Home » Modeling » TMF (Xtext) » SetExpressions: Lists and Ranges
SetExpressions: Lists and Ranges [message #810585] Thu, 01 March 2012 04:38 Go to next message
Hi folks!
I want to have expressions for sets of items like
list: {1, 2, 3} or even {1}
range: {1..3}
I found so far two possibilites with XText. The first doesn't creaste the correct Ecore-Model, the second doesn't work with syntactic predicates as expected (I don't know understand why):
1.
SetDescription returns SetDescription:
   "{" ArithExpr (
     ({SetList.elements+=current} ("," elements += ArithExpr)+ |
     ({SetRange.left=current} ".." right=ArithExpr)?
ArithExpr: ...;
Problem here is: In the ecore model the type ArithExpr is a subtype of SetDescription, which shall not be the case. Ok, so work with syntactic predicates, since it will be not left-factored:
2.
		=>({SetList} elements+=ArithExpr (',' elements+=ArithExpr)*) |
		({SetRange} left=ArithExpr '..' right=ArithExpr)
In this case, the second "range"-alternative can never be taken, that means, I can not write expressions like {1..2}. I thought that syntactic predicates work like backtracking, meaning, that if the parser see ".." he tracks back and doesn't take the default alternative described by the syntactic predicate (here the list of items).
What I want is an (abstract) type SetDescription with (concrete) subtypes SetListDescription (with elements attribute) and SetRangeDescription (with left and right attributes). ArithExpr shall not be a subtype of SetDescription (in this case, if the description looks like {1}, it shall be a SetListDescription. What I don't want is:
* attributes in SetDescription like "firstItem"
* describe the range syntactically in another way, like [1..3] instead of {1..3}
* turn on backtrack option.
Does anyone has an idea how to solve this problem with XText (if possible)?
Re: SetExpressions: Lists and Ranges [message #810610 is a reply to message #810585] Thu, 01 March 2012 05:11 Go to previous messageGo to next message
This looks like the same problem that I have in OCL.
The ".." gets confused with the decimal point in a floating point number
and needs backtracking to sort it out.
I used to use an LPG grammar that could resolve this, but while
developing an Xtext to LPG translator, I noticed that the LPG Lexer
grammar bears no resemblance to the Xtext terminal grammar, so it may be
that a more considered exposition of the floating point number grammar
may make the problem go away. Either way, ".." needs to be resolved by
the lexing phase to avoid stupidities in the parsing.
Ed Willink
On 01/03/2012 09:38, Alex G wrote:
> Hi folks!
> range: {1..3}
Re: SetExpressions: Lists and Ranges [message #810765 is a reply to message #810610] Thu, 01 March 2012 09:33 Go to previous messageGo to next message
I don't have problems with the ".." here, since my ArithExpr is a parser rule, which can reference to a variable or be an integer or a floating point number. There were no problems to establish an ecore model, where the ArithExpr type is a subtype of SetDescription (but this is pragmatically not a nice solution, cp. Code 1 above).
Re: SetExpressions: Lists and Ranges [message #811412 is a reply to message #810585] Fri, 02 March 2012 05:09 Go to previous messageGo to next message
Would unassigned rulecalls work?
SetDescription :
'{' SetList | SetRange '}'
SetList:
elements+=ArithExpr (',' elements+=ArithExpr)*;
SetRange
left=ArithExpr '..' right=ArithExpr;
Am 01.03.12 10:38, schrieb Alex G:
> Hi folks!
> range: {1..3}
> 1.
> "{" ArithExpr (
> ArithExpr: ...;
> 2.
> of {1..3}
Re: SetExpressions: Lists and Ranges [message #818984 is a reply to message #811412] Mon, 12 March 2012 06:47 Go to previous messageGo to next message
Jan Kohnlein wrote on Fri, 02 March 2012 05:09
SetDescription :
SetList:
SetRange
No, this doesn't work, since it is again non-LL.
