Home » Eclipse Projects » Remote Application Platform (RAP) » Unable to access servlet when deployed on Tomcat
Unable to access servlet when deployed on Tomcat [message #82178] Thu, 10 April 2008 03:12 Go to next message
Hi all,
Recently I've tried to deploy our RAP application to Tomcat.
We use browser widget pointing to a servlet in our welcome view which
works fine under Jetty, but in Tomcat it throws something like unable to
find the servlet.
To register servlet we have defined it in our plugin.xml:
<extension id="com.fearnot.ui.resources"
point="org.eclipse.equinox.http.registry.resources">
<resource alias="/web" base-name="/web"/>
</extension>
<extension id="com.fearnot.ui.servlets"
point="org.eclipse.equinox.http.registry.servlets">
<servlet alias="/fes" class="com.fearnot.ui.servlets.MainServlet"
load-on-startup="true"/>
</extension>
I suspect that I can't deploy application with internal browser widget to
Tomcat as it is.
Do I have to move the declaration above to the web.xml ?
Any help would be greatly appreciated.
Best Regards,
Setya
Re: Unable to access servlet when deployed on Tomcat [message #82246 is a reply to message #82178] Thu, 10 April 2008 06:29 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
there should be no difference in servlet registration for deployment on
tomcat. Probably your deployment archive isn't correct. Please take a
look at the log entries and follow the thread regarding deployment of
RAP applications in this newsgroup.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Setya [mailto:jsetya@gmail.com]
Bereitgestellt: Donnerstag, 10. April 2008 09:12
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Unable to access servlet when deployed on Tomcat
Betreff: Unable to access servlet when deployed on Tomcat
Hi all,
find the servlet.
<resource alias="/web" base-name="/web"/> </extension>
</extension>
to Tomcat as it is.
Best Regards,
Setya
Re: Unable to access servlet when deployed on Tomcat [message #82340 is a reply to message #82246] Fri, 11 April 2008 02:01 Go to previous messageGo to next message
Frank,
I've followed tutorial written by Elias here :
http://rapblog.innoopract.com/2007/12/rap-deployment-part-2- deploying-your.html
Actually the application is successfully deployed, I've inspected the OSGI
console and all bundles are started. But when browser widget in our
viewpart try to access url '/fes', it says 'The requested resource (/fes)
is not available'.
BTW, which log entries are you talking about ?
Setya
Re: Unable to access servlet when deployed on Tomcat [message #82368 is a reply to message #82340] Fri, 11 April 2008 04:07 Go to previous messageGo to next message
are you sure that your build.properties file contains the plugin.xml?
That's a common mistake.
Besides the common logs available at the tomcat's log directory, there
is a log in case of problems written by equinox at '<path to your tomcat
installation>\work\Catalina\localhost\<RAP
application>\eclipse\workspace\.metadata\.log'
Ciao
Frank
Bereitgestellt: Freitag, 11. April 2008 08:02
Betreff: Re: Unable to access servlet when deployed on Tomcat
Frank,
> on tomcat. Probably your deployment archive isn't correct. Please take
> a look at the log entries and follow the thread regarding deployment
> of RAP applications in this newsgroup.
ur.html
OSGI console and all bundles are started. But when browser widget in our
(/fes) is not available'.
Setya
Re: Unable to access servlet when deployed on Tomcat [message #82395 is a reply to message #82368] Fri, 11 April 2008 06:42 Go to previous messageGo to next message
Frank,
This is the content of my build.properties :
source.. = src/
output.. = bin/
bin.includes = META-INF/,\
plugin.xml,\
web/,\
plugin.properties
The web/ folder contains all the web stuff like jsp and WEB-INF folder.
> installation>workCatalinalocalhost<RAP
> application>eclipseworkspace.metadata.log'
The log from catalina just show the Tomcat startup process and no .log
file produced under .metadata folder.
Setya
Re: Unable to access servlet when deployed on Tomcat [message #82455 is a reply to message #82395] Fri, 11 April 2008 09:00 Go to previous messageGo to next message
at the moment I'm running a little bit out of options. What is the exact
URL you are using to access the application on tomcat?
Ciao
Frank
Bereitgestellt: Freitag, 11. April 2008 12:42
Frank,
source.. = src/
output.. = bin/
plugin.xml,\
web/,\
plugin.properties
> tomcat
Setya
Re: Unable to access servlet when deployed on Tomcat [message #82483 is a reply to message #82455] Fri, 11 April 2008 09:25 Go to previous messageGo to next message
Frank,
The code to access the servlet is like the following :
public void createPartControl(Composite parent)
browser.setUrl("/fes?mode=login");
One other possibility crossed in my mind, is it possible that I include
too many plugin jars in the feature.xml that interferes with Tomcat's ?
Here's our list of plugins in the feature.xml:
org.eclipse.core.contenttype
org.eclipse.equinox.registry
org.eclipse.rap.rwt
org.eclipse.core.runtime.compatibility.auth
org.eclipse.osgi
org.eclipse.rap.ui
org.eclipse.rap.ui.forms
org.eclipse.rap.ui.workbench
org.eclipse.core.jobs
org.apache.commons.logging
org.eclipse.equinox.common
org.eclipse.rap.ui.views
com.farbeyond.ui
org.eclipse.core.commands
org.eclipse.core.expressions
org.eclipse.rap.jface
org.eclipse.equinox.app
org.eclipse.equinox.preferences
org.apache.commons.el
org.eclipse.osgi.services
org.eclipse.equinox.http.servlet
com.farbeyond.core
org.eclipse.equinox.http.servletbridge
org.eclipse.update.configurator
javax.servlet.jsp
org.eclipse.equinox.jsp.jasper.registry
org.apache.jasper
Setya
Re: Unable to access servlet when deployed on Tomcat [message #82544 is a reply to message #82483] Fri, 11 April 2008 10:54 Go to previous messageGo to next message
Hi again,
this reminds me at a thread about the file upload widget that uses a
seperate servlet for the actual upload. A similar problem was reported
and a nice guy proposed a solution which would adapted to your case look
like this:
String application = RWT.getRequest().getContextPath();
application = application.trim();
browser.setUrl(application + "/fes?mode=login");
Maybe this helps in your case too.
Ciao
Frank
Bereitgestellt: Freitag, 11. April 2008 15:26
Frank,
> exact URL you are using to access the application on tomcat?
public void createPartControl(Composite parent) { ..
org.eclipse.rap.rwt
org.eclipse.osgi
org.eclipse.rap.ui
com.farbeyond.ui
com.farbeyond.core
javax.servlet.jsp
org.apache.jasper
Setya
Re: Unable to access servlet when deployed on Tomcat [message #82830 is a reply to message #82544] Mon, 14 April 2008 08:22 Go to previous message
Frank,
Works like a charm.
Thank you so much.
Best Regards,
Setya
Previous Topic:Split of RWT into host and fragment
Next Topic:Double & in setPartName
Current Time: Sat Jul 19 04:28:00 EDT 2025
Powered by FUDForum. Page generated in 0.05954 seconds
