LTTng 2.0 [message #819337] |
Mon, 12 March 2012 15:54  |
Hello everyone.
We are in the process of restructuring the LTTng plug-ins for v2.0 wghich is planned for Juno. For those of you interested, the work is being tracked in https://bugs.eclipse.org/bugs/show_bug.cgi?id=374002.
Our goal is to do one last release of the legacy LTTng with the Linux Tools 0.10 (scheduled for March/26) and then move to the new structure for Juno.
Best Regards,
/fc
Re: LTTng 2.0 [message #847701 is a reply to message #840195] |
Tue, 17 April 2012 11:13   |
After a bit of cleanup, the CTF code finally made it in the master branch and the nightly build (P2 repo: http://download.eclipse.org/technology/linuxtools/updates-nightly).
As mentioned before, only the basic views work for now (Events, Histogram, Statistics, Project). The others are a work-in-progress as we are fitting the kernel analysis views to our new state system management.
If you installed the LTTng 2.0 tracer on your target system (which can be your main system), you can create your own traces. Info for trace control and collection can be found here: http://wiki.eclipse.org/index.php/Linux_Tools_Project/LTTng/User_Guide#LTTng_Tracer_Control_.28LTTng_Tracer_Toolchain_v2.0.29.
If you don't have CTF traces handy or don't want to instrument your system, we could provide some samples on demand.
Before opening a trace you have to specify its type so the correct parser is used to process it, in this case the CTF parser. This can be done e.g. at import time by selecting "LTTng -> LTTng 2.0 Kernel Type" as the trace type. The trace icon should change to a penguin. Opening the trace (select and press "Enter" in the Project view) should populate the views immediately.
If you try to assign the legacy format parser ("LTTng -> Kernel Trace"), you will get an immediate error.
Hope this helps. For more info/clarifications, please consult the wiki/user guide (http://wiki.eclipse.org/index.php/Linux_Tools_Project/LTTng/User_Guide) or simply post a question.
/fc
Re: LTTng 2.0 [message #856314 is a reply to message #855142] |
Wed, 25 April 2012 10:58  |
With a state system, yes CPU usage can be done.
The reason: process 0 == swapper == idle. So whenever you're not in 0, you're running the CPU.
For memory it's more complicated. The reason: Shared memory, we can trace every malloc and free, and we can know the initial memory usage, but I would suggest using a UST tracer to poll your memory usage.
I think some people at Suse are working on a similar project. Check out the lttng-dev mailing list, they have more info.
FUDForum. Page generated in 0.31359 seconds
