Home » Language IDEs » C / C++ IDE (CDT) » Error in inclusion of CDT in galileo Java IDE
Error in inclusion of CDT in galileo Java IDE [message #821003] Wed, 14 March 2012 16:49 Go to next message
Hey! I just downloaded Eclipse Galileo for Java Developers. Now, in order to use both C/C++ and Java within the same Eclipse, I used the install new software thing and instal the CDT 6.0.2 for Eclipse Galileo. I installed succesfully, but i can never build a project in C/C++ because this error occurs:
Description Resource Path Location Type
Error launching external scanner info generator (g++ -E -P -v -dD D:/FACULTATE/PP/laboratoare/.metadata/.plugins/org.eclipse.cdt.make.core/specs.cpp) sort Unknown C/C++ Problem
Also, everytime I try including smthing, like <stdio.h>, it gives the warning : "Unresolved inclusion" ! ALL THESE ERRORS APPEAR ONLY IN C/C++ PROGRAMS!
Can anyone help me please?
Re: Error in inclusion of CDT in galileo Java IDE [message #821365 is a reply to message #821003] Thu, 15 March 2012 05:02 Go to previous messageGo to next message
You should install a C/C++ compiler. See Help: Before you start
Re: Error in inclusion of CDT in galileo Java IDE [message #821681 is a reply to message #821365] Thu, 15 March 2012 13:28 Go to previous message
I downloaded some other tools from where you said. Thx. It works on Eclipse Helios, but in Galileo still gives the errors.. I guess I'll use them both:D
Previous Topic:Consistent paths...HOW!?
Next Topic:Linking static library does not work in Ubuntu 11.04
Current Time: Sun Jul 20 21:50:12 EDT 2025
Powered by FUDForum. Page generated in 0.03999 seconds
