Home » Language IDEs » C / C++ IDE (CDT) » Eclipse 3.0M3 and CDT
Eclipse 3.0M3 and CDT [message #79888] Sun, 07 September 2003 10:25 Go to next message
Originally posted by: crusader.far-galaxy.de
I've tested the Eclipse 3.0M2 whith CDT it works correctly for me,
but after updating 3.0M2 to 3.0M3 the c editor refused to open cpp files.
Does anyone know how to fix this?
Thanks in advance
Sebastian
Re: Eclipse 3.0M3 and CDT [message #79949 is a reply to message #79888] Mon, 08 September 2003 16:02 Go to previous messageGo to next message
Originally posted by: dschaefe.ca.ibm.com
There has been an API change (unfortunately internal) that has broken the
CDT Editor for 3.0M3. Right now, I'm not sure how to fix this...
Doug
"Sebastian Fohler" <crusader@far-galaxy.de> wrote in message
news:bjfei1$9i9$1@eclipse.org...
> Thanks in advance
> Sebastian
Re: Eclipse 3.0M3 and CDT [message #80485 is a reply to message #79949] Wed, 17 September 2003 15:58 Go to previous messageGo to next message
Originally posted by: jmricker.eos.ncsu.edu
"Doug Schaefer" <dschaefe@ca.ibm.com> wrote in
news:bjin6k$75r$1@eclipse.org:
> the CDT Editor for 3.0M3. Right now, I'm not sure how to fix this...
> Doug
>> files. Does anyone know how to fix this?
>> Thanks in advance
>> Sebastian
(Windows XP, Eclipse 3.0)
Is this problem also responsible for this problem: I'm new to Eclipse so
I've downloaded Eclipise 3.0. I used Help -> Software Updates -> Find and
Install to install CDT and used
http://update.eclipse.org/tools/cdt/updates/release as the update URL.
When I select and add the Windows CDT plugin, I get an error saying:
Eclipse C/C++ Development Tools (Windows) (1.1.0): Update conflict
detected (see details). Please deselect this update and try again.
Eclipse C/C++ Development Tools (1.1.0): Feature requires plug-in
"org.eclipse.platform (2.1.0)", or compatible.
Sounds like if I want to use CDT, I'll need to remove Eclipse 3.0 and go
back to a version <=2.1.0? Any way around this?
Jody
Re: Eclipse 3.0M3 and CDT [message #81173 is a reply to message #80485] Fri, 26 September 2003 13:15 Go to previous messageGo to next message
Unfortunately, yes. CDT 1.1 and CDT 1.2 will only work on Eclipse 2.1 and
not on Eclipse 3.0 M3 and later. Equally unfortunately, there doesn't
appear to be a quick workaround in the code of the CDT to address this.
Luckily, it is possible to have as many copies and versions of Eclipse
installed in a machine at one time so you won't have to remove 3.0.
We will be working early in the next release of CDT 2.0 to get up and
running on Eclipse 3.0. This should happen by Eclipse 3.0 M5 and earlier in
the CDT nightly builds.
Doug
"Jody" <jmricker@eos.ncsu.edu> wrote in message
news:Xns93F9A2BB94D8Anoemailnonenone@204.138.98.10...
> > Doug
> >> Thanks in advance
> >> Sebastian
> Thanks
> Jody
Re: Eclipse 3.0M3 and CDT [message #82084 is a reply to message #81173] Sat, 04 October 2003 00:57 Go to previous messageGo to next message
if you think about it, sticking with eclipse 2.1 is not good strategy.
since cdt is a 'bleeding-edge' technology, the type of person who is
willing to try it and use it is (obviously) someone who wants to learn
about/use bleeding edge technology. probably almost all eclipse users
who fit into this category are using eclipse 3.0, because it too is
bleeding-edge. since cdt does not work with 3.0, these users are not
using cdt.
conversely, it is reasonable to assume that many who use eclipse 2.1
instead of 3.0 do so because it is stable, 'tried and true' technology.
these people use 2.1 specifically because it is not likely to have bugs
which will cause them to lose work/productivity, and because the
procedure for accomplishing any particular task with 2.1 is the same as
it was yesterday and will be the same tomorrow. these people are
extremely unlikely to be interested in using cdt because it is still too
'bleeding edge' for them.
in short, the policy of developing cdt only for eclipse 2.1 is probably
severely limiting the number of people who are willing to test it. since
*contributers* in open-source projects are always people who first
use/test the product and become excited about it, this policy severely
limits the number of potential cdt contributers. it is likely some of
these potential contributers are very talented, and would be a great
boon to the cdt development effort. cdt will never get these
contributers, because they can not use cdt.
although i am interested in the concept of a unified ide, i do not use
cdt precisely because it does not work with eclipse 3.0. i do not have
the time or inclination to run two separate versions of the same ide
just to try one product. i instead put my efforts into the dev-cpp ide
(www.bloodshed.org). i'm sure there are many others like me.
does this make sense?
alvin
Re: Eclipse 3.0M3 and CDT [message #82099 is a reply to message #82084] Sat, 04 October 2003 01:02 Go to previous messageGo to next message
pardon me, the dev-cpp link should read ' www.bloodshed.net '.
-alvin
Re: Eclipse 3.0M3 and CDT [message #82141 is a reply to message #82084] Sun, 05 October 2003 20:37 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
Personally I agree, and I had to stop using CDT for the same reason. The
Eclipse plain text editor and external tool launches for builds had to
suffice. Fortunately, development for the next version of CDT will be
starting soon and will be based on Eclipse 3.
Ed Burnette, co-author Eclipse in Action (www.manning.com/gallardo)
"Alvin Thompson" <nobody@nowhere.com> wrote in message
news:3F7E5350.4070808@nowhere.com...
> just to try one product. ...
Re: Eclipse 3.0M3 and CDT [message #83153 is a reply to message #82084] Wed, 15 October 2003 11:31 Go to previous messageGo to next message
The CDT is currently integrated into commercial products and we have to take
that into account. For CDT 1.2, there is a need to maintain the connection
with Eclipse 2.1.x. CDT 2.0, on the other hand, will line up with Eclipse
3.0. We just need to figure out the right timing to make the cutover.
Doug.
> using cdt.
> alvin
Re: Eclipse 3.0M3 and CDT [message #83541 is a reply to message #83153] Sun, 19 October 2003 08:16 Go to previous message
I would vote for ASAP.
Steve
"Doug Schaefer" <dschaefe@ca.ibm.com> wrote in message
news:bmjp82$djl$1@eclipse.org...
take
connection
> Doug.
> > using cdt.
> > alvin
Previous Topic:Compiler in Project Build Properties?
Next Topic:Instructions needed how to customize an Eclipse tool-chain for Borland C++ 5.5 !
Current Time: Sat Nov 08 08:38:16 EST 2025
Powered by FUDForum. Page generated in 0.03680 seconds
