Update resource [message #824146] |
Mon, 19 March 2012 06:09  |
Hey everybody,
I have a little problem, or rather I don't know how to start solving it without what I think is a big work around.
I'm using EMF and working with xml files. I'm trying to get an object out the file, edit it and save it back to the file. Wich is not really a big problem but right now I load the file, get the object, edit the object, delete the original object from the file and save the new one to it. So instead of updating the object I create a new one everytime it edits.
This is no problem aslong as there are like 5-10 objects in the file, but I'm guessing that once this builds up, my performance won't be great. Is there like an update method on resource? I know there is a save and a delete method so I was wondering if there was some kind of update aswell.
Re: Update resource [message #824153 is a reply to message #824146] |
Mon, 19 March 2012 06:14   |
Comments below.
On 19/03/2012 11:09 AM, El Shorty wrote:
> Hey everybody,
> to it.
Why not modify the object itself?
Why? How are you doing this?
I'd suggest you measure performance and not make assumption.
No. If you think about it, there's nothing in Java that's lets you
easily write just part of a file. You need to write all the bytes for
the new version.
No.
Re: Update resource [message #824170 is a reply to message #824153] |
Mon, 19 March 2012 06:47   |
That is what I think I'm doing but when I save it, I add it as a new object so I have to delete the old object, I don't know how to overwrite it. This is what I do:
This gets me the object I select in my tree from a viewer:
Person person = (Person) item;
GroupLabelProvider labelProvider = new GroupLabelProvider();
final IWorkbenchWindow window = PlatformUI.getWorkbench().getActiveWorkbenchWindow();;
IWorkbenchPage page = window.getActivePage();
PersonEditorInput input = new PersonEditorInput(person);
try {
page.openEditor(input, SecondPersonEditor.ID);
} catch (PartInitException e) {
e.printStackTrace();
So this opens my editor with all the properties from this person. Say I edit them than I save it again wich I do by calling the savemethod I worte, I'm guessing that there might be an easier way.
This is what I do in the savemethod:
loadResource = resourceSet.getResource(fileURI, true);
list = loadResource.getContents();
list.add(object);
resource = resourceSet.createResource(fileURI);
resource.getContents().addAll(list);
try {
final Map<Object, Object> saveOptions = new HashMap<Object, Object>();
saveOptions.put(Resource.OPTION_SAVE_ONLY_IF_CHANGED, Resource.OPTION_SAVE_ONLY_IF_CHANGED_MEMORY_BUFFER);
saveOptions.put(XMLResource.OPTION_KEEP_DEFAULT_CONTENT, true);
resource.save(saveOptions);
} catch (IOException e1) {
e1.printStackTrace();
Re: Update resource [message #824212 is a reply to message #824170] |
Mon, 19 March 2012 07:53   |
Comments below.
> overwrite it.
You just modify it and save the resource containing it and that will
write out your changes.
> This is what I do:
> try {
> list.add(object);
You should just save the resource you loaded in the first place.
> try {
> Object>();
Have a look at the generated editor. All it does is save the resources
in the resource set.
Re: Update resource [message #824213 is a reply to message #824175] |
Yes, it's as easy as that.
On 19/03/2012 11:56 AM, El Shorty wrote:
> I found the solution by using this:
> bryanhunt.wordpress.com/2011/03/15/mongo-emf/
> I didn't know about the eResource option.. All I had to do was instead
> of calling my saveMethod use eResource().save(null)
> I want to thank you for the help ed, especially since that site is
> also made with your help.
FUDForum. Page generated in 0.04135 seconds
