Home » Modeling » Graphiti » creating a ChopboxAnchor on a nested polygon
creating a ChopboxAnchor on a nested polygon [message #789436] |
Thu, 02 February 2012 20:12  |
Hi there again,
I have a new issue with creating connections to a polygon nested in an invisible rectangle. When I create a connection it anchors to the outer invisible rectangle and not to the polygon. It is a very similar situation as in the tutorial, in fact I believe I have faithfully replicated this feature setup. (See below)
When I re-ran the tutorial example everything seemed fine. The chop box was associated with the inner rectangle and made its connections there. Unfortunately not so with my parallelogram. Is there anything that I am obviously missing?
It seems to me that I need to create a container shape that is specific to the polygon and associate the chop box with that. However, then in the layout routine it is not clear what pictogram element the context would be picking up or is there a way to change my layout code so that I can still have the outer invisible rectangle be the "parent" (i.e. dictating the size for the addition ornaments, namely the diamond that is added from time to time.)?
Thanks in advance,
Joe
public PictogramElement add(IAddContext context) {
Strategy addedClass = (Strategy) context.getNewObject();
Diagram targetDiagram = (Diagram) context.getTargetContainer();
SafetyCase sc = (SafetyCase)targetDiagram.getLink().getBusinessObjects().get(0);
sc.getNode().add(addedClass);
// CONTAINER SHAPE
IPeCreateService peCreateService = Graphiti.getPeCreateService();
ContainerShape containerShape =
peCreateService.createContainerShape(targetDiagram, true);
// define a default size for the shape
int width = context.getWidth() <= 0 ? 100 : context.getWidth();
int height = context.getHeight() <= 0 ? 50 : context.getHeight();
IGaService gaService = Graphiti.getGaService();
Polygon p;
int offset = 0;
Rectangle invisible = gaService.createInvisibleRectangle(containerShape);
if(addedClass.isToBeDeveloped()){
System.out.println("Strat add offset????");
offset = UNDEVELOPED_OFFSET;
gaService.setLocationAndSize(invisible, context.getX(), context.getY(), width, height+offset);
int xy[] = new int[] {25,0,100,0,75,50,0,50};
// Polygon p = gaService.createPolygon(containerShape, xy);
p = gaService.createPolygon(invisible, xy);
p.setParentGraphicsAlgorithm(invisible);
p.setBackground(manageColor(CLASS_BACKGROUND));
p.setForeground(manageColor(CLASS_FOREGROUND));
p.setLineWidth(2);
Graphiti.getPeService().setPropertyValue(containerShape, "shape-type", "parallelogram");
gaService.setLocationAndSize(p, 0, 0, width, height);
// create link and wire it
link(containerShape, addedClass);
Shape shape = peCreateService.createShape(containerShape, false);
int[] diamondXY = new int[] {10,0,20,10,10,20,0,10};
Polygon diamond = gaService.createPolygon(shape, diamondXY);
diamond.setBackground(manageColor(UNDEV_BACKGROUND));
diamond.setForeground(manageColor(UNDEV_FOREGROUND));
diamond.setLineWidth(2);
Graphiti.getPeService().setPropertyValue(shape, "shape-type", "diamond");
//gaService.setLocationAndSize(p, width/2, height, 10, 10);
gaService.setLocation(diamond, (width/2-10), (height));
link(shape, addedClass);
// SHAPE WITH TEXT
// ...............Elided text stuff
// add a chopbox anchor to the shape
ChopboxAnchor cpb = peCreateService.createChopboxAnchor(containerShape);
cpb.setReferencedGraphicsAlgorithm(p);
// call the layout feature
layoutPictogramElement(containerShape);
return containerShape;
public boolean layout(ILayoutContext context){
boolean anythingChanged = false;
boolean mDevelop = false;
(ContainerShape) context.getPictogramElement();
GraphicsAlgorithm containerGa = containerShape.getGraphicsAlgorithm();
PictogramElement pe = context.getPictogramElement();
EList<EObject> bOs = pe.getLink().getBusinessObjects();
Strategy s = (Strategy) bOs.get(0);
if (s.isToBeDeveloped()){
mDevelop = true;
// polygon is added first so will always be 0????
Polygon poly = (Polygon) containerGa.getGraphicsAlgorithmChildren().get(0);
// height
if (containerGa.getHeight() < MIN_HEIGHT) {
containerGa.setHeight(MIN_HEIGHT);
anythingChanged = true;
// width
if (containerGa.getWidth() < MIN_WIDTH) {
containerGa.setWidth(MIN_WIDTH);
resizePoly(poly,containerGa.getWidth(), containerGa.getHeight());
int containerWidth = containerGa.getWidth();
int containerHeight = containerGa.getHeight();
for (Shape shape : containerShape.getChildren()){
GraphicsAlgorithm graphicsAlgorithm = shape.getGraphicsAlgorithm();
IDimension size =
gaService.calculateSize(graphicsAlgorithm);
if (containerWidth != size.getWidth()) {
if (graphicsAlgorithm instanceof MultiText) {
MultiText mt = (MultiText) graphicsAlgorithm;
mt.setHeight(containerHeight - DESCRIPTION_OFFSET);
mt.setWidth(containerWidth);
} else if (graphicsAlgorithm instanceof Rectangle){
Rectangle rt = (Rectangle) graphicsAlgorithm;
rt.setHeight(containerHeight); //- UNDEVELOPED_OFFSET );
rt.setWidth(containerWidth);
} else if (graphicsAlgorithm instanceof Polygon){
Polygon pg = (Polygon) graphicsAlgorithm;
PictogramElement pge = pg.getPictogramElement();
if(Graphiti.getPeService().getPropertyValue(pge, "shape-type").equals("diamond")){
System.out.println("DIAMOND FOUND");
pg.setX(containerWidth/2 - UNDEVELOPED_OFFSET/2);
pg.setY(containerHeight - UNDEVELOPED_OFFSET);
} else if (graphicsAlgorithm instanceof Polyline) {
Polyline polyline = (Polyline) graphicsAlgorithm;
Point secondPoint = polyline.getPoints().get(1);
Point newSecondPoint =
gaService.createPoint(containerWidth, secondPoint.getY());
polyline.getPoints().set(1, newSecondPoint);
} else {
gaService.setWidth(graphicsAlgorithm,
containerWidth);
return anythingChanged;
Re: creating a ChopboxAnchor on a nested polygon [message #823150 is a reply to message #820032] |
Sat, 17 March 2012 17:44   |
Hi Michael,
Thank you so much for looking into this for me. I apologize it has taken me so long to get back to this.
