> 1643 [main] DEBUG
> inheritance: single
> 1643 [main] DEBUG
> 1643 [main] DEBUG
> 1643 [main] DEBUG
> 1643 [main] DEBUG
> 1643 [main] DEBUG
> name strategy
> 1649 [main] DEBUG
> 1649 [main] DEBUG
> length: -1
> 1650 [main] DEBUG
> primary key true
> 1650 [main] DEBUG
> 1654 [main] DEBUG
> 1654 [main] DEBUG
> 1654 [main] DEBUG
> 1654 [main] DEBUG
> EDataTypes
> 1654 [main] DEBUG
> EClasses
> 1654 [main] DEBUG
> 1666 [main] DEBUG
> 1668 [main] DEBUG
> 1670 [main] DEBUG
> 1670 [main] DEBUG
> 1670 [main] DEBUG
> 1670 [main] DEBUG
> 1670 [main] DEBUG
> 1671 [main] DEBUG
> 1671 [main] DEBUG
> 1671 [main] DEBUG
> 1796 [main] DEBUG
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> :158)
> at
> at
> :104)
> at
The Netherlands
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #605344 is a reply to message #82175] Mon, 07 May 2007 14:51 Go to previous message
Hi Martin,
With regards,
Gonzalo
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #605351 is a reply to message #82324] Mon, 07 May 2007 15:47 Go to previous message
Hi Gonzalo,
you posted earlier.
gr. Martin
Gonzalo wrote:
> Hi Martin,
> With regards,
> Gonzalo
>> Hi Gonzalo,
>> gr. Martin
>> Gonzalo wrote:
>>> Hi Martin,
>>> factura.ecore).
>>> I attach my ecores.
>>> With regards,
>>> Gonzalo
>>> epackage
>>> epackage
>>> an epackage
>>> 856 [main] DEBUG
>>> Reading ecore file:
>>> 1363 [main] DEBUG
>>> 1364 [main] DEBUG
>>> party
>>> 1597 [main] DEBUG
>>> 1597 [main] DEBUG
>>> 1597 [main] DEBUG
>>> Parse annotations
>>> 1608 [main] DEBUG
>>> 1609 [main] DEBUG
>>> Processing party
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> Processing Party
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1609 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1610 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> Processing extTel
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> 1611 [main] DEBUG
>>> Processing correoE
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> Processing fax
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> Processing web
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1612 [main] DEBUG
>>> 1613 [main] DEBUG
>>> Processing Empresa
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> Processing cif
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1613 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> Processing cnae
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> Processing contacto
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> 1614 [main] DEBUG
>>> Processing Persona
>>> 1614 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> Processing nif
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> Processing nombre
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1615 [main] DEBUG
>>> 1616 [main] DEBUG
>>> 1616 [main] DEBUG
>>> 1616 [main] DEBUG
>>> 1617 [main] DEBUG
>>> 1622 [main] DEBUG
>>> Processing fechaNac
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> 1623 [main] DEBUG
>>> Processing cargo
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> Processing empresa
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> 1625 [main] DEBUG
>>> Processing Pdi
>>> 1625 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1626 [main] DEBUG
>>> 1627 [main] DEBUG
>>> Processing centro
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1627 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> Processing Pas
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1629 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> Processing centro
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> 1630 [main] DEBUG
>>> Processing Becario
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1631 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> 1632 [main] DEBUG
>>> default annotations
>>> 1643 [main] DEBUG
>>> inheritance: single
>>> 1643 [main] DEBUG
>>> 1643 [main] DEBUG
>>> 1643 [main] DEBUG
>>> 1643 [main] DEBUG
>>> 1643 [main] DEBUG
>>> name strategy
>>> 1649 [main] DEBUG
>>> 1649 [main] DEBUG
>>> length: -1
>>> 1650 [main] DEBUG
>>> primary key true
>>> 1650 [main] DEBUG
>>> strategy
>>> 1654 [main] DEBUG
>>> 1654 [main] DEBUG
>>> 1654 [main] DEBUG
>>> 1654 [main] DEBUG
>>> EDataTypes
>>> 1654 [main] DEBUG
>>> EClasses
>>> 1654 [main] DEBUG
>>> 1666 [main] DEBUG
>>> 1668 [main] DEBUG
>>> 1670 [main] DEBUG
>>> 1670 [main] DEBUG
>>> 1670 [main] DEBUG
>>> 1670 [main] DEBUG
>>> 1670 [main] DEBUG
>>> 1671 [main] DEBUG
>>> 1671 [main] DEBUG
>>> 1671 [main] DEBUG
>>> 1796 [main] DEBUG
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> :158)
>>> at
>>> at
>>> :104)
>>> at
>> The Netherlands
The Netherlands
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #605360 is a reply to message #82363] Mon, 07 May 2007 17:07 Go to previous message
Hi Martin,
(code continues...)
