Home » Modeling » TMF (Xtext) » [Xtend] Xtend 2.3 maven compiler build
[Xtend] Xtend 2.3 maven compiler build [message #820170] Tue, 13 March 2012 16:23 Go to next message
for our Xtext project we are using a Maven/Tycho based build, but sadly we cannot use the current, v2.2 xtend-maven-compiler because of https://bugs.eclipse.org/bugs/show_bug.cgi?id=367914.
The issue is already fixed for v2.3, however, the last snapshot version of the compiler I found is of 2011.12.13, and according to Hudson the Xtext-Maven-Deploy job was executed the same time.
My question is whether the compiler is available in binary form (e.g. in some repository I failed to find)? Or if not, could you give me some hints how to compile the current head to get the compiler working? The current Buckminster-based build is a bit hard for me to understand (although it is organized neatly).
Thank you for your help,
Zoltán Ujhelyi
UPDATE: I moved the '.' (dot) outside the bug url, as the resulting bug number was invalid.
[Updated on: Tue, 13 March 2012 17:02] by Moderator
Re: [Xtend] Xtend 2.3 maven compiler build [message #820187 is a reply to message #820170] Tue, 13 March 2012 16:52 Go to previous messageGo to next message
did you already had a look at http://maven.eclipse.org/nexus/content/repositories/nightly-juno/
~Christian
Re: [Xtend] Xtend 2.3 maven compiler build [message #820191 is a reply to message #820187] Tue, 13 March 2012 16:56 Go to previous messageGo to next message
thank you for the quick answer, I did not check that repository. However, the repository contains only xtend-maven-plugin-2.2.0-20111206.101637, that is older then the fix of 2012-01-22, so it does not solve my problem.
Additionally, executing a search in maven.eclipse.org/nexus does not find anything newer.
Thank you for your help again,
Zoltán
Re: [Xtend] Xtend 2.3 maven compiler build [message #821865 is a reply to message #820170] Thu, 15 March 2012 18:52 Go to previous message
Hi Zoltan!
AFAIK it has not been deployed so far in a public repository. You will have to build it from sources and deploy it into your local repository manager.
~Karsten
Previous Topic:Java Proposal
Next Topic:extending grammar: error in generated Semantic Sequencer?
Current Time: Sat Jul 26 11:21:28 EDT 2025
Powered by FUDForum. Page generated in 0.05727 seconds