Unfortunately, that still leaves the connection feature dangling below the bottom of the diamond as opposed to being connected to the polygon. The sides look great though!
I thought I would try and run with your idea and implement something similar:
int polyxy[] = new int[] {25,0,100,0,75,50,0,50};
int offset = 0;
Rectangle invisibleRect = gaService.createInvisibleRectangle(containerShape);
if(addedClass.isToBeDeveloped() || addedClass.isToBeInstantiated()){
gaService.setLocationAndSize(invisibleRect, context.getX(), context.getY(), width, height + offset);
// CREATE new shape for chop box
Shape shapePoly = peCreateService.createShape(containerShape,true);
Polygon invisible = gaService.createPolygon(shapePoly, polyxy);
invisible.setFilled(false
invisible.setLineVisible(false);
gaService.setLocationAndSize(invisible, 0, 0, width, height );
//invisible.setParentGraphicsAlgorithm(invisibleRect);
// VISIBLE POLYGON
Polygon p = gaService.createPolygon(invisibleRect, polyxy);
p.setStyle(StyleUtil.getStyleForNode(getDiagram()));
p.setParentGraphicsAlgorithm(invisibleRect);
//p.setParentGraphicsAlgorithm(invisible);
Graphiti.getPeService().setPropertyValue(containerShape, "shape-type", "parallelogram1");
Graphiti.getPeService().setPropertyValue(shapePoly, "shape-type", "parallelogram2");
link(shapePoly, addedClass);
Unfortunately the "invisible" polygon does not render (I turned it to visible and made it bigger to test this) unless I set the parent GA to be invisibleRect. At that point though I get the following NPE.
!ENTRY org.eclipse.graphiti 4 0 2012-03-17 14:23:32.831
!MESSAGE refresh edit part problem
!STACK 0
at org.eclipse.draw2d.Figure.add(Figure.java:148)
at org.eclipse.draw2d.Figure.add(Figure.java:184)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addChildVisual(AbstractGraphicalEditPart.java:209)
at org.eclipse.graphiti.ui.internal.parts.ContainerShapeEditPart.addChildVisual(ContainerShapeEditPart.java:161)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:211)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
at org.eclipse.graphiti.ui.internal.parts.ShapeEditPart.refreshChildren(ShapeEditPart.java:635)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:726)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
at org.eclipse.graphiti.ui.internal.parts.ShapeEditPart.refresh(ShapeEditPart.java:555)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
at org.eclipse.graphiti.ui.internal.parts.DiagramEditPart.refresh(DiagramEditPart.java:183)
But I am not certain where this is derived from exactly.
I'll use your solution for the moment and keep playing.
Thanks again,
Joe
Re: creating a ChopboxAnchor on a nested polygon [message #826008 is a reply to message #823150] |
Wed, 21 March 2012 10:32   |
It seems that you have a shape without an associated GA, that's usually the
cause of such a NPE.
How about defining the outer invisble polygon just the size that it covers
exactly all inner visible polygons?
Polygon invisiblePolygon = gaService.createPolygon(containerShape,
new int[] { 25, 0, 100, 0, 75,50, 50,50, 55,55, 50,60, 45,55, 50,50
,0,50 });
Michael
Re: creating a ChopboxAnchor on a nested polygon [message #831963 is a reply to message #826865] |
Thu, 29 March 2012 11:24  |
Hi Michael,
Sorry it has taken me a bit to get back to this. I have had a few other things going on, as I am sure we all do.
Well, this worked. It took a bit to get the rendering right but it worked really well.
So I have two other questions which are somewhat related.
The first is related to the similar connection placement for rounded rectangles. I have tried a few different implementations with the chopbox (implementations as in
containershape and GA configurations) but the connection feature will not connect directly to the GA on the corners. (It again is offset by the rectangle.) I tried this behavior in the tutorial code and got a similar outcome. I am rounding my corners a lot more than the tutorial. Is there something similar that I could try to get the attachment at the corners?
The second question relates to refresh and update. I am setting certain properties, such as the odd diamond and some text via the property viewer (I used the EEF methodology to create these.) Is there any way to get a "refresh" to fire automatically when an update is recognized? What is the sequence of events that cause an update to be recognized?
Thanks, as always!
Joe
Current Time: Sat Jul 19 00:21:03 EDT 2025
Powered by FUDForum. Page generated in 0.07558 seconds
