Home » Eclipse Projects » Remote Application Platform (RAP) » [Text] new Text(parent, SWT.MULTI | SWT.V_SCROLL);
[Text] new Text(parent, SWT.MULTI | SWT.V_SCROLL); [message #820374] Tue, 13 March 2012 23:29 Go to next message
new Text(parent, SWT.MULTI | SWT.V_SCROLL); used to create a text area with vertical scrolling in RAP 1.4
1.5 nightly doesn't scroll.
Where did it go? It's a subclass of Scrollable so should support V_SCROLL and H_SCROLL
Re: [Text] new Text(parent, SWT.MULTI | SWT.V_SCROLL); [message #820473 is a reply to message #820374] Wed, 14 March 2012 02:58 Go to previous messageGo to next message
Hi Chris,
if it's working as expected in RAP 1.4 but not in latest nightly, it's
probably a regression. Could you open a bugzilla about this issue. What
do you mean by doesn't scroll? Vertical scrollbar is missing or it is
there but you couldn't drag it?
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: [Text] new Text(parent, SWT.MULTI | SWT.V_SCROLL); [message #820574 is a reply to message #820374] Wed, 14 March 2012 05:43 Go to previous messageGo to next message
Hi.
I just want to give some notes for a better technical overview.
The RAP Text widget does not "support" V_SCROLL and H_SCROLL insofar
that it is based on the html textarea element. (This was also true in
1.4.) This element always scrolls if the text doesn't fit, and shows no
scrollbars if it does fit. Its not possible to change that.
To properly support H_SCROLL and V_SCROLL, a completely new
implementation of Text would be needed. In 1.5 we did make changes to
Text, but its still based on textarea. Thats why i'm not sure how there
could be any differences between 1.4 and 1.5 regarding scrolling.
Greetings,
Tim
Am 14.03.2012 04:29, schrieb Chris Fairhall:
Tim Buschtöns
Re: [Text] new Text(parent, SWT.MULTI | SWT.V_SCROLL); [message #820985 is a reply to message #820574] Wed, 14 March 2012 16:31 Go to previous messageGo to next message
in 1.5 nightly, the Text widget still scrolls when text does not fit like it used to, but scroll bars nolonger appear.
public class EntryPoint3 implements IEntryPoint {
	public int createUI() {
		new Display();
		final Shell shell = new Shell(SWT.SHELL_TRIM);
		shell.setSize(200, 200);
		Text text = new Text(shell, SWT.BORDER | SWT.V_SCROLL | SWT.MULTI | SWT.WRAP);
		text.setBounds(50, 50, 100, 105);
		shell.setVisible(true);
		return 0;
This snippet should have a vertical scrollbar visible when there is too much text to show in the widget. It doesn't. You can still scroll up and down using the up and down keys though.
Works as expected in SWT on windows and RWT 1.4
Re: [Text] new Text(parent, SWT.MULTI | SWT.V_SCROLL); [message #820988 is a reply to message #820985] Wed, 14 March 2012 16:34 Go to previous message
logged [bug 374312]
Re: [Text] new Text(parent, SWT.MULTI | SWT.V_SCROLL); [message #820990 is a reply to message #820574] Wed, 14 March 2012 16:31 Go to previous message
new Display();
return 0;
Previous Topic:RAP dynamically generated perspective
Next Topic:Backspace in non editable textfield triggers browser action
Current Time: Sun Jul 27 08:08:06 EDT 2025
Powered by FUDForum. Page generated in 0.08094 seconds