But I have found a solution for this (a little bit tricky, but it works):
	'{' ArithExpr (
			((',' {SetList.elements+=current} elements+=ArithExpr) (',' elements+=ArithExpr)*) |
			('..' {SetRange.left=current} right=ArithExpr) |
			({SetList.elements+=current})
(1) left-factor the ArithExpr
(2) choose what follows after ArithExpr: "," or ".." or nothing
(3) create actions according to what follows. When "," follows, I had to split (ArithExpr)+ into ArithExpr (ArithExpr)* in order to be able to create the action elements for the first and second ArithExpr in the list.
Re: SetExpressions: Lists and Ranges [message #819163 is a reply to message #818984] Mon, 12 March 2012 11:21 Go to previous messageGo to next message
Ahhhh, there is still some problem:
With the code from my last post above for SetDescription, now ArithExpr is a subtype of SetDescription, which it should not be! There arise problems with polymorphic dispatching in my scope provider.
Please compare p.61 on XText documentation ("Simple Actions"). In my case, I want that a type is assumed if a token is embraced by two terminals and not only leading a terminal, like in the documentation. Here:
'{' something '}' -> shall create SetList
'{' something ',' something2 '}' -> shall create SetList (something is embraced by '{' and ',')
'{' something '..' something2 '}' -> shall create SetRange (something is embraced by '{' and '..')
So my solution is still not possible. Any ideas?
Re: SetExpressions: Lists and Ranges [message #819201 is a reply to message #819163] Mon, 12 March 2012 12:12 Go to previous messageGo to next message
I haven't tested this, it's just an idea:
SetDescription:
    ( => ({SetRange} left = ArithExpr '..') right = ArithExpr
    |     {SetList} elements += ArithExpr
               (',' elements += ArithExpr)*
I think that including the bare minimum number of rules/tokens inside the predicate should improve the error messages the user gets, so I included them only up to the '..'.
P.S. I've had problems with the '..' before, but you said you already had it solved. Anyhow, I solved that decimal point/.. conflict by replacing both the floating point number and the '..' with datatype rules, and using just a DOT: '.'; terminal rule (no '..' terminal, nor '..' literal string in parser rules):
FLOAT         : INT? DOT INT ; // INT from common terminals
RANGE hidden(): DOT DOT ; // replacement for '..' in the previous code snippet
terminal DOT  : '.' ;
The problem I've had is that '1 .. 2' is right, but with '1.. 2' the lexer matches '1.', so it assumes it is a floating point, but then it finds another '.' and raises an error.
Are you sure that your problem is not related to this "no space between 1 and .." problem?
Re: SetExpressions: Lists and Ranges [message #819701 is a reply to message #819201] Tue, 13 March 2012 04:13 Go to previous messageGo to next message
Hi Stefano!
You are great! Your code works fine for me! Just what I searched for a long time. I worked also with syntactic predicates, but I tested it only on exactly one parser rule or on the whole alternative, but not on a part of the alternative (as you said: "bare minimum of rules/tokens"), which if thinking of it, makes of course much more sense!
Stefano Zanotti wrote on Mon, 12 March 2012 12:12
I use my float numbers all the time as data type rules. And I don't have any conflicts with the '..', even if there is no space between the leading number and the '..'. Further I don't need a special RANGE-terminal, like in your case. It's working with '.' and '..' out of the box, if dealing with data type rules. (I think '.' and '..' are a type of implicitely defined terminal rules).
Thank you for your help!
Re: SetExpressions: Lists and Ranges [message #819744 is a reply to message #819701] Tue, 13 March 2012 05:19 Go to previous message
Yes, I think the RANGE rule is unnecessary, but the FLOAT is (i.e. FLOAT must not be a terminal rule).
About syntactic predicates, thanks go to Vlad Dumitrescu, who pointed them out to me in another topic.
Previous Topic:Decision can match input such as "'.'" using multiple alternatives: 1, 2
Next Topic:importURI and importNamespace
Current Time: Fri Jul 25 23:03:08 EDT 2025
Powered by FUDForum. Page generated in 0.07826 seconds
