Home » Newcomers » Newcomers » Adobe Flash Builder plugin for eclipse
Adobe Flash Builder plugin for eclipse [message #820855] Wed, 14 March 2012 12:54 Go to next message
Is there any Adobe Flash Builder plugin available for Eclipse Indigo? If so, how do I install it?
I have Windows 7 (64-bit) machine with Eclipse Indigi already installed on it. I have already created workspace for my Java project and it has a flex component that I will need to work on now. I do not wish to install Adobe flash Builder separately (it will unnecessarily complecate the things!!!) and hence keen to know if any Adobe Flash Builder plugin is available for eclipse Indigo?
Any help/suggestion appreciated.
Thanks Smile
Re: Adobe Flash Builder plugin for eclipse [message #820872 is a reply to message #820855] Wed, 14 March 2012 13:14 Go to previous messageGo to next message
On 3/14/2012 10:54 AM, Smita Tendulkar wrote:
> Hello,
> Thanks :)
Since Eclipse doesn't create or maintain Flex tools for use with
Eclipse, this is a matter you should take up with Adobe or its developer
community instead.
Re: Adobe Flash Builder plugin for eclipse [message #821651 is a reply to message #820855] Thu, 15 March 2012 12:46 Go to previous messageGo to next message
Smita Tendulkar wrote on Wed, 14 March 2012 12:54
Hmm...I don't think that install Adobe Flash Builder will complicate the things. It's just a modified version of Eclipse which supports Flash development.
Re: Adobe Flash Builder plugin for eclipse [message #917083 is a reply to message #820872] Wed, 19 September 2012 16:02 Go to previous messageGo to next message
Even I am looking for Adobe Flash Builder plugin for Eclipse Indigo and
plugins to run my java web applications from Adobe Flash Builder 3.
Any help/suggestion appreciated here.
Thanks & Regards,
Sridhar Goranti
Re: Adobe Flash Builder plugin for eclipse [message #917094 is a reply to message #917083] Wed, 19 September 2012 16:14 Go to previous messageGo to next message
On 9/19/2012 2:02 PM, Sridhar Goranti wrote:
> Hello,
> Thanks & Regards,
> Sridhar Goranti
If you are having trouble finding, installing or using the Adobe Flash
Builder development tools, you should be aware that they are written on
top of the Eclipse platform by the Adobe community and not by the
eclipse.org community.
You can wait here for someone who happens to know if you like.
I found a lot of promising links by Googling "flash builder eclipse
plugins".
Re: Adobe Flash Builder plugin for eclipse [message #917095 is a reply to message #917083] Wed, 19 September 2012 16:19 Go to previous message
For the Adobe Flash Builder, If you want to run java applications.
While installing Adobe Flash Builder it self, we need choose few options as attached.
Thanks & Regards,
Sridhar Goranti
USA
[Updated on: Wed, 19 September 2012 16:23] by Moderator
Previous Topic:Eclipse C/C++ help, gcc not found.
Next Topic:Eclipse Just Stopped Working?
Current Time: Mon Nov 03 03:40:26 EST 2025
Powered by FUDForum. Page generated in 0.09615 seconds
