Home » Newcomers » Newcomers » Selection does not contain a main type error.
Selection does not contain a main type error. [message #820382] Tue, 13 March 2012 23:47 Go to next message
I am currently doing a Java course. I am only 3 lessons in. When I run the TestTax class (I right click on TestTax.java and run as a java application), I get an error that says "Selection does not contain a main type". If I click the green "run" button, it says "Editor does not contain a main type." As you can see from the code below, it does have a main method. Am I missing something??
class TestTax{
public static void main(String[] args){
NJTax t = new NJTax(); // creating an instance
t.grossIncome= 50000; // assigning the values
t.dependents= 2;
t.state= "NJ";
double yourTax = t.calcTax(); //calculating tax
// Printing the result
System.out.println("Your tax is " + yourTax);
Re: Selection does not contain a main type error. [message #822553 is a reply to message #820382] Fri, 16 March 2012 15:24 Go to previous message
> class TestTax{
> t.dependents= 2;
> t.state= "NJ";
What kind of project is it in? It should be a Java Project. The source
file should also be in a Source Folder in the project's Java Build Path.
I'd also suggest not using the "default" package.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Previous Topic:Text Compare Colors
Next Topic:Where can I download PyDev
Current Time: Fri Jul 25 21:53:02 EDT 2025
Powered by FUDForum. Page generated in 0.28904 seconds
