Home » Modeling » TMF (Xtext) » Decision can match input such as "'.'" using multiple alternatives: 1, 2
Decision can match input such as "'.'" using multiple alternatives: 1, 2 [message #819165] Mon, 12 March 2012 11:23 Go to next message
I'm using Xtext for more than a year but I still don't get it. I reade several other threads with examples and solutions for this problem but I cannot transfer it to my problem. I'm using Xtext 2.0 and have the following grammar:
Model:
	(PlanungsKategorien);
PlanungsKategorien:
	{PlanungsKategorien}
	'PlanungsKategorien'
	planungsKategorien += PlanungsKategorie*;
PlanungsKategorie:
	name=INT text=STRING ('.'subkategorie+=PlanungsKategorie)*;
And, as you experts may already see, I get the following error:
warning(200): /parser/antlr/internal/InternalDsl.g:217:2: Decision can match input such as "'.'" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
I don't see the problem. I also visualized this using the ANTLR Workbench.
The DSL usage should look like this:
1 "Category1"
.1 "Subcategory1"
.2 "Subcategory2"
Where is the ambiguity?
Thanky so much
Steffen
Re: Decision can match input such as "'.'" using multiple alternatives: 1, 2 [message #819227 is a reply to message #819165] Mon, 12 March 2012 12:45 Go to previous messageGo to next message
(first of all, I'm not sure, but maybe you should wrap this in parens: (planungsKategorien += PlanungsKategorie)*)
It's like a dangling-else problem: where does C belong to? To A or B ?
1 "A"
.2 "B"
.3 "C"
i.e. is it
1 "A"
    .2 "B"
    .3 "C"
[like 1 "A" (2 "B" 3 "C")]
or
1 "A"
    .2 "B"
        .3 "C"
[like 1 "A" (2 "B" (3 "C"))]
I think that this is easily solvable only if every '.' means "subcategory of the very last typed category", but this doesn't seem the case.
Do you want to allow for arbitrary nesting?
i.e.
1 "A"
  .2 "B"
  .3 "C"
    ..4 "D"
If this is the case, you should add something (like further '.'), in order to tell which nesting level a category belongs to.
I have no idea about how to do this via syntax only; I can only think of this (followed by a validation that counts the dots and assign each subcategory to its parent category):
PlanungsKategorien:
    ('.'* INT STRING)*;
That's not a nice solution, maybe others can think of something better.
Or, if you simply want to allow for a single level of nesting, you should introduce another rule, to avoid recursion:
PlanungsKategorie:
    INT STRING (PlanungsKategorieLevel2)*;
PlanungsKategorieLevel2:
    '.' INT STRING;
Re: Decision can match input such as "'.'" using multiple alternatives: 1, 2 [message #819322 is a reply to message #819227] Mon, 12 March 2012 15:20 Go to previous messageGo to next message
As Stefano points out it is the "dangle else" problem.
You can solve it by requiring that a sub category is terminated with a
token, or always interpret '.' as either a sub category (or sibling) -
and then allow the user to use some way to escape that decision.
Or use different tokens.
- henrik
> 1 "A"
> 2 "B"
> 3 "C"
> i.e. is it
> 1 "A"
> .2 "B"
> .3 "C"
> or
> 1 "A"
> .2 "B"
> .3 "C"
> case.
> i.e.
> 1 "A"
> .2 "B"
> .3 "C"
> ..4 "D"
> PlanungsKategorien:
> ('.'* INT STRING)*;
> PlanungsKategorie:
> '.' INT STRING;
Re: Decision can match input such as "'.'" using multiple alternatives: 1, 2 [message #819709 is a reply to message #819165] Tue, 13 March 2012 04:26 Go to previous message
of course *duh*. I should have figured out myself. Sorry.
The solution with many dots "..." is not nice, as you already said.
But as i need more than 2 levels of nesting, I will introduce some terminal symbol for a nesting level.
Steffen
Previous Topic:How to set file encoding of generated file from my dsl file
Next Topic:SetExpressions: Lists and Ranges
Current Time: Sun Jul 27 14:07:42 EDT 2025
Powered by FUDForum. Page generated in 0.04645 seconds
