Home » Modeling » EMF » Cross-reference between several models(Using TransactionalEditingDomain)
Cross-reference between several models [message #819159] Mon, 12 March 2012 11:18 Go to next message
I want to use TransactionalEditingDomain to synchronize several models between them, in order to separate a "business model" (only the usefull information I want to keep) and a "notation model" (e.g. the coordinates of each object) for example (like in GMF).
I want something like this :
Business Model:
<?xml version="1.0" encoding="ASCII"?>
<test:TestModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:test="http://test/1.0">
  <square name="squareA"/>
  <circle name="circleA"/>
</test:TestModel>
Notation Model:
<notation:NotationModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:test="http://notation/1.0">
  <notation href="referenceToSquareA" x="40" y="20" />
  <notation href="referenceToCircleA" x="100" y="10" />
</test:TestModel>
For this, I tried to use the absolute URI of each EObject as identifier for the href attribute. I extended ResourceSetListenerImpl to listen to modifications inside my business model and modify my other models like this :
MyListener:
public class MyListener extends ResourceSetListenerImpl {
public Command transactionAboutToCommit(ResourceSetChangeEvent event)
		      throws RollbackException {
	List notifications = event.getNotifications();
	for (Iterator i = notifications.iterator(); i.hasNext();) {
		Notification n = (Notification)i.next();
		if (n.getEventType() == Notification.SET && n.getNotifier() instanceof Square) {
			Square notifier = (Square) n.getNotifier();
			System.out.println (EcoreUtil.getURI(notifier));
			// Modification of the notation model
Problems appear when :
- I delete an EObject inside my business model:
transactionAboutToCommit:
if (n.getEventType() == Notification.REMOVE && n.getOldValue() instanceof Square) {
	System.out.println (EcoreUtil.getURI(notifier)); // print "#//"
- I add an EObject in a collection of EObject:
Modifiying my business model:
editingDomain.getCommandStack().execute(new RecordingCommand(editingDomain) {
	protected void doExecute() {
		TestModel model = (TestModel)resource.getContents().get(0);
		Square square = SquareFactory.eINSTANCE.createSquare();
		model.getSquare().add(2,square); // I add square in third position, what about the URI of the fourth and the fifth square ?
I found some topics about the problem of synchronizing several models but no implementation which do this.
Does anybody have an idea to achieve this ?
Nicolas
Re: Cross-reference between several models [message #819183 is a reply to message #819159] Mon, 12 March 2012 11:43 Go to previous messageGo to next message
Nicolas,
Comments below.
On 12/03/2012 4:18 PM, nicolas h wrote:
> Business Model:
> </test:TestModel>
> Notation Model:
> </test:TestModel>
> MyListener:
> - I delete an EObject inside my business model: transactionAboutToCommit:
The object is no longer attached to the graph so it has no containing
resource and hence you can't determine it's original absolute URI.
> position, what about the URI of the fourth and the fifth square ? }
What are you trying to do with the URIs? You could traverse the
notation model to look for dangling references (references to EObjects
for which eResource is null). EcoreUtil has a utility for that.
> Best regards,
Re: Cross-reference between several models [message #820012 is a reply to message #819183] Tue, 13 March 2012 12:12 Go to previous message
Hi Ed,
Thank you for your remark. I wasn't interested in the EcoreUtil's capabilities. I'm rereading the part about splitting model into multiple packages from the EMF book. I realize that I wasn't on the right track.
Thank you again,
Nicolas
Previous Topic:[Databinding] TreeViewer not notified
Next Topic:[Xcore] preceding comment as GenModel documentation?
Current Time: Sat Jul 19 18:15:24 EDT 2025
Powered by FUDForum. Page generated in 0.03743 seconds
