Auto-refreshing ViewPart by using Job [message #820980] |
Wed, 14 March 2012 16:23  |
I have an issue updating a view. It's just a label that I am hoping to present the current time.
public class TestView extends ViewPart {
private Label label;
private String jobId;
private Display display;
public TestView() {
System.out.println("TestView.TestView()");
public void createPartControl(Composite parent) {
this.setContentDescription("This is just a test.");
GridLayoutFactory.fillDefaults().applyTo(parent);
label = new Label(parent, SWT.BOLD | SWT.BORDER);
jobId = UUID.randomUUID().toString();
System.out.println("Job ID: " + jobId);
display = parent.getDisplay();
Job job = new Job(jobId) {
protected IStatus run(IProgressMonitor monitor) {
// Assume this getTime() method takes a long time
final String newString = GregorianCalendar.getInstance()
.getTime().toString();
System.out.println("new Time: " + newString);
display.asyncExec(new Runnable() {
public void run() {
// Updating UI has to happen in a thread that is called
// by display.asyncExec.
updateLabel(newString);
return Status.OK_STATUS;
job.schedule();
public void setFocus() {
System.out.println("TestView.setFocus()");
label.setFocus();
private void updateLabel(String newString) {
System.out.println("TestView.updateLabel()");
if (!label.isDisposed()) {
label.setText(newString);
The current time stamp will show up fine initially, but it will never get updated anymore. How do I
1) Update this label with the current time continuously? I know I can use UICallBack but I think the Job should handle this for me automagically.
2) Update this label when user gets to the page (pull model instead of push).
Thank you,
Ronald
Re: Auto-refreshing ViewPart by using Job [message #821680 is a reply to message #820980] |
Thu, 15 March 2012 13:21   |
Hi Ronald,
your code looks good. The only thing missing is a loop in your job. Currently you only update the label once :).
See attached file.
Elias.
begin 644 TestView.java
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M;W5T+G!R:6YT;&XH(E1E<W16:65W+E1E<W16:65W*"DB*3L*"7T*"B`@("`@
M("`@0$]V97)R:61E"@EP=6)L:6,@=F]I9"!C<F5A=&5087)T0V]N=')O;"A#
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M36]N:71O<B!M;VYI=&]R*2!["@D)"0EW:&EL92`H(6QA8F5L+FES1&ES<&]S
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M17AE8RAN97<@4G5N;F%B;&4H*2;G1E<G)U<'1E9$5X8V5P=&EO;B!E*2!["@D)
M"0D)"64N<')I;G13=&%C:U1R86-E*"D["@D)"0D)"6)R96%K.PH)"0D)"7T*
M"0D)"7T*"0D)"7)E='5R;B!3=&%T=7,N3TM?4U1!5%53.PH)"0E]"@D)?3L*
M"0EJ;V(N<V-H961U;&4H*3L*"7T*"@E`3W9E<G)I9&4*"7!U8FQI8R!V;VED
M('-E=$9O8W5S*"D@>PH)"5-Y<W1E;2YO=70N<')I;G1L;B@B5&5S=%9I97<N
M<V5T1F]C=7,H*2(I.PH)"6QA8F5L+G-E=$9O8W5S*"D["@E]"@H)<')I=F%T
M92!V;VED('5P9&%T94QA8F5L*%-T<FEN9R!N97=3=')I;F<I('L*"0E3>7-T
M96TN;W5T+G!R:6YT;&XH(E1E<W16:65W+G5P9&%T94QA8F5L*"DB*3L*"0EI
M9B`H(6QA8F5L+FES1&ES<&]S960H*2D@>PH)"0EL86)E;"YS971497AT*&YE
2=U-T<FEN9RD["@D)?0H)?0I]
end
Elias Volanakis | http://eclipsesource.com
elias (AT) eclipsesource.com | @evolanakis
Re: Auto-refreshing ViewPart by using Job [message #821758 is a reply to message #821047] |
Thu, 15 March 2012 15:42  |
Hi Ronald,
the part listener gets call for EVERY view, i.e. not only your particular view.
However, you can use the 'part' parameter to figure out if the notification is relevant for you, i.e.:
public void partActivated(IWorkbenchPart part) {
if (part == this) {
System.out.println("TestView.partActivated() " + part);
public void partDeactivated(IWorkbenchPart part) {
if (part == this) {
System.out.println("TestView.partDeactivated() " + part);
Hope this helps,
Elias.
Re: Auto-refreshing ViewPart by using Job [message #821761 is a reply to message #821047] |
Hi Ronald,
if (part == this) {
if (part == this) {
Hope this helps,
Elias.
FUDForum. Page generated in 0.04346 seconds