With regards,
Gonzalo
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #605364 is a reply to message #82398] Mon, 07 May 2007 17:28 Go to previous message
Hi Gonzalo,
datastore?
gr. Martin
Gonzalo wrote:
> Hi Martin,
> (code continues...)
> With regards,
> Gonzalo
>> Hi Gonzalo,
>> gr. Martin
>> Gonzalo wrote:
>>> Hi Martin,
>>> With regards,
>>> Gonzalo
>>>> Hi Gonzalo,
>>>> gr. Martin
>>>> Gonzalo wrote:
>>>>> Hi Martin,
>>>>> factura.ecore).
>>>>> I attach my ecores.
>>>>> With regards,
>>>>> Gonzalo
>>>>> epackage
>>>>> epackage
>>>>> 724 [main] DEBUG
>>>>> 856 [main] DEBUG
>>>>> Reading ecore file:
>>>>> 1363 [main] DEBUG
>>>>> 1364 [main] DEBUG
>>>>> party
>>>>> 1597 [main] DEBUG
>>>>> 1597 [main] DEBUG
>>>>> 1597 [main] DEBUG
>>>>> Parse annotations
>>>>> 1608 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> Processing party
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> Processing Party
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1609 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1610 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> Processing extTel
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> 1611 [main] DEBUG
>>>>> Processing correoE
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> Processing fax
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> Processing web
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1612 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> Processing Empresa
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> Processing cif
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1613 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> Processing cnae
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> Processing contacto
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> 1614 [main] DEBUG
>>>>> Processing Persona
>>>>> 1614 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> Processing nif
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> Processing nombre
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1615 [main] DEBUG
>>>>> 1616 [main] DEBUG
>>>>> 1616 [main] DEBUG
>>>>> 1616 [main] DEBUG
>>>>> 1617 [main] DEBUG
>>>>> 1622 [main] DEBUG
>>>>> Processing fechaNac
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> 1623 [main] DEBUG
>>>>> Processing cargo
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> Processing empresa
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> 1625 [main] DEBUG
>>>>> Processing Pdi
>>>>> 1625 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1626 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> Processing centro
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1627 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> Processing Pas
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1629 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> Processing centro
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> 1630 [main] DEBUG
>>>>> Processing Becario
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1631 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1632 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> inheritance: single
>>>>> 1643 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> 1643 [main] DEBUG
>>>>> 1649 [main] DEBUG
>>>>> strategy
>>>>> 1649 [main] DEBUG
>>>>> EClass name option:
>>>>> 1649 [main] DEBUG
>>>>> length: -1
>>>>> 1650 [main] DEBUG
>>>>> as primary key true
>>>>> 1650 [main] DEBUG
>>>>> case strategy
>>>>> 1654 [main] DEBUG
>>>>> SQLCaseStrategy
>>>>> 1654 [main] DEBUG
>>>>> 1654 [main] DEBUG
>>>>> 1654 [main] DEBUG
>>>>> EDataTypes
>>>>> 1654 [main] DEBUG
>>>>> EClasses
>>>>> 1654 [main] DEBUG
>>>>> 1666 [main] DEBUG
>>>>> 1668 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1670 [main] DEBUG
>>>>> 1671 [main] DEBUG
>>>>> 1671 [main] DEBUG
>>>>> 1671 [main] DEBUG
>>>>> 1796 [main] DEBUG
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> :158)
>>>>> at
>>>>> at
>>>>> :104)
>>>>> at
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #605375 is a reply to message #82417] Mon, 07 May 2007 17:46 Go to previous message
Hi Martin,
With regards,
Gonzalo
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #606622 is a reply to message #82439] Tue, 08 May 2007 01:27 Go to previous message
Hi Gonzalo,
gr. Martin
Gonzalo wrote:
> Hi Martin,
> With regards,
> Gonzalo
>> Hi Gonzalo,
>> datastore?
>> gr. Martin
>> Gonzalo wrote:
>>> Hi Martin,
>>> (code continues...)
>>> doesn't
>>> With regards,
>>> Gonzalo
>>>> Hi Gonzalo,
>>>> I
>>>> gr. Martin
>>>> Gonzalo wrote:
>>>>> Hi Martin,
>>>>> With regards,
>>>>> Gonzalo
>>>>>> Hi Gonzalo,
>>>>>> gr. Martin
>>>>>> Gonzalo wrote:
>>>>>>> Hi Martin,
>>>>>>> generate
>>>>>>> (you
>>>>>>> factura.ecore).
