Home » Newcomers » Newcomers » Hello World!
Hello World! [message #822716] Sat, 17 March 2012 02:05 Go to next message
Hi! Sad
There are three weeks I try to create my first project "Hello, World!" It is impossible to me overcome errors of
compilation of the IDE. I have OS XP SP 3 Eclipse indigo classic. There are simple means - build -> rebuild, project
-clean, automatic compilation--- do not help. The avtogenerated folder the gen is empty. I simply do not find file
R.java anywhere.... I so understand, that it is necessary to compile manually files .... I tried .... It is impossible ... ...
here are screenshots ...
Excuse for my bad English...
index.php/fa/7570/0/
  • Attachment: error2.jpg
    (Size: 142.39KB, Downloaded 816 times)
Re: Hello World! [message #822881 is a reply to message #822716] Sat, 17 March 2012 08:20 Go to previous messageGo to next message
On 03/17/2012 01:05 AM, Andrey Starikov wrote:
> Hi! :(
This project appears much more complicated then the typical Hello World
program. You appear to be working with Android. Android and the
Android tools are provided by Google. They build their tools on top of
Eclipse. The Eclipse forums don't provide support for Android
development. You need to use the Google/Android support mechanisms.
In the case of your program, it isn't completely clear what R is. It
appears to be a class, but the class name of R would be quite strange.
If it really is a class, then it needs to imported into your class.
If it is supposed to be a variable, then it needs to be declared somewhere.
Re: Hello World! [message #822918 is a reply to message #822716] Sat, 17 March 2012 09:45 Go to previous messageGo to next message
On 2012.03.17 0:05, Andrey Starikov wrote:
> Hi! :(
I understand your frustration; I went through this too.
First, for the R.java problem, check out my notes at
http://www.javahotchocolate.com/tutorials/android.html#r-java
Second, check out Lars Vogel's fabulous Android tutorials at
http://www.vogella.de.
Third, understand that this had nothing to do with Eclipse, so your best
bet for support is an Android community forum. In my article, I list
several:
http://www.javahotchocolate.com/tutorials/android.html#support
Best of luck,
Russ
Re: Hello World! [message #822994 is a reply to message #822918] Sat, 17 March 2012 12:05 Go to previous message
Many thanks friends for the help! You have very much helped me.
Previous Topic:Eclipse Plugins in Linux Pardus
Next Topic:DDMS GPX file import problems
Current Time: Sat Jul 26 20:34:19 EDT 2025
Powered by FUDForum. Page generated in 0.07799 seconds
