Home » Archived » BIRT » Is it possible to create "n" GUI tables for "n" records within the database(Separate GUI Table for each record in the database)
Is it possible to create "n" GUI tables for "n" records within the database [message #824320] Mon, 19 March 2012 10:31 Go to next message
I think that "for loop" is needed for this.
I have one table with n records. Let's say it is my table T1.
T1:
ID|STATUS
1 NEW
2 OPEN
3 NEW
T2:
ID|DESCRIPTION
1 DESC1
1 DESC2
2 DESC3
I would like to create NOT ONE table using birt that will show this information, but SEPARATE table for each record in T1 which will show information for both table:
Template and result will be like this:
ID: 1 STATUS: NEW
DESCRIPTION: DESC1
DESCRIPTION: DESC2
And then below that second table (n=2)
ID: 2 STATUS: OPEN
DESCRIPTION: DESC3
And then below third table (n=3)
ID: 3 STATUS: NEW
DESCRIPTION: null
Is this possible?
I will have n separate tables because of n records in T1 and I will have as many descriptions as there are records in T2 table.
Thanks for help.
[Updated on: Mon, 19 March 2012 10:32] by Moderator
Re: Is it possible to create "n" GUI tables for "n" records within the database [message #824361 is a reply to message #824320] Mon, 19 March 2012 11:25 Go to previous message
I guess you only need to separate tables visually, right? I have attached example where grouping is used (birt 2.6.1).
--- edit
For complete reference I have added similar example using filters on slave table.
Tomas
[Updated on: Mon, 19 March 2012 11:32] by Moderator
Previous Topic:Use multiple schema in a birt report
Next Topic:report issue
Current Time: Sun Jul 27 11:26:10 EDT 2025
Powered by FUDForum. Page generated in 0.57339 seconds