>>>>>>> I attach my ecores.
>>>>>>> With regards,
>>>>>>> Gonzalo
>>>>>>> 0 [main] DEBUG
>>>>>>> 723 [main] DEBUG
>>>>>>> an
>>>>>>> epackage
>>>>>>> 724 [main] DEBUG
>>>>>>> epackage
>>>>>>> 724 [main] DEBUG
>>>>>>> epackage
>>>>>>> 856 [main] DEBUG
>>>>>>> Reading ecore file:
>>>>>>> 1363 [main] DEBUG
>>>>>>> 1364 [main] DEBUG
>>>>>>> party
>>>>>>> 1597 [main] DEBUG
>>>>>>> 1597 [main] DEBUG
>>>>>>> 1597 [main] DEBUG
>>>>>>> Parse annotations
>>>>>>> 1608 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> Processing party
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> Processing Party
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1609 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1610 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> Processing extTel
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> 1611 [main] DEBUG
>>>>>>> Processing correoE
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> Processing fax
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> Processing web
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1612 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> Processing Empresa
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> Processing cif
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1613 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> Processing cnae
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> Processing contacto
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1614 [main] DEBUG
>>>>>>> Processing Persona
>>>>>>> 1614 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> Processing nif
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> Processing nombre
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1615 [main] DEBUG
>>>>>>> 1616 [main] DEBUG
>>>>>>> 1616 [main] DEBUG
>>>>>>> 1616 [main] DEBUG
>>>>>>> 1617 [main] DEBUG
>>>>>>> 1622 [main] DEBUG
>>>>>>> Processing fechaNac
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> 1623 [main] DEBUG
>>>>>>> Processing cargo
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> Processing empresa
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1625 [main] DEBUG
>>>>>>> Processing Pdi
>>>>>>> 1625 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1626 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> Processing centro
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1627 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> Processing Pas
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1629 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> Processing centro
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> 1630 [main] DEBUG
>>>>>>> Processing Becario
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1631 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1632 [main] DEBUG
>>>>>>> 1643 [main] DEBUG
>>>>>>> inheritance: single
>>>>>>> 1643 [main] DEBUG
>>>>>>> 1643 [main] DEBUG
>>>>>>> 1643 [main] DEBUG
>>>>>>> 1643 [main] DEBUG
>>>>>>> set
>>>>>>> 1643 [main] DEBUG
>>>>>>> 1649 [main] DEBUG
>>>>>>> strategy
>>>>>>> 1649 [main] DEBUG
>>>>>>> EClass name option:
>>>>>>> 1649 [main] DEBUG
>>>>>>> column
>>>>>>> length: -1
>>>>>>> 1650 [main] DEBUG
>>>>>>> Feature
>>>>>>> as primary key true
>>>>>>> 1650 [main] DEBUG
>>>>>>> case strategy
>>>>>>> 1654 [main] DEBUG
>>>>>>> SQLCaseStrategy
>>>>>>> 1654 [main] DEBUG
>>>>>>> 1654 [main] DEBUG
>>>>>>> Adding
>>>>>>> 1654 [main] DEBUG
>>>>>>> EDataTypes
>>>>>>> 1654 [main] DEBUG
>>>>>>> Processing
>>>>>>> EClasses
>>>>>>> 1654 [main] DEBUG
>>>>>>> 1666 [main] DEBUG
>>>>>>> 1668 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1670 [main] DEBUG
>>>>>>> 1671 [main] DEBUG
>>>>>>> 1671 [main] DEBUG
>>>>>>> 1671 [main] DEBUG
>>>>>>> 1796 [main] DEBUG
>>>>>>> EReference
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> :158)
>>>>>>> at
>>>>>>> at
>>>>>>> :104)
>>>>>>> at
>>>>>> The Netherlands
>>>> The Netherlands
>> The Netherlands
> /* Get data. */
> try {
Re: [Teneo] dataStore.initialize() fails (four .ecore) [message #606636 is a reply to message #82490] Wed, 09 May 2007 07:03 Go to previous message
Hi Martin,
With regards,
Gonzalo
Previous Topic:[teneo-jpox] jdoDatastore initialize failed on with mulitple ecores
Next Topic:Restrict copy/paste for some elemets
Current Time: Sat Jul 19 00:53:27 EDT 2025
Powered by FUDForum. Page generated in 0.07402 seconds
