Home » Eclipse Projects » Rich Client Platform (RCP) » Nullpointerexception (opening editor)
Nullpointerexception (opening editor) [message #819924] Tue, 13 March 2012 09:56 Go to next message
Hey,
I think this belongs here. I'm working with RCP and EMF.
I've made a view and am trying to open this in an editor trough the addpages method but I keep getting an nullpointerexception.
The complete error:
!SESSION 2012-03-13 14:54:17.969 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_03
Framework arguments: -product smartapps.smartsignature.ui.product
Command-line arguments: -product smartapps.smartsignature.ui.product -data C:\Users\...\Workspace/../runtime-smartsignature.product -dev file:C:/Users/.../Workspace/.metadata/.plugins/org.eclipse.pde.core/smartsignature.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 4 0 2012-03-13 14:54:24.370
!MESSAGE Unable to create editor ID smartapps.smartsignature.ui.editors.personEditor: An unexpected exception was thrown.
!STACK 0
at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor.java:473)
at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1067)
at org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEditor.java:603)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:352)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at smartapps.smartsignature.ui.views.LeftView$2.mouseDown(LeftView.java:75)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:191)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at smartapps.smartsignature.ui.views.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
The code when I try to open the editor:
		btnNew.addMouseListener(new MouseAdapter() {
			public void mouseDown(MouseEvent e) {
				PersonEditorInput editorInput = new PersonEditorInput();
				IWorkbenchWindow window = PlatformUI.getWorkbench().getActiveWorkbenchWindow();
				IWorkbenchPage page = window.getActivePage();
				try {
					page.openEditor(editorInput, PersonEditor.ID);
				} catch (PartInitException e1) {
					e1.printStackTrace();
This is the code from the editor to add the view:
	protected void addPages() {
		PersonEditorInput editorInput = (PersonEditorInput) getEditorInput();
		personView = new PersonView();
		person = editorInput.getPerson();
		setPartName(person.getFirstName());
		try {
			addPage(personView);
		} catch (PartInitException e) {
			e.printStackTrace();
			throw new RuntimeException(e);
And finally the PersonEditorInput
package smartapps.smartsignature.ui.editors;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IPersistableElement;
import smartapps.smartsignature.model.smartsignature.Person;
import smartapps.smartsignature.model.smartsignature.SmartsignatureFactory;
public class PersonEditorInput implements IEditorInput {
	private Person person;
	private boolean newItem = false;
	private TableViewer viewer;
	public PersonEditorInput(){
		SmartsignatureFactory factory = SmartsignatureFactory.eINSTANCE;
		Person ps = factory.createPerson();
		this.person = ps;
		newItem = true;
		person.setFirstName("Nieuw");
    public PersonEditorInput(TableViewer viewer){
    	this.viewer = viewer;
		this.person = ps;
		newItem = true;
    public PersonEditorInput(Person person) {
        this.person = person;
Re: Nullpointerexception (opening editor) [message #820790 is a reply to message #819924] Wed, 14 March 2012 11:11 Go to previous messageGo to next message
Got this fixed, I was trying something I think really isn't possible. Anyway I figured out I was looking at this the wrong way so instead of working with a view I'm just directly working on the editor wich works fine. However I got another question, hoping anyone still gonna read this topic Razz
I have a view on the left with a treeviewer listing groups. When I click on a group a groupeditor opens wich allows me to either edit or add a new view. However when I do this the treeviewer in the left view doesn't get updated. Anyone knows how I can do this?
Re: Nullpointerexception (opening editor) [message #821319 is a reply to message #820790] Thu, 15 March 2012 03:38 Go to previous message
I am not sure if I understand this correct. Do you mean that your editor modifies the model of the treeviewer and the changes are not reflected in the viewer? Then maybe it's as simple as refreshing the viewer after model change?
Previous Topic:Open custom editor from cnf
Next Topic:Restore expanded tree items in CommonNavigator
Current Time: Wed Jul 23 07:41:56 EDT 2025
Powered by FUDForum. Page generated in 0.09187 seconds
