Home » Modeling » TMF (Xtext) » Complex Cross Reference
Complex Cross Reference [message #818593] Sun, 11 March 2012 18:10 Go to next message
Hi all,
i'm pretty new of this forum... and i've discovered the power of xtext2... currently i'm using it for my degree thesis..
I have a problem with cross reference, that maybe this community, much more expert than me, can resolve...
MainRule:
'goals {' ((goalsList+=Goal) (',' goalsList+=Goal)*)? '}' //Pre-defined Goal
(planList+=[Plan])+
Plan:
'plan' name=ID '{'
(('event' eventName=[Event]) | ('goal' goalName=[Goal])) //Pre-defined goal or new one
'context' context=BoolExpr
'body {'
planBody+=Action*
//One of the Action is this...
ModifyGoal returns SingleAction:
planAction=('add' | 'delete') goalName=[Goal]; //Both pre-defined or new
The fact is that i don't want lose the cross reference function in goals definition. The list of goals doesn't have to be fully explained in the "goals" rule. Anyway in Plan-Goal i would like to reference that goals and other new. Finally i would like to reference both - preDefined and post defined goal - from ModifyGoal rule...
is it possible to have that dynamic behaviour?
thank you so much!
Denis
Re: Complex Cross Reference [message #818633 is a reply to message #818593] Sun, 11 March 2012 19:38 Go to previous messageGo to next message
x = [GOAL]
means that x is a reference to a GOAL, that is found by searching for an
instance of GOAL with an exported name matching a parsed ID - i.e.
x = [GOAL | ID ]
By default, anything is referenceable that has a name = ID attribute.
(Other things can be made referenceable even if they do not have a name
attribute).
It does not matter where this GOAL comes from when you are specifying
the grammar - it can be in the same file, some other file, in a jar, in
a different project etc. etc. all depending on how you configure your
language.
I do not understand what you mean by "pre-defined" goal vs.
"post-defined" - can you elaborate?
Hope the answer above still helps you.
- henrik
On 2012-11-03 23:10, Denis Brighi wrote:
> Hi all,
> xtext2... currently i'm using it for my degree thesis.. I have a problem
> me, can resolve...
> MainRule:
> Goal
> (planList+=[Plan])+
> Plan:
> 'plan' name=ID '{'
> goal or new one
> 'body {'
> planBody+=Action*
> thank you so much!
> Denis
Re: Complex Cross Reference [message #818906 is a reply to message #818633] Mon, 12 March 2012 05:07 Go to previous messageGo to next message
Thank you for the fast response Very Happy
I try to explain myself better...
"Pre-defined" goal, are static-like task in my language, listed a priori.
But i would like to define other Goal, not listed before, and use them to cross refernce
the action ModifyGoal
Is it more clear now?
Ok... i did the try (as you can see below, in the complete code)
 x = [GOAL | ID ]
but when i run the editor and i try to write in a plan like this one:
goals {
      goal1, goal2
plan piano1 {
	goal goal1 //OK
	context true
	body {
plan piano1 {
	goal nonInListGoal //Error
	context true
	body {
it continues to give me error: "Couldn't resolve reference to Goal 'nonInListGoal'."
i attach the complete part of grammar to this point
MainRule:
         (planList+=[Plan])+;
Plan:
	'plan' name=ID '{'
		(('event' eventName=[Event]) | ('goal' goalName=[Goal|ID]))
		'body {'
			planBody+=Action*
//Action:
//       ... | ModifyGoal;
Goal:
	name=ID;
[Updated on: Mon, 12 March 2012 05:09] by Moderator
Re: Complex Cross Reference [message #819112 is a reply to message #818906] Mon, 12 March 2012 10:03 Go to previous messageGo to next message
Where is the "nonInList" goal defined?
Btw [Goal] and [Goal|ID] means exactly the same thing.
- henrik
On 2012-12-03 10:07, Denis Brighi wrote:
> Thank you for the fast response :d
> to cross refernce
> Ok... i did try the
> x = [GOAL | ID ]
> goals {
> goal1, goal2
> plan piano1 {
> goal goal1 //OK
> context true
> body {
> plan piano1 {
> context true
> body {
> 'nonInListGoal'."
> MainRule:
> Goal
> Plan:
> 'plan' name=ID '{'
> 'body {'
> planBody+=Action*
> //Action:
> Goal:
> name=ID;
Re: Complex Cross Reference [message #819124 is a reply to message #819112] Mon, 12 March 2012 10:28 Go to previous messageGo to next message
Anywhere... it's a name for a new plan, defined there inside that plan...
In plan rule, i would reference - (a previously defined goal OR a new goal)
Re: Complex Cross Reference [message #819254 is a reply to message #819124] Mon, 12 March 2012 13:15 Go to previous messageGo to next message
On 2012-12-03 15:28, Denis Brighi wrote:
> Quote:
From a language perspective, it makes it hard to differentiate between
a reference to something that exists and it was not spelled correctly,
and something new.
If you use a keyword to denote the intent to create a new goal it is
both much easier to handle (works out of the box), and IMO would be help
users with potential errors.
i.e. something like:
('goal' goalRef = [Goal]) | ('new' 'goal' newGoal = Goal)
If you really want "if it does not exist, then create it" you need to
customize how the linking is done - either by customizing scoping or by
doing your own (additional) linking. There are some blog posts available
on the topic of linking to an EObject, and solving what it can reference
using scoping (don't have the URL handly - IIRC Meinte Boersma's blog).
If you want custom linking, I posted on that subject before.
PS: I would use the 'new' 'goal', saves you a lot of work.
- henrik
Re: Complex Cross Reference [message #819380 is a reply to message #819254] Mon, 12 March 2012 17:17 Go to previous messageGo to next message
i think so... thank you very much!
Re: Complex Cross Reference [message #820784 is a reply to message #819254] Wed, 14 March 2012 11:04 Go to previous message
I concluded with a complete listing of goal with a keyword,
like
goals {
goal1, goal2 disabled, goal3
So the effect is the same...
thank you very much for the help!
Previous Topic:Validation just for the changed elements?
Next Topic:Reference to implicit variable
Current Time: Sun Jul 27 11:20:23 EDT 2025
Powered by FUDForum. Page generated in 0.27622 seconds
