Home » Archived » Riena » Plug-in versions of the Riena toolbox(Toolbox brings along newer versions of Riena some plug-ins)
icon5.gif  Plug-in versions of the Riena toolbox [message #820515] Wed, 14 March 2012 04:20 Go to next message
Hi all,
when I install the Riena toolbox from the given update site (download.eclipse.org/rt/riena/toolbox/20110926), I get v4.0.0 versions of some Riena plug-ins, e.g. org.eclipse.riena.ui.swt and org.eclipse.riena.ui.common. These plug-ins shadow the v3.0.0 versions that were installes into my target platform when I set up Riena for RCP from the update site download.eclipse.org/rt/riena/3.0.0.0/rcp/.
Now some of my Riena plug-ins have different version numbers than others. I know that, in principle, this is not problem and after changing some lines of code to the new v4.0.0 API everything works fine - but I'm wondering if there's a toolbox version with v3.0.0 plug-ins? And why does the toolbox currently come with the v4.0.0 plug-ins when there is no final Riena v4.0.0 yet?
U
Re: Plug-in versions of the Riena toolbox [message #820524 is a reply to message #820515] Wed, 14 March 2012 04:32 Go to previous messageGo to next message
Am 14.03.12 09:20, schrieb Uwe San:
> Hi all,
> U
I think something in your setup is wrong if the IDE plugins shadows targetplatform plugins. In our setup they are
totally unrelated.
If you look at this page http://wiki.eclipse.org/index.php?title=Riena/GettingStarted you see the setup that we have in
mind....
Note that it says that you should start with an empty Target Platform. (Maybe you start with your IDE as Target Platform
????) Then you install Equinox Targets, RCP and Riena.
If you have this setup, no installation into the IDE will conflict with your target platform.
hope that helps
christian
Re: Plug-in versions of the Riena toolbox [message #820529 is a reply to message #820524] Wed, 14 March 2012 04:45 Go to previous messageGo to next message
Hi Christian,
thanks for your comments, they made me aware of the erroneous setup of my target platform. Smile
Yet, one question is still open: why does the toolbox currently come with the v4.0.0 plug-ins when there is no final Riena v4.0.0 yet?
U
Re: Plug-in versions of the Riena toolbox [message #821280 is a reply to message #820529] Thu, 15 March 2012 02:21 Go to previous messageGo to next message
Am 14.03.12 09:45, schrieb Uwe San:
> Hi Christian,
> thanks for your comments, they made me aware of the erroneous setup of my target platform. :)
> Riena v4.0.0 yet?
> U
In other words the Toolbox contains milestone bundles of Riena, right ? We consider them to be quite stable, so thats
why we use them. There are also very stable Riena bundles for 4.0. 4.0.0.M6 is coming next week. Milestone bundles are
by its nature NOT necessarily unsafe to use. We ourselves use milestone versions in production environments since we do
a lot of testing for them as well.
does that help ?
christian
Re: Plug-in versions of the Riena toolbox [message #821318 is a reply to message #821280] Thu, 15 March 2012 03:35 Go to previous message
Yes, this helps. So the toolbox is a little bit of a testing ground for you.
U
Previous Topic:Riena and Guice
Next Topic:Riena 4.0.0.M6 is out
Current Time: Fri Jul 18 19:05:37 EDT 2025
Powered by FUDForum. Page generated in 0.09726 seconds
